[Guide] Sierra / HighSierra / Mojave / Catalina on Serie 5, 6, 7, 8, 9 / DSDT
Post by MaLd0n » 19 Jun 2019, 23:46
Leonidivs, converter o que?
Added in 1 minute 10 seconds:
cedroxim, create one usb with dosdude tool
-Donated? Send me one PM-
cedroxim
CPU: Intel Core I5 2500k
Motherboard: Intel DH67BL
GPU: Intel HD Graphics 3000
Post by cedroxim » 20 Jun 2019, 03:02
19 Jun 2019, 23:48
MaLd0n if I thought of it as an alternative but I thought there was a trick to jump that with your installer, how to change the smbios or fakecpuid.
if i use the dosdude tool i have to download the mojave app from zero, is there no way to use it with your raw image?
Then the only way to bypass is the dosdude.
update
I boot clover legacy and put smbios from macmini6,1 the installer runs fine.
Update 2
Installer progress bar stucked in 16 minutes remaining
Update 3
I could install Mac OS Mojave 10.14.5 Olarila Image, A Question? The first boot is laggy?
Build
SMBIOS: Macmini5,1
CPU: Intel Core i5 2500k (Sandy Bridge)
MOTHERBOARD: Intel DH67BL (H67 Chipset)
VIDEO: Intel HD Graphics 3000.
AUDIO: Realtek Alc892
STORAGE: Samsung SSD 840 PRO
Leonidivs
CPU: intel i7 3770
Motherboard: AsRock H61M - VS
GPU: intel HD 4000
Post by Leonidivs » 20 Jun 2019, 20:01
MaLdOn,
Baixei a imagem do Mojave, quero saber se posso prelarar o USB para a instalação à partir do Windows dó pelo Win32diskmanager?
Post by MaLd0n » 21 Jun 2019, 03:20
cedroxim, need a fine tune
Added in 14 seconds:
Leonidivs, sim
Leonidivs
CPU: intel i7 3770
GPU: intel HD 4000
Post by Leonidivs » 21 Jun 2019, 05:37
Maldon💪💪💪💪💪 :guitar
cedroxim
Post by cedroxim » 22 Jun 2019, 06:41
MaLd0n, I already managed to fix all the details of mojave 10.14.5. It works audio, video, ethernet, usb and shutdown.
Everything works normal and fast, I have boot in UEFI and everything normal. I have attached my EFI folder if one that has a build similar to mine serves.
:frantics
Build
SMBIOS: Macmini5,1
Post by MaLd0n » 22 Jun 2019, 10:06
cedroxim, extract one sendme and post here
cedroxim
Post by cedroxim » 23 Jun 2019, 08:38
Hi MaLd0n, Here the dump of the sendme, for you to take a look bro.
I have some glitches but it is because of the integrated video that is the intel HD 3000.
Build
SMBIOS: Macmini5,1
cassaregh
CPU: Intel i5 3570
Motherboard: www
GPU: AMD RX 570
Post by cassaregh » 25 Jun 2019, 13:05
Hi @MaLdon,
I just joined this forum so I can Install Mojave. When booting at the installer, I am stuck at "End RandomSeed ++++++++++++". I followed the instruction to change the AptioMemoryFix-64.efi to OsxAptioFix3Drv-64.efi but still I am stuck. Any idea how to fix this?
Post by MaLd0n » 25 Jun 2019, 13:26
cassaregh, use uefi mode, if u use legacy mode u need wait one minute in this screen
cassaregh
CPU: Intel i5 3570
Motherboard: www
GPU: AMD RX 570
Post by cassaregh » 25 Jun 2019, 14:04
25 Jun 2019, 13:26
I already changed to uefi mode. I am making a usb bootable again it might be something got corrupted.
Added in 1 minute 11 seconds:
Does my CPU is supported? and also my GPU?
Post by MaLd0n » 25 Jun 2019, 14:23
cassaregh, yes, both
cassaregh
CPU: Intel i5 3570
Motherboard: www
GPU: AMD RX 570
Post by cassaregh » 25 Jun 2019, 15:22
25 Jun 2019, 14:23
After creating a new usb bootable, I was able to pass the "Random Seed ++++++" error. Now the problem is, when the verbose will go to identifying the graphics card, the monitor will blink and shows like a TV with no signal. It keeps blinking like that. And sometimes I can see it displays the choosing of language with pink shade of the monitor for about 3 seconds and then it will blink again... I tried to press Enter key and it shows the macos installer and then blinks again. What should I do? I guess its about the gpu? I
Post by MaLd0n » 25 Jun 2019, 16:24
cassaregh, try other output
hdmi, dvi or dp
cassaregh
CPU: Intel i5 3570
Motherboard: www
GPU: AMD RX 570
Post by cassaregh » 25 Jun 2019, 16:28
25 Jun 2019, 16:24
hdmi, dvi or dp
The GPU has only DVI output. No hdmi or vga.
cedroxim
Post by cedroxim » 25 Jun 2019, 22:28
MaLd0n, You checked the send me friend?
I have an old laptop asus ul80jt with a first generation i3.
I installed mojave 10.14.5 using the second config.plist that is for laptops using nv_disable = 1.
I completed the installation and I could start it in the raw, I do not have any DSDT patch. Use the post installation of dosdude for the arradale graphics and do not boot it is kextd install igpu.
I know I have to patch the dsdt and ssdt but where do I get it raw? if the clover gives me a few DSS with little content.
I will try extracting the dsdt in Windows and I will comment.
Build
SMBIOS: Macmini5,1
cassaregh
CPU: Intel i5 3570
Motherboard: www
GPU: AMD RX 570
Post by cassaregh » 27 Jun 2019, 10:44
Hi MaldOn,
I bought a cable DVI to HDMI. It is not an adapter. I read somewhere that adapters causes problem . Everything works fine in the installer. But the monitor display weird color. It is purple / magenta color all over the monitor. Can this be fixed? Currently installing mojave now but the color is bothering me.
Post by MaLd0n » 27 Jun 2019, 12:15
cassaregh, try without weg.kext
cassaregh
CPU: Intel i5 3570
Motherboard: www
GPU: AMD RX 570
Post by cassaregh » 27 Jun 2019, 13:03
27 Jun 2019, 12:15
I don't know how to include weg.kext. I successfully installed mojave. But my problems are the color of the monitor and PC won't boot without the USB inserted.
Post by MaLd0n » 27 Jun 2019, 13:13
cassaregh, u need a boot from hdd/ssd
copy efi from usb stick or use olarila clover folder for ur chipset
