Asus G73Sw
andrizmitnick
CPU: Intel Core i7 2630
Motherboard: ASUS G73SW Motherboard
GPU: Nvidia GTX 460M
Re: Asus G73Sw
Post by andrizmitnick » 12 Feb 2017, 09:31
oldnapalm wrote:I got Sierra running on it, had to delete the Devices and Graphics sections from config.plist
	<key>Devices</key>
	<dict>
		<key>Inject</key>
		<true/>
		<key>Properties</key>
		<string>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</string>
	</dict>
	<key>Graphics</key>
	<dict>
		<key>Inject</key>
		<false/>
	</dict>
would you mind to share a short step by step guide? what method you use to get sierra? also what boot args you use, some modified config file, maybe modified dsdt? I had kernel panic at apple boot logo after installation finishes, seems to be kext/kernel issue. I use direct update method from tony forum. btw thanks before
oldnapalm
Re: Asus G73Sw
Post by oldnapalm » 12 Feb 2017, 19:22
I used the image from this topic
Same files as for El Capitan from [Local Link Removed for Guests] with the changes in the post you quoted.
andrizmitnick
Re: Asus G73Sw
Post by andrizmitnick » 13 Feb 2017, 12:16
oldnapalm wrote:I used the image from this topic
thanks, after 12 hours of workaround, finally it's working good. just need some optimizing. do you think I need to use nvidia web driver for performance stability? oh yea, also I don't need nullcpupower kext anymore ight? since I use your dsdt.
I forgot to mention, would you mind to share a geekbench result of your g73sw to compare with mine? so that I can see if I my cpu is already well configured or not
oldnapalm
Re: Asus G73Sw
Post by oldnapalm » 13 Feb 2017, 12:20
I didn't try the web drivers.
You don't need NullCPU but the DSDT isn't enough, you need AsusAICPUPM=True in Clover config as for Yosemite.
andrizmitnick
Re: Asus G73Sw
Post by andrizmitnick » 13 Feb 2017, 12:46
oldnapalm wrote:I didn't try the web drivers.
last question, is it fine if I update to 10.12.3 via App Store? is there any additional step or I can just do it right away?
btw so much thanks, I wouldn't get into Sierra without you xD
oldnapalm
Re: Asus G73Sw
Post by oldnapalm » 13 Feb 2017, 17:14
You can update via App Store, you will just need to re-patch AppleGraphicsDevicePolicy, or you can try this
andrizmitnick
Re: Asus G73Sw
Post by andrizmitnick » 13 Feb 2017, 20:21
oldnapalm wrote:You can update via App Store, you will just need to re-patch AppleGraphicsDevicePolicy, or you can try this
sorry for taking your time, last question. how can i fix usb3 port? if i just plug the usb 3 port it won't detected, if i try to reboot while the usb3 port still plugged in, when get inside desktop it was detected, but somehow if i try to copy/open files, it's corrupt. using usb2 is just fine, no corrupt at all. already tried to put appleusbxhcipci patch to clover but still not fixed.
sorry for my bad english, i hope you can still understand my issue xD thanksss
oldnapalm
Re: Asus G73Sw
Post by oldnapalm » 13 Feb 2017, 22:10
I didn't get USB 3.0 working. Sorry, I can't help, I'm no longer using OS X on this laptop, just installed Sierra for testing.
Re: Asus G73Sw
Post by MaLd0n » 13 Feb 2017, 22:19
send me ur clover folder
-Donated? Send me one PM-
andrizmitnick
Re: Asus G73Sw
Post by andrizmitnick » 13 Feb 2017, 23:14
MaLd0n wrote:send me ur clover folder
here is my clover folder [External Link Removed for Guests]
hope you can find a solution for my issue, thanks before
Re: Asus G73Sw
Post by MaLd0n » 13 Feb 2017, 23:58
replace folder and test
i need ioreg, extract with ioreg 3
all Fn HotKey and ALS sensor work?
andrizmitnick
Re: Asus G73Sw
Post by andrizmitnick » 14 Feb 2017, 01:01
what i should look for from IOreg? just tried replacing my clover folder, it makes my closer not working, no bootable drives showed up. luckily i had clover usb backup.
what i should change btw?
fn and als is works
Re: Asus G73Sw
Post by MaLd0n » 14 Feb 2017, 15:25
oh yes, i think u dont use uefi
use it
use ioreg 3 for extract
IORegistryExplorer 3.app.zip
Re: Asus G73Sw
Post by MaLd0n » 14 Feb 2017, 20:02
man, ur usb3 is a fresco logic. i think dont work. u can try a genericusb
oldnapalm
Re: Asus G73Sw
Post by oldnapalm » 14 Feb 2017, 20:48
It works with RehabMan-Generic-USB3-2015-1215.
It doesn't show up in system profiler but it works.
Thanks for the tip!
kajmol
Re: Asus G73Sw
Post by kajmol » 13 Sep 2017, 14:28
hi, any update for latest sierra 10.12.6 ? are kexts the same ?
thanks!
kaj
godpepe
CPU: i7 2630QM
Motherboard: H55M
GPU: GTX 460M
Re: Asus G73Sw
Post by godpepe » 19 Nov 2017, 21:42
Hi, someone can upload their Mac OS Sierra EFI file?
thanks
kajmol
Re: Asus G73Sw
Post by kajmol » 08 Mar 2018, 06:04
Hello, is anyone using high sierra? It seems to have serious problems with this notebook(graphics flickering , unstable , not possible to use it). Any suggestion? Thanks!
oldnapalm
Re: Asus G73Sw
Post by oldnapalm » 08 Mar 2018, 13:11
I'm no longer using this laptop, the video card bricked and I couldn't find a replacement at affordable price in Brazil. The latest version I used was Sierra, it was stable. I had to patch AppleGraphicsDevicePolicy to avoid black screen since 10.10 and other fixes for 10.11 and 10.12 as I posted here
kajmol
Re: Asus G73Sw
Post by kajmol » 19 Mar 2018, 18:20
hi oldnapalm, thanks. No it doesn't work unfortunately... i don't know what to try more. I stay with sierra at the moment
Return to “Laptop”
