[Guide] Install MacOS High Sierra / Mojave / Catalina on AMD RYZEN / THREADRIPPER / ATHLON2xxGE / Full DSDT Patches
theCardfather
CPU: AMD FX-8320
Motherboard: Gigabyte 990FXS-UD3
GPU: AMD Radeon HD 7800
Post by theCardfather »
sata mode in ahci
do I change it to raid or native ide? ***never mind. I read that it has to be ahci. but ahci has already been enabled..
I can't find a lot of options like fast boot, etc on my motherboard, which is weird. (990fxa-ud3)
theCardfather
CPU: AMD FX-8320
I feel like I'm so close yet so far. also clicked on config2. blocked usbinjectall. but under boot arg, verbose and set nvidia to vesa is checked by default.
[External Link Removed for Guests] is the link to the pic.
Post by MaLd0n »
theCardfather, try with amd usb injector and sata amd kexts, check amd-osx forum
theCardfather
CPU: AMD FX-8320
22 Oct 2019, 00:24
thanks man.
UPDATE: well, i got high sierra to run on my surface pro 3 with touch and all. will continue to work on my amd desktop afterwards...
iryzen3900x
CPU: 3900x
Motherboard: Asus x570
GPU: 5700 XT
Post by iryzen3900x »
able to boot with clover , want to use Opencore to use beta to try my 5700 xt. unable to boot. can someone help ?
I have mono Asus TUF 570x Ryzen 3900x and 5700 XT.
I think , added the patch incorrectly.
elizona
CPU: Ryzen 3600
Motherboard: Asrock Phantom gaming 4
GPU: rx 580
Post by elizona »
Estou com um probleminha. Fiz os procedimentos mas quando preciso usar o utilitário de disco, ele não aparece e com isso não reconhece os armazenamentos que tenho. Fica parado em uma tela dizendo que não há espaço livre para instalar o olaria Mojave AMD. O que eu faço?
Post by MaLd0n »
elizona, nunca vi esse erro
está usando um pendrive de 16gb?
Eceiah
CPU: Ryzen 3 3200G
Motherboard: Asus Prime B450M-A
GPU: GeForce GTX 760
Post by Eceiah »
Hello Maldon,
Finally after being locked out of Olarila for months :(
I will try to install Mojave on my new rig, i will update you.
Cheers,
Post by MaLd0n »
Eceiah, ;)
Eceiah
CPU: Ryzen 3 3200G
Post by Eceiah »
05 Nov 2019, 14:39
--Olarila Hackintosh Builds Link
Will follow this and update you over the weekend.
Any tips on my mobo biios set up?
Bios Version 1820
2019/09/24 [External Link Removed for Guests]
ASUS PRIME B450M-A
Cheers!
Post by MaLd0n »
Eceiah, first try is default, just ahci set
Eceiah
CPU: Ryzen 3 3200G
Post by Eceiah »
copy. will update you!
Hackman666
CPU: 5930k
Motherboard: Rampage V
GPU: Vega 64
Post by Hackman666 »
hi, during installation when i go format ssd on disk utility the screen frozen, i try to install without format and frozen too..any one can help me?
Post by MaLd0n »
Hackman666, check if have patches update
Esfera
CPU: Intel i7 Quad 4.0
Motherboard: Gigabyte GA-Z97-HD3
GPU: GTX970
Post by Esfera »
Bos dias.
Eu son novo no hackintos e teño un PC con un Intel i7 Quad Core 4.0 e 32Gb DDR3 1866Mhz de RAM.
Monta unha GTX 970 4GB en un SSD 500GB
Antes funcionabame ben co Yosemite pero un dia deixoume de arrancar. Seguin o teu tutorial eh instalei ben o OSX HighSierra, pero cando intento face lo arranque dame varios erros en non funciona, deixo duas imaxes (da BIOS e dos Fallos):
[External Link Removed for Guests] / [External Link Removed for Guests]
Non sei que debo facer, se me podedes botar unha man.
Busquei no foro mais non encontrei a solucion.
P.D.: Perdoade o meu portugues, salin de pequeno e acostumbreime a falar español :P
Post by MaLd0n »
Esfera, use a pasta pro chipset 9
reinicie e extraia um send_me
--Run_Me
Esfera
GPU: GTX970
Post by Esfera »
Gracias por a respota tan rapida, descarguei este: CHIPSET SERIES 5, 6, 7, 8, 9
Mais agora que fago con él?
Onde teño que meter eses arquivos? ou mais ben, como os meto se non arranca o computador?
Perdoa a miña ignorancia...
Post by MaLd0n »
Esfera, efi partition
use other topic, here is for amd processors
Esfera
GPU: GTX970
Post by Esfera »
OK, perdoa, eu escribin neste hilo po lo da isntalacion do HigSierra.
Agora bou para o outro hilo.
Gracias ^^
Eceiah
CPU: Ryzen 3 3200G
Post by Eceiah »
Hi Maldon,
Ok so i tried yesterday to install them on my AMD desktop.
1: disk utility cant see my HDD
2: screen freezes after 10secs or so..
Kindly assist.
