Hackintosh Tutorial - Sierra / HighSierra / Mojave / Catalina em Mobos séries 5, 6, 7, 8, 9, 10, 20 e 30
Re: Sierra/HighSierra em Mobos séries 5, 6, 7, 8, 9, 10, 20
Post by MaLd0n » 10 Mar 2018, 14:22
olivier wrote:This time files can't be uploaded... Any idea?
here
-Donated? Send me one PM-
olivier
CPU: 2xXeon E5 2670
Motherboard: HP Z620 C602
GPU: Quadro 400
Post by olivier » 10 Mar 2018, 15:48
CLOVER-HPZ620-sierra.zip
Send me mac-pro-de-olivier.home.zip
Post by MaLd0n » 10 Mar 2018, 16:09
olivier wrote:CLOVER-HPZ620-sierra.zip
Replace full folder, reboot and send me new dumps
CLOVER.zip
olivier
CPU: 2xXeon E5 2670
GPU: Quadro 400
Post by olivier » 10 Mar 2018, 16:57
Video is now perfect! Thank you Master.
Concerning CPU detection, is there anything else to do? (it is shown 2 x 2,59GHz unknown)
Do you think there could be a solution for USB3.0 to work?
Here is the new send me file:
Send me Mac-Pro-de-Olivier.zip
Post by MaLd0n » 10 Mar 2018, 17:43
olivier wrote:Video is now perfect! Thank you Master.
replace, reboot, new dumps
CLOVER.zip
Audio work?
olivier
CPU: 2xXeon E5 2670
GPU: Quadro 400
Post by olivier » 10 Mar 2018, 18:30
Thank you MaLdOn!
Now audio and lan work perfectly.
SAS Hdds are show "orange".
CPU is always shown as "unknown"... Don't know if it has any effect on performances.
Still no USB 3,0 ports, but I think that the problem is still unsolved.
New dumps here:
Send me mac-pro-de-olivier-1.home.zip
Post by MaLd0n » 10 Mar 2018, 18:55
olivier wrote:Thank you MaLdOn!
New dumps here:
CLOVER.zip
SAS
idk if work, the kext is not oficial
CPU
open . /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/English.lproj/
USB3
is load, but with genericxhci kext dont appears in system profiler, but work in some cases
we need solve Power Management now
olivier
CPU: 2xXeon E5 2670
GPU: Quadro 400
Post by olivier » 10 Mar 2018, 20:22
Exact, USB 3.0 do not appear but are fully functionnal!
Concerning, CPU, I don't have such a text file (plist) in the directory you mentioned.
It is not written the same way (it's a block text)
What should I do then?
SAS Drive is still orange (?)
You are making miracles :-) thank you MaLdOn :-)
Post by MaLd0n » 10 Mar 2018, 21:02
olivier wrote:Exact, USB 3.0 do not appear but are fully functionnal!
CPU
run in terminal
and edit file, if u use system in other Language, need edit correct file
SAS
idk about it, we need check xD
olivier
CPU: 2xXeon E5 2670
GPU: Quadro 400
Post by olivier » 10 Mar 2018, 22:06
It worked for the CPUs ;-)
Thank you again, and let's see later for CPUPM :D :D
Good job MaLdOn!
Post by MaLd0n » 10 Mar 2018, 22:39
olivier wrote:It worked for the CPUs ;-)
Good job MaLdOn!
Welcome, bro!
Enjoy!
olivier
CPU: 2xXeon E5 2670
GPU: Quadro 400
Post by olivier » 12 Mar 2018, 22:11
Hi MaLdOn,
I've just added a D-Link DWA547 pic wifi card.
It worked once, but after reboot doesn't work anymore.
Do I need a DSDT patch or a kext?
Thanks again :D
Here is my new dump:
Moreover, I am learning how to patch for CPUPM...
I will try. If I have doubts, I will call you :)
Post by MaLd0n » 12 Mar 2018, 22:14
olivier wrote:Hi MaLdOn,
Thanks again :D
u need a kext xD
olivier
CPU: 2xXeon E5 2670
GPU: Quadro 400
Post by olivier » 12 Mar 2018, 23:11
OK, I will search tomorrow...
WIFI Airport detected but "no hardware installed"
Post by MaLd0n » 12 Mar 2018, 23:17
olivier wrote:OK, I will search tomorrow...
what chipset this card have?
olivier
CPU: 2xXeon E5 2670
GPU: Quadro 400
Post by olivier » 13 Mar 2018, 14:03
Atheros
AR5416-AC1A
T721884. 1C
0739
CHINA
DWA-547A1 REV:A2
It is actually unstable (sometimes works, sometimes not detected, sometimes KP)
Post by MaLd0n » 13 Mar 2018, 14:28
olivier wrote:Atheros
AR5416-AC1A
T721884. 1C
0739
CHINA
DWA-547A1 REV:A2
use dpci manager and check in PCI LIST
diegosantanamelo
CPU: Intel Core i7-4510U
Motherboard: Dell Vostro 5470
GPU: Intel HD4400
Post by diegosantanamelo » 19 Mar 2018, 02:30
Não consigo baixar a pasta Clover.zip.
Post by MaLd0n » 19 Mar 2018, 16:54
19 Mar 2018, 02:30
tenta novamente, está fazendo download normalmente
asapreta
Re: Sierra/HighSierra em Mobos séries 5, 6, 7, 8, 9, 10, 20 e 30
Post by asapreta » 25 Mar 2018, 16:48
Pessoal bom dia.
Estou já a um tempo sem instalar nada de Hackintosh.
Eu parei no El Capitain e lembro que o último problema que deu, que foi corrigido na época para a minha máquina foi a forma que eram identificadas as USBs.
Eu tive uns problemas de MoBo mas agora estou com o mesmo setup de antes e quero voltar a atualizar o sistema.
Eu sempre faço um fresh install num HD zerado.
Mas me recordo que passei a optar em não usar um pendrive de boot e fazia numa segunda partição do mesmo HD que eu ia instalar o MacOS, criava essa partição com 16-20 Gb e fazia toda aquela coisa de puxar a pasta do instalador, copiar as outras pastas e tal e colocar o clover nela para dar o boot + o fakesmc e talvez, se nao me engano, o NullPowerManagement.kext.
Li o primeiro post desse tópico e vi que parece que as coisas mudaram, essa imagem Olarila já vem pronta para install precisando colocar o DSDT que será editado pós rodar o RunMe.app e o Clover? Fiquei meio perdido nessa.
Obrigado e continuem o ótimo trabalho.
Return to “Guias de instalação”
