onemanosx
Post by onemanosx » 24 Dec 2018, 10:55
Update: My trackpad now works with latest release! [Local Link Removed for Guests]
This post is not meant to be a guide. Instead, I hope this thread is able to gather all VoodooI2C kext users to share their knowledge and new users to be able to activate their I2C track pads. This write up is a simplified version of the original to benefit new hackintoshers. It is always advised to read the actual documentation by the developer in case I had missed out important key points.
Another note, users are urged to participate in developer's gitter chat for better support or report major issues. And you are expected to had done the preliminary steps mentioned below. I would like to point out again that this is not an official VoodooI2C help page.
IMPORTANT: Ensure 'Disable built-in trackpad when...' is disabled within accessibility preferences
IMPORTANT 2: Enable advanced option for trackpad in bios if option is available.
IMPORTANT 3: Delete Trackpad and Mouse plugin from within VoodooPS2Controller kext to avoid conflict. We only need the keyboard plugin. Except in certain scenarios where touch screen is an I2C device and trackpad is a PS2, then do not remove the plugin.
IMPORTANT 4: Disable _DSM to XDSM/ZDSM patches. This is one of the common mistakes found from most new users. DO NOT USE THESE PATCHES.
IMPORTANT 5: Disable Apple's I2C Kext to patch
Include this patch in kext to patch.
<key>KextsToPatch</key>
		<array>
			<dict>
				<key>Comment</key>
				<string>Prevent Apple I2C kexts from attaching to I2C controllers, credit CoolStar</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				SU9LaXQ=
				</data>
				<key>InfoPlistPatch</key>
				<true/>
				<key>Name</key>
				<string>com.apple.driver.AppleIntelLpssI2C</string>
				<key>Replace</key>
				<data>
				SU9LaXM=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				SU9LaXQ=
				</data>
				<true/>
				<key>Name</key>
				<string>com.apple.driver.AppleIntelLpssI2CController</string>
				<key>Replace</key>
				<data>
				SU9LaXM=
				</data>
			</dict>
		</array>
	</dict>
Or, if you are using plist editor/ xcode/ clover configurator. Refer to the the screenshot below.
Plist Editor/Xcode
Clover Configurator
OPTIONAL:
In the past, track pad tends to be disabled after every OS update and a simple rebuild of kext cache then rebooting will solve that minor issue. However, adding these in config.plist force loads trackpad without rebuilding kext cache (I'd recommend to still do a rebuild, anyway ;) )
<key>ForceKextsToLoad</key>
<array>
<string>\System\Library\Extensions\IOGraphicsFamily.kext</string>
</array>
This is the official VoodooI2C gitter chat
It is also a known issue (at least in my knowledge at this point of writing) that certain version of kexts are not compatible with some devices and may involve some trial and error of different releases of kexts.
*Note: You must not have any other I2C kexts installed except for VoodooI2C kexts.
The following device classes are fully supported:
- I2C-HID devices
- ELAN devices
- FTE devices
Before posting for help and attaching send me files, new users are advised to take the below steps which are crucial. These preliminary steps are also outlined by the original dev in his wiki guide.
Also, before using Run_me app, make sure you boot from your SSD/HDD clover and NOT from USB bootable disk!
VoodooI2C Dev guide can be read [External Link Removed for Guests].
Basically, we are required to know these 3 main items
1. ACPI ID
2. APIC Pin Number
3. Ensure I2C Serial bus name are correctly labelled in DSDT.
Below are the steps on how to achieve the 3 criteria mentioned above.
Step 1 - Identify ACPI ID or GPIO pinning
If you have windows installed in another partition or drive, use Windows Device Manager to locate your device's ACPI ID like shown in the picture below.
In this example, the ACPI ID is TPL0
If you do not have windows installed, dont worry, continue to follow the step below
Step 2. Determining your interrupt pinning situation/ APIC pin number
a. First compile your DSDT by simply pressing F4 at clover boot. The file will be available at Clover/ACPI/Origin
b. Patch your DSDT with windows patch script below using MaciASL
into_all method code_regex If\s+\([\\]?_OSI\s+\(\"Windows\s2015\"\)\) replace_matched begin If(LOr(_OSI("Darwin"),_OSI("Windows 2015"))) end;
c. Place the patched DSDT into your clover/ACPI/patched folder. Reboot.
d. Use IOREG to find your ACPI ID like below picture
In this example, the ACPI ID is TPD1.
Click on IOInterruptSpecifiers to reveal the hexadecimal APIC pin number. In this example the APIC pin number is 0x33. If we convert 0x33 to decimal, it will be 51.
If your APIC pin number is equal or less than 47, you can proceed to install kexts.
If you do not have IOInterruptSpecifiers, you can also proceed to install kexts.
Download latest kexts [External Link Removed for Guests]
Always install 3rd party kexts in Clover/kexts/other.
Step 3. Ensure I2C Serial bus name is correctly labelled
You will also need to make sure that your I2C Serial Bus Name is correctly labelled. Search for your device ACPI ID in your DSDT until you reach its device entry, you should be able to find a Name called SBFB. If you cannot find it, you may find something that looks like this instead:
Method (_CRS, 0, Serialized)  // _CRS: Current Resource Settings
                    Name (SBFI, ResourceTemplate ()
                        I2cSerialBusV2 (0x0015, ControllerInitiated, 0x00061A80,
                            AddressingMode7Bit, "\\_SB.PCI0.I2C1",
                            0x00, ResourceConsumer, , Exclusive,
                        Interrupt (ResourceConsumer, Level, ActiveLow, Exclusive, ,, )
                            0x0000006D,
                    Return (SBFI)
In this case, rename SBFI to SBFB and remove the following from it:
        0x0000006D,
But, what if your APIC pin number is greater than 47?
to be continued..
Note: All guide and thanks to the hardwork of original developer whom can be contacted at [External Link Removed for Guests]
Intel i7-6700HQ, 8GB RAM (UEFI Clover Mojave)
MSI B360 Gaming Arctic
Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Mojave)
onemanosx
Post by onemanosx » 24 Dec 2018, 11:04
I2C device with APIC Pin Number greater than hex 0x2f (or decimal 47)
In post 1, I describe the procedure or implementation for I2C device with APIC Pin Number less than or equal to 0x2f (HEX). Let us now proceed for devices with APIC Pin Number GREATER than 0x2f.
1. Open DSDT and find the below SBFG Name
Name (SBFG, ResourceTemplate ()
        GpioInt (Level, ActiveLow, ExclusiveAndWake, PullDefault, 0x0000,
            "\\_SB.PCI0.GPI0", 0x00, ResourceConsumer, ,
            {   // Pin list
                0x0000
If you are not able to find the code above in your DSDT, then you will need to add in manually. Thus, after manually adding the code in the DSDT, we will now need to define a proper pin.
Manually pinning a device
As an example, we will use the hexadecimal APIC Pin number of 0x33 (i.e decimal 51)
a. Go to this [External Link Removed for Guests]
b. Look for hexadecimal 0x33 in the table and take note of the IRQ table on the left pane. Here, 0x33 corresponds to #define GPP_B3_IRQ
c. Then we will go to this [External Link Removed for Guests]
Here we will find the corresponding decimal digit for #define GPP_B3_IRQ which is 27
If we convert decimal 27 into HEX, we will get 0x1B. This is our pin! Hence, our code will now look like this in the DSDT.
            {   // Pin list
                0x1B
Finally, the last step will be ensuring that the device is well pinned by checking _CRS method in DSDT so that it returns as
Return (ConcatenateResTemplate (SBFB, SBFG))
In my case originally _CRS looks like this
Method (_CRS, 0, NotSerialized)  // _CRS: Current Resource Settings
                If ((OSYS < 0x07DC))
                    Return (SBFI)
                If ((SDM1 == Zero))
                Return (ConcatenateResTemplate (SBFB, SBFI))
This is how it looks like eventually.
                    Return (SBFI)
                If ((SDM1 == Zero))
We can now install our kexts and test if our trackpad is working!
The above procedure describes if SBFG Name is not found in DSDT. So, what shall we do if SBFG Name exists? In this instance, we will just need to ensure that Method _CRS will return as
And we can proceed to install our kexts and reboot!
Finding a usable pin as described in the example above is when GPI0 is "SunrisepointLP".
Look down the list below for other GPI0 names.
For CannonPointLP:
The IRQ table is [External Link Removed for Guests]
And the second reference table for CannonPointLP is [External Link Removed for Guests]
For CannonPoint_H:
And second reference table for CannonPoint-H is [External Link Removed for Guests]
GPI0 with multiple communities
On newer chipsets (Cannon Point and newer), there is a mismatch between the GPIO pin and the hardware pin number. If you are using such hardware, you will need to convert the hardware pin number you have found to a GPIO pin, to allow the driver to use the pin.
For CannonPointLP is [External Link Removed for Guests]
For CannonPoint-H is [External Link Removed for Guests]
The pin calculation for GPI0 with multiple communities is different from the "older" chip sets but here is the quote from dev site. Its actually quite simple. ;)
GPIO pins are divided to multiple communities, containing multiple GPPs each. During the mapping from an APIC pin to a GPIO pin you have found a label in the form GPP_XYY_IRQ, or GPP_XYY. X is the GPP identifier you are looking for. Find the GPP of the pin you have found in one of the communities in the link. A GPP will have the form CHIPSET_GPP(num, base, end, gpio_base), /* GPP_X */. To convert your hardware pin to a usable GPIO pin, take the decimal GPIO pin number you have found, subtract the base, then add the gpio_base. The result is your GPIO pin number. Notice a gpio_base of X_NO_GPIO means this pin is not valid for use.
Convert this to a hexadecimal number, this is your hexadecimal GPIO pin. You may notice that your hexadecimal APIC pin appears multiple times in the first list mentioned above. You will need to repeat the lookup process for all occurences of your hexadecimal APIC pin to obtain all possible hexadecimal GPIO pins. You will then need to test all of them to see which one works.
EXAMPLE
As an example, say we have APIC pin of 0x5F for CannonPointH. Looking through the table [External Link Removed for Guests] we have three IRQ values i.e
GPP_C23
GPP_H23
GPP_K23
Next we go to the second reference table for CannonPointH [External Link Removed for Guests]
And we find these pins in Decimal
GPP_C23 > 74
GPP_H23 > 202
GPP_K23 > 178
Finally, we go to the third table for CannonPointH [External Link Removed for Guests]. And the pin calculation is as per illustrated below:
CNL_GPP(0, 51, 74, 64),
74 - 51 + 64 = 87 = 0x0057
CNL_GPP(0, 155, 178, 192)
178-155+192= 215 = 0x00D7
CNL_GPP(1, 179, 202, 224)
202-179+224= 247 = 0x00F7
So, we have 3 GPI0 pins to test with and hopefully one of the pins will work for interrupt mode.
Note that (in very rare cases), the corresponding GPIO hexadecimal pin will not work. In this case, you can try some of the common values such as 0x17, 0x1B, 0x34 and 0x55.
That is all!
:guitar :guitar :cap :cap
onemanosx
Post by onemanosx » 24 Dec 2018, 13:18
imran.sefat,
Boot with attached clover folder and run [Local Link Removed for Guests]
Imran-CLOVER.zip
Added in 22 minutes 7 seconds:
sarakabir,
Your SSDT-ELAN refers to the wrong I2C device. Your I2C device is TPD0 and not ETPD
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 24 Dec 2018, 15:00
Could you please upload latest voodooi2c commits ?
Tried with lilu and friends but gives error.
onemanosx
Post by onemanosx » 24 Dec 2018, 15:08
24 Dec 2018, 15:00
I use officially released kexts from dev
erroruser
CPU: i9 9900k
Motherboard: asus z390-a
GPU: rx 590
Post by erroruser » 24 Dec 2018, 15:18
onemanosx, :guitar :guitar :guitar
Asus z390-A, i9 9900k, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, sapphire rx 590, fractal celcius s36
:superman :superman
onemanosx
Post by onemanosx » 24 Dec 2018, 15:28
erroruser, :ugeek: :guitar
imran.sefat
CPU: i5 7300HQ
Motherboard: Acer Nitro 5
GPU: 1050ti
Post by imran.sefat » 24 Dec 2018, 20:59
24 Dec 2018, 13:40
imran.sefat,
Imran-CLOVER.zip
sarakabir,
onemanosx,
The trackpad is working now but the sound isn't working after replacing clover folder,
I already changed the layout id but it didn't work. previously layout 17 worked for me but now the sound isn't working in layout 3, 13, 17, 18, 27, 28, 99
onemanosx
Post by onemanosx » 24 Dec 2018, 22:54
imran.sefat,
try
imran.sefat
CPU: i5 7300HQ
GPU: 1050ti
Post by imran.sefat » 25 Dec 2018, 05:33
24 Dec 2018, 22:54
imran.sefat,
try DSDT.aml.zip
all things are working perfectly thanks a lot! I just needed to boot from hdd that solved the sound problem!
onemanosx
Post by onemanosx » 25 Dec 2018, 07:01
25 Dec 2018, 05:33
:guitar :guitar :guitar :cap
Sampath007
CPU: i7-8550u
Motherboard: Acer Nitro 515-31
GPU: UHD 620
Post by Sampath007 » 25 Dec 2018, 07:26
Awesome work bro :guitar :meeting
onemanosx
Post by onemanosx » 25 Dec 2018, 07:30
25 Dec 2018, 07:26
Awesome work bro
I merely simplify the Dev's original guide so new hackintoshers can understand and follow easily :mrgreen:
imran.sefat
CPU: i5 7300HQ
GPU: 1050ti
Post by imran.sefat » 25 Dec 2018, 18:58
25 Dec 2018, 07:01
please help! :cry: :cry:
I fully installed Mojave using the olarilla image and the clover folder that you gave me with apfs format and replaced the clover folder in my hdd
now I'm facing some problems
1. Sound is not working
2. keyboard and trackpad is working fine but in trackpad option in system preference showing looking for bluetooth trackpad
3. battery percentage is not showing
4. when I turned on the option to show brightness option in menu bar, it doesn't work
onemanosx
Post by onemanosx » 25 Dec 2018, 23:11
imran.sefat,
Replace DSDT in patched folder, reboot and check track pad setting.
imran.sefat
CPU: i5 7300HQ
GPU: 1050ti
Post by imran.sefat » 26 Dec 2018, 02:40
25 Dec 2018, 23:11
imran.sefat,
not working man! :( attached another send me file after replacing the patch file
onemanosx
Post by onemanosx » 26 Dec 2018, 02:50
imran.sefat, consider to post your issues at VoodooI2c github chat.
imran.sefat
CPU: i5 7300HQ
GPU: 1050ti
Post by imran.sefat » 26 Dec 2018, 04:42
26 Dec 2018, 02:50
what should I do about the other problems ? can you please help me out ? sound isn't working either
onemanosx
Post by onemanosx » 26 Dec 2018, 04:46
26 Dec 2018, 04:42
create new post. This thread is for I2C trackpad only
imran.sefat
CPU: i5 7300HQ
GPU: 1050ti
Post by imran.sefat » 26 Dec 2018, 04:57
26 Dec 2018, 04:46
trackpad option came after installing ACPI battery manager kext
Return to “Laptop”
