Hackintosh Tutorial - Sierra / HighSierra / Mojave / Catalina em Mobos séries 5, 6, 7, 8, 9, 10, 20 e 30
satkabir
CPU: xeon
Motherboard: z270f
GPU: rx570
Hackintosh Tutorial - Sierra/HighSierra/Mojave em Mobos séries 5, 6, 7, 8, 9, 10, 20 e 30
Post by satkabir » 18 Feb 2019, 18:13
MaLd0n, Hello sir, I have a z620 with 2 xeon e5-2670 and 96gb ram and a gtx titan.
Everything is working except the usb 3 ports in the front and the back.
I have tried everything... it will be very helpful if you can take a look into this matter.
and i am not able to connect hdd above 3tb of capacity into the hackintosh as well.
Please let me know what files do you need to fix this problem and i will provide them to you.
Thank you for at least reading this.
Post by MaLd0n » 18 Feb 2019, 18:15
satkabir, post files here
--Run_Me
satkabir
CPU: xeon
Motherboard: z270f
GPU: rx570
Post by satkabir » 18 Feb 2019, 19:00
where can i post the efi ?
Added in 13 minutes 56 seconds:
MaLd0n, [External Link Removed for Guests]
Here are the files... i hope they help.
Post by MaLd0n » 18 Feb 2019, 20:19
satkabir,
ur usb3 is not intel
try it
GenericUSBXHCI.x79.zip
satkabir
CPU: xeon
Motherboard: z270f
GPU: rx570
Post by satkabir » 18 Feb 2019, 20:22
MaLd0n, I did tried that kext but the issue that get is that after the mac sleeps and wake the usb 3 stops working.
Post by MaLd0n » 18 Feb 2019, 20:25
satkabir, :shock: avoid sleep
satkabir
CPU: xeon
Motherboard: z270f
GPU: rx570
Post by satkabir » 18 Feb 2019, 20:26
MaLd0n, Is there any fix for that ? any possible fix ?
Post by MaLd0n » 18 Feb 2019, 20:32
satkabir, first u need solve ur Power Management, u dont have it now
satkabir
CPU: xeon
Motherboard: z270f
GPU: rx570
Post by satkabir » 18 Feb 2019, 20:33
MaLd0n, And how can i fix that ? can you guide me ?
Post by MaLd0n » 18 Feb 2019, 20:40
satkabir, here have a solution by stinga
satkabir
CPU: xeon
Motherboard: z270f
GPU: rx570
Post by satkabir » 18 Feb 2019, 20:44
MaLd0n, Thanks, I will get this done and get back to you if this fixes my sleep wake usb issue... i will donate.
Post by MaLd0n » 18 Feb 2019, 20:50
satkabir, :cap :guitar
satkabir
CPU: xeon
Motherboard: z270f
GPU: rx570
Post by satkabir » 18 Feb 2019, 20:51
MaLd0n, And do you have any guide on how to create custom sdd for the hackintosh ?
Added in 58 minutes 57 seconds:
MaLd0n, How can i get rid of the unknown cpu in the about this mac... When i tried the last time i crashed this
Added in 3 minutes 15 seconds:
MaLd0n, And it is showing 80 gb of ram which is two less sticks of ram making it 96 gb...
Added in 19 minutes 42 seconds:
MaLd0n, The hackintosh is making a electrical sound after the fixes you provided... should i be worried ?
Post by MaLd0n » 18 Feb 2019, 23:16
satkabir, for create ssdt use it
unknow cpu, use 0x0a05 ion cputype in cpu tab in config.plist
use native audio, not voodoohda, remove voodoohda and put applealc and inject 1 via clover
satkabir
CPU: xeon
Motherboard: z270f
GPU: rx570
Post by satkabir » 21 Feb 2019, 18:20
MaLd0n, I tried cpu type you said in the clover but it doesn't work
it is still showing up as unknown.
Post by MaLd0n » 21 Feb 2019, 18:27
satkabir, [Local Link Removed for Guests]
satkabir
CPU: xeon
Motherboard: z270f
GPU: rx570
Post by satkabir » 21 Feb 2019, 21:03
MaLd0n, It is giving error 36 no matter how many times i install the os whenever i use your dsdt.aml file
Post by MaLd0n » 22 Feb 2019, 01:17
satkabir, post one photo
satkabir
CPU: xeon
Motherboard: z270f
GPU: rx570
Post by satkabir » 24 Feb 2019, 21:47
MaLd0n, Hello sir, i was working on another build of mine because the last one didn't work for me
and i am not able to output hdmi in UHD 630 in mojave
Post by MaLd0n » 25 Feb 2019, 12:02
satkabir, [External Link Removed for Guests]
Return to “Guias de instalação”
