Install MacOS with Olarila Image, Step by Step, Install and Post Install
First...
If you need DSDT edits...
-Reboot and extract original tables, press F4 in Clover boot screen, files generated in Clover
-Run it and send me files
--Installation--
--Download Olarila Image--
The images have all you need, just use a boot key and install!
*if you created one personal USB Stick...
--Install Clover in USB stick
--Replace with my Clover folder
--Install Sierra/High Sierra/Mojave and boot into system!
--Post Installation--
--Install Clover in HDD/SSD and replace with my folder
--Fine Tune - DSDT--
Patches
-FIX ERRORS AND WARNINGS
-HPET
-SATA
-DMAC
-SLPB
-DARWIN
-EHCI
-XHCI
-PLUGIN TYPE
-XXXX to HDEF
-HDEF
-RTC
-IRQs
-SBUS
-MIKEY
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-LAN
-USBX
-IMEI
-EC
-PNLF
-GFX0
-HDAU
-NVME
-ARPT
-INTELHDGRAPHICS
or just run it
--Nvidia Cuda
--Power Management
-Nehalem and SandyBridge use Generate P and CStates in Config.plist
-IvyBridge, generate one SSDT with Piker script(You can use script for SandyBridge too)
-Haswell+ use "plugin-type"=0x01 in DSDT, SSDT or Clover config.plist
--Brightness
Install .app, select the required permission and reboot. Work in F1 / F2 keys!
*in some cases .app don't work, check patches in config.plist inside Clover folder Post Install
--Audio
--Lan
Done
-Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad and many, many, many others!
ENJOY!
