aryaone
CPU: Intel core i3-8100
Motherboard: gigabyte B360M
GPU: RX 570
Post by aryaone » 31 Aug 2019, 23:21
31 Aug 2019, 16:39
I personally avoid installing third party kexts in L/E. Moreover, in BOTH locations for same kexts.
What is your plist setting for "Inject Kext"?
If you still keep kexts in L/E, the setting should be set as "Detect" if my memory still serves me well.
before, my default setting is "detect"
but since my laptop only can "booting with injected kext" on clover, i change the setting to "yes"
so, should i remove the same kext on L/E, since i already placed the same ones on clover?
onemanosx
Post by onemanosx » 31 Aug 2019, 23:29
31 Aug 2019, 23:21
Its the most preferred way to remove 3rd party kexts from L/E.
Once kexts are removed from L/E, rebuild cache & permissions or run kext utility app before rebooting. Else, you will face kernel panic. ;)
Added in 43 minutes 4 seconds:
31 Aug 2019, 21:26
Here is fresh extracted
Make a backup of your EFI folder. Then, boot only with attached plist and DSDT. Remove all other SSDT and DSDT in patched folder.
Extract new sendme.
Archive.zip
MSI B360 Gaming Arctic
aryaone
GPU: RX 570
Post by aryaone » 01 Sep 2019, 02:21
01 Sep 2019, 00:12
i already remove third party kext from L/E, rebuild cache, than rebooting normally, still the sound not work
i forgot to say that i used new config.plist (from rehabman intel h620 config) because previous config.list seems not work with virtualsmc
can you check my config.plist? may be something work with audio device
here is my sendme file
Send me aryaones-MacBook-Pro.zip
onemanosx
Post by onemanosx » 01 Sep 2019, 03:02
aryaone, Remove VoodooHDA kext. AppleALC kext + correct layout id is a better option for most cases.
Note: Ensure that you have untouched or unmodified AppleHDA kext when using AppleALC.
On a I2C related note, your trackpad is running on polling mode. Implement interrupt mode which is more desirable.
gish94
CPU: e8400
Motherboard: p5q3
GPU: gt 8500
Post by gish94 » 01 Sep 2019, 03:35
new Send me
onemanosx
Post by onemanosx » 01 Sep 2019, 03:38
gish94, You did not boot with my files [Local Link Removed for Guests]
gish94
CPU: e8400
Motherboard: p5q3
GPU: gt 8500
Post by gish94 » 01 Sep 2019, 03:44
01 Sep 2019, 03:38
sorry didn't get it, just booted with your files, and again my keyboard stoped working. Can't do anything without keyboard, I have no USB keyboard right now.
onemanosx
Post by onemanosx » 01 Sep 2019, 03:49
01 Sep 2019, 03:44
Thats too bad.
Can you try boot my DSDT with this plist?
config.plist.zip
gish94
CPU: e8400
Motherboard: p5q3
GPU: gt 8500
Post by gish94 » 01 Sep 2019, 04:40
01 Sep 2019, 03:49
Still no keyboard and touchpad :(
onemanosx
Post by onemanosx » 01 Sep 2019, 05:01
gish94, I am narrowing down to the keyboard issue before proceeding further.
Can you try these files?
Archive.zip
If you can join me at my Gitter chat, our conversation will be real time. Click the chat link under my signature.
gish94
CPU: e8400
Motherboard: p5q3
GPU: gt 8500
Post by gish94 » 01 Sep 2019, 05:17
01 Sep 2019, 05:01
Joined
aryaone
GPU: RX 570
Post by aryaone » 01 Sep 2019, 05:20
01 Sep 2019, 03:02
okay, i will remove voodooHDA, and copy the original appleHDA.kext from installer to make sure.
i2c trackpad and touchscreen already working well since i used smcbatterymanagement kext. before i already try your modified DSDT that implement interrupt mode, but still jumpy with acpibatterymanagement
onemanosx
Post by onemanosx » 01 Sep 2019, 07:21
gish94, This is the first time I try to work with a XiaoMi notebook. Very strange config, but I am glad we managed to get it to work.
#ELAN2301
kernel: (VoodooGPIO) VoodooGPIOSunrisePointLP::Loading GPIO Data for SunrisePoint-LP
kernel: (VoodooGPIO) VoodooGPIOSunrisePointLP::VoodooGPIO Init!
kernel: (VoodooGPIO) VoodooGPIOSunrisePointLP::VoodooGPIO Initializing Community 0
kernel: (VoodooGPIO) VoodooGPIOSunrisePointLP::VoodooGPIO Initializing Community 1
kernel: (VoodooGPIO) VoodooGPIOSunrisePointLP::VoodooGPIO Initializing Community 2
kernel: (VoodooGPIO) VoodooGPIOSunrisePointLP::GPIO Controller is already awake! Not reinitializing.
kernel: (VoodooI2C) VoodooI2CPCIController::pci8086,9d60 Starting I2C controller
kernel: (VoodooI2C) VoodooI2CPCIController::pci8086,9d60 Set PCI power state D0
kernel: (VoodooI2C) VoodooI2CPCIController::pci8086,9d60 Publishing nub
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,9d60 Probing controller
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,9d60 Found valid Synopsys component, continuing with initialisation
kernel: (VoodooI2C) VoodooI2CControllerNub::pci8086,9d60 SSCN not implemented in ACPI tables
kernel: (VoodooI2C) VoodooI2CControllerNub::pci8086,9d60 FMCN not implemented in ACPI tables
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,9d60 Warning: Error getting bus config, using defaults where necessary
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,9d60 Publishing device nubs
kernel: (VoodooI2C) VoodooI2CPCIController::pci8086,9d61 Starting I2C controller
kernel: (VoodooI2C) VoodooI2CPCIController::pci8086,9d61 Set PCI power state D0
kernel: (VoodooI2C) VoodooI2CPCIController::pci8086,9d61 Publishing nub
kernel: (IOPlatformPluginFamily) Generation from SMC report as 2
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,9d61 Probing controller
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,9d61 Found valid Synopsys component, continuing with initialisation
kernel: (VoodooI2C) VoodooI2CControllerNub::pci8086,9d61 SSCN not implemented in ACPI tables
kernel: (VoodooI2C) VoodooI2CControllerNub::pci8086,9d61 FMCN not implemented in ACPI tables
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,9d61 Warning: Error getting bus config, using defaults where necessary
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,9d61 Publishing device nubs
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,9d61 Found I2C device: ELAN2301
kernel: (VoodooI2C) VoodooI2CControllerDriver::VoodooI2CDeviceNub Warning: Incompatible APIC interrupt pin (0x33 > 0x2f) and no GPIO interrupts found; if your chosen satellite implements polling then VoodooI2CDeviceNub will run in polling mode.
kernel: (VoodooI2CHID) VoodooI2CPrecisionTouchpadHIDEventDriver::ELAN2301 Putting device into Precision Touchpad Mode
Added in 8 minutes 35 seconds:
01 Sep 2019, 05:20
But now you are using SMCBatteryManager ;)
iki
CPU: intel
Motherboard: lenovo ideapad 320
GPU: intel
Post by iki » 06 Sep 2019, 15:40
hey bro , I got a new laptop for my friend same as mine , lenovoideapad 320 and I copied the refi from my laptop to his , all working fine except the mouse , can u please help me , that's my send ME
onemanosx
Post by onemanosx » 06 Sep 2019, 18:38
iki, Remove VoodooI2CHID and VoodooI2CELAN. Use VoodooI2CSynaptics
VoodooI2CSynaptics.kext.zip
iki
CPU: intel
GPU: intel
Post by iki » 06 Sep 2019, 19:29
06 Sep 2019, 18:38
thank you , its working now <3 , one more question if u can help me with , there is not display option in the keyboard shortcut to make my brightness more or less , so i cant make a shortcut for it , any suggestions ?
onemanosx
Post by onemanosx » 07 Sep 2019, 07:50
06 Sep 2019, 19:29
You can change the button assignment at preferences.
iki
CPU: intel
GPU: intel
Post by iki » 07 Sep 2019, 12:40
07 Sep 2019, 07:50
i dont have this option in my preferences
onemanosx
Post by onemanosx » 07 Sep 2019, 12:50
07 Sep 2019, 12:40
I dont have any suggestion other than this :)
iki
CPU: intel
GPU: intel
Post by iki » 11 Sep 2019, 10:51
hey man , i was removing windows and i accidentally removed EFI with it , i copied my backup one with the kext u told me about but the mouse is not working , here is my send-me
Return to “Laptop”
