Help with ACPI errors
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 31 May 2019, 15:49
Can someonr help me solve several acpi errors?
2019-05-31 18:22:41.149113+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149114+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149116+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [_SB_.PCI0.RP05.PXSX]
2019-05-31 18:22:41.149117+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [_SB_.PCI0.RP05.PXSX]
2019-05-31 18:22:41.149119+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Namespace lookup failure, AE_NOT_FOUND
2019-05-31 18:22:41.149829+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149830+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149832+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [_SB_.PCI0.RP09.PXSX]
2019-05-31 18:22:41.149854+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149855+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.149857+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Method parse/execution failed
2019-05-31 18:22:41.149859+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [\_SB.PCI0.RP08.PXSX] (Node ffffff8034021e40)
2019-05-31 18:22:41.149860+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [\_SB.PCI0.RP08.PXSX] (Node ffffff8034021e40)
2019-05-31 18:22:41.149862+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) , AE_NOT_FOUND
2019-05-31 18:22:41.178052+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.178054+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Cannot assign type [Device] to [Integer] (must be type Int/Str/Buf)
2019-05-31 18:22:41.178055+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Cannot assign type [Device] to [Integer] (must be type Int/Str/Buf)
2019-05-31 18:22:41.178058+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) (20160930/exstoren-203)
2019-05-31 18:22:41.178086+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.178087+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) ACPI Error:
2019-05-31 18:22:41.178088+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Method parse/execution failed
2019-05-31 18:22:41.178089+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) Method parse/execution failed
2019-05-31 18:22:41.178091+0300 0x71 Default 0x0 0 0 kernel: (AppleACPIPlatform) [\_SB.PCI0.RP15._INI] (Node ffffff8034046c30)
Post by MaLd0n » 01 Jun 2019, 01:52
mathewgx, first u need apply all patches in ssdt inside dsdt, ssdt is not a clean way, need many renames etc and some good patches don't work
-Donated? Send me one PM-
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 01 Jun 2019, 04:32
@MaLd0n,
I prefer ssdt hotpatch because I don't need to make any changes after bios update.
Do you have any idea what these acpi errors mean ?
Post by MaLd0n » 01 Jun 2019, 14:27
mathewgx, if u have a stable bios/uefi version, u don't need update every time
a full dsdt edited = 2 minutes
u need try delete entries in dsdt for solve acpi warnings and errors
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 01 Jun 2019, 14:32
I see.
If you have the time could you make a dsdt patch for me , based on runme files on first post?
Thank you again.
Post by MaLd0n » 01 Jun 2019, 14:45
mathewgx,
change GFX0 to IGPU
47465830
49475055
change HDAS to HDEF
48444153
48444546
change HECI to IMEI
48454349
494d4549
change SAT0 to SATA
53415430
53415441
mathewgx
CPU: intel
Motherboard: dell
GPU: intel
Post by mathewgx » 01 Jun 2019, 14:53
Wow !!!
Will try as soon as possible.
Just a question though. I have read that with latest whatevergreen.kext renames like GFX0 to IGPU , HDAS to HDEF and HECI to IMEI are not suggested anymore. Do you agree?
Post by MaLd0n » 01 Jun 2019, 15:56
mathewgx, we need it for renames devices in ssdts oem, same devices in ssdt and dsdt, clover rename in all tables
Return to “Laptop”
