neverday
CPU: I5 6600K
Motherboard: Asus Maximus VIII Ranger
GPU: RX 580 8GB
Post by neverday » 10 Aug 2019, 16:35
onemanosx ,trackpad Enabled! thank you.. :guitar :crazy:
Lenovo IdeaPad 320 15IKB
onemanosx
Post by onemanosx » 10 Aug 2019, 16:36
10 Aug 2019, 16:35
Awesome! :guitar :mrgreen:
MSI B360 Gaming Arctic
Toddynho
Geek
Geek
CPU: Intel Core i5 7200U 2.5 Ghz
Motherboard: Dell Inspiron 5468
GPU: Intel HD Graphics 620
Post by Toddynho » 10 Aug 2019, 23:28
26 Jul 2019, 09:05
Toddynho, Try. If not succeed, upload new sendme.
After removing voodoops2controller plugins, your track pad is working in polling mode using voodooI2C controller.
(kernel) VoodooGPIOSunrisePointH::Loading GPIO Data for SunrisePoint-H
(kernel) VoodooGPIOSunrisePointH::VoodooGPIO Init!
(kernel) VoodooGPIOSunrisePointH::VoodooGPIO Initializing Community 0
(kernel) VoodooGPIOSunrisePointH::VoodooGPIO Initializing Community 1
(kernel) VoodooGPIOSunrisePointH::VoodooGPIO Initializing Community 2
(kernel) VoodooGPIOSunrisePointH::GPIO Controller is already awake! Not reinitializing.
(kernel) VoodooI2CPCIController::pci8086,a161 Starting I2C controller
(kernel) VoodooI2CPCIController::pci8086,a160 Starting I2C controller
(kernel) VoodooI2CPCIController::pci8086,a161 Set PCI power state D0
(kernel) VoodooI2CPCIController::pci8086,a161 Publishing nub
(kernel) VoodooI2CPCIController::pci8086,a160 Set PCI power state D0
(kernel) VoodooI2CPCIController::pci8086,a160 Publishing nub
(kernel) VoodooI2CControllerDriver::pci8086,a160 Probing controller
(kernel) VoodooI2CControllerDriver::pci8086,a160 Found valid Synopsys component, continuing with initialisation
(kernel) VoodooI2CControllerDriver::pci8086,a161 Probing controller
(kernel) VoodooI2CControllerDriver::pci8086,a161 Found valid Synopsys component, continuing with initialisation
(kernel) VoodooI2CControllerNub::pci8086,a160 SSCN not implemented in ACPI tables
(kernel) VoodooI2CControllerNub::pci8086,a160 FMCN not implemented in ACPI tables
(kernel) VoodooI2CControllerDriver::pci8086,a160 Warning: Error getting bus config, using defaults where necessary
(kernel) VoodooI2CControllerDriver::pci8086,a160 Publishing device nubs
(kernel) VoodooI2CControllerDriver::pci8086,a161 Got bus configuration values
(kernel) VoodooI2CControllerDriver::pci8086,a161 Publishing device nubs
(kernel) VoodooI2CControllerDriver::pci8086,a161 Found I2C device: ELAN1000
(kernel) VoodooI2CControllerDriver::VoodooI2CDeviceNub Warning: Incompatible APIC interrupt pin (0x5f > 0x2f) and no GPIO interrupts found; if your chosen satellite implements polling then VoodooI2CDeviceNub will run in polling mode.
Before, it was using voodoops2 controller. Which probably explains why the pointer is running around
(kernel) VoodooPS2SynapticsTouchPad: Version 1.8.34 starting on OS X Darwin 18.6.
(kernel) VoodooPS2Mouse: Version 1.8.34 starting on OS X Darwin 18.6.
(kernel) VoodooPS2Trackpad starting: Synaptics TouchPad reports type 0x47, version 8.2
Hi, I was using hackintosh and unfortunately had a problem with the hard drive I needed to change. Then I followed the same steps and added all the edited kexts and DSDT to the touchpad operation. I noticed the permissions but unfortunately everything is as before and it is not working.
OS: macOS 10.14.6 (18G95) - Notebook Dell Inspiron 5468 - Processador: i5 7200U 2.5ghz - Mem: 8 GB DDR4 - SSD: 120 GB - Rede: Realtek RTL8102E - Vídeo: Intel HD 620 - WiFi: Atheros9565 (Funcionando)
Post by MaLd0n » 11 Aug 2019, 00:10
Toddynho, rebuild
Kernel and Kexts Cache.command.zip
Toddynho
Geek
Geek
Post by Toddynho » 11 Aug 2019, 01:04
11 Aug 2019, 00:10
Toddynho, rebuild
reparei as permissões e seguir os mesmos passos que o onemanosx indicou, e o mouse parou e inclusive ele fez uma correção na DSDT para esse touchPad que da ultima vez funcionou só que agora não esta mais a funcionar.
onemanosx
Post by onemanosx » 11 Aug 2019, 10:36
03 Aug 2019, 17:03
The touchpad worked fine, but the settings do not open
Replace VoodooI2CHID with VoodooI2CSynaptics
VoodooI2CSynaptics.kext.zip
Rebuild kext cache and reboot.
Added in 7 minutes 56 seconds:
10 Aug 2019, 23:28
Replace Clover folder
CLOVER.zip
janjao
CPU: i3 6100
Motherboard: gigabyte H110M
GPU: GT 710
Post by janjao » 17 Aug 2019, 13:46
Hi, touchpad working in interrupt mode, but sometimes it gets some stuttering, especially when i click. is there anything to do for improvement?
onemanosx
Post by onemanosx » 18 Aug 2019, 03:05
17 Aug 2019, 13:46
Try asking the Devs at their gitter page. Some ASUS board has buggy GPI0, so interrupt mode is problematic for those machines.
aryaone
CPU: Intel core i3-8100
Motherboard: gigabyte B360M
GPU: RX 570
Post by aryaone » 26 Aug 2019, 14:30
onemanosx, please help me, i'm going to give up to make my trackpad working, my dsdt already patched by mald0n after i install mojave, then i try to follow your tutorial but unable to apply windows patch on dsdt.
here is my dump file, thank you for your help
Send me LONEXTs-MacBook-Pro.zip
onemanosx
Post by onemanosx » 26 Aug 2019, 14:40
aryaone, Just use a Maldon's DSDT. You dont need any other SSDT or clover patches.
Reboot and extract new sendme files
aryaone
GPU: RX 570
Post by aryaone » 27 Aug 2019, 00:41
onemanosx, okay, i will try and send to you ASAP
----update------
amazing onemanosx, after follow your guide, now my touchpad and even may touchscreen are working like a charm :guitar
now, the bugs that remain :
- brightness control (minimal brightness will turn off the screen, step 1 will give about 75% brightness)
- trackpad movement a bit laggy (not smooth)
here is my sendme file
onemanosx
Post by onemanosx » 27 Aug 2019, 11:31
27 Aug 2019, 00:41
Glad that helps!
However, You did not disable the SSDT's I had mentioned as they are still loaded into the system. You should remove all the SSDTs and only use DSDT which Maldon had patched. I also have no idea which config.plist that you use to boot up and create the latest sendme files.
You should also remove these highlighted kexts as I see that your system do not need it.
You can try VirtualSMC + SMCBatteryManager (instead of fakesmc +acpibatterymanager kext) and see if that improves your track pad experience.
Send me another sendme files with the above advise.
aryaone
GPU: RX 570
Post by aryaone » 28 Aug 2019, 12:16
onemanosx, sorry it seems i sent the wrong file yesterday,
i still use appleBackLightFixup.kext and SSDT-PLNF to make my fix my screen brightness
i already tried to use virtualsmc instead of fakesmc, but that makes me stuck on boot with "AppleLMUController::start Error: Could not get SMCProvider"
here is my sendme file when using fakesmc
onemanosx
Post by onemanosx » 28 Aug 2019, 12:32
aryaone,
1. SSDT-PNLF is not required as your DSDT is already patched with it.
2. AppleBacklightFixup kext is not required as Whatevergreen kext is taking care of it now.
3. You might need to rebuild kext cache and permissions when first time booting with VirtualSMC from fakesmc.
However, try boot with this DSDT that allows interrupt mode for track pad. Lets see if the track pad performs better.
Thelion
CPU: Intel i3 3217
GPU: Intel HD 4000
Post by Thelion » 29 Aug 2019, 06:23
Can anyone help me touchpad not work after update to mojave
onemanosx
Post by onemanosx » 29 Aug 2019, 06:56
29 Aug 2019, 06:23
Rebuild kext cache and permissions [Local Link Removed for Guests]
Thelion
CPU: Intel i3 3217
GPU: Intel HD 4000
Post by Thelion » 29 Aug 2019, 07:08
not worked sir
onemanosx
Post by onemanosx » 29 Aug 2019, 07:12
Thelion, run the command and reboot.
Thelion
CPU: Intel i3 3217
GPU: Intel HD 4000
Post by Thelion » 29 Aug 2019, 07:14
not worked
onemanosx
Post by onemanosx » 29 Aug 2019, 07:30
Thelion, extract sendme files
Return to “Laptop”
