Fujitsu Lifebook A574/H macOS Mojave
ShunWong167
CPU: i5-4300m
Motherboard: Fujitsu
GPU: HD4600
Post by ShunWong167 » 06 May 2019, 07:48
Hi all i would like to install Mac OS Mojave with these specs.
Operating System: Windows 10 Pro 64-bit
Language: English (Regional Setting: English)
System Manufacturer: FUJITSU
System Model: LIFEBOOK A574/H
Motherboard model: FJNB26E
Southbridge: Intel HM86
BIOS: Phoenix BIOS v1.07 (type: BIOS)
Processor: Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
Memory: 8192MB RAM
SSD Kingston 240GB
Intel HD 4600
Which Olarila image or Clover folder needed?
Thanks alot.
Post by MaLd0n » 06 May 2019, 12:34
ShunWong167, Olarila Mojave and clover folder NOTEBOOKS CHIPSET SERIES 5, 6, 7, 8, 9
video
audio
-Donated? Send me one PM-
ShunWong167
CPU: i5-4300m
GPU: HD4600
Post by ShunWong167 » 10 May 2019, 10:23
Hi MaLd0n, i've no luck try to boot from Olarila Mojave and clover folder notebooks chipset series 5,6,7,8,9 but halted, any way to know what is the problem? thanks.
Post by MaLd0n » 10 May 2019, 11:01
ShunWong167, u don't need replace clover folder inside Olarila image, this image have it, just use config2.plist and check if work
ShunWong167
CPU: i5-4300m
GPU: HD4600
Post by ShunWong167 » 14 May 2019, 04:36
no replace clover folder and selected config2.plist when boot it prompt "Please go to [External Link Removed for Guests] to report this panic".
Post by MaLd0n » 16 May 2019, 14:51
ShunWong167, post one photo, kp screen or rec one movie with problem
ShunWong167
CPU: i5-4300m
GPU: HD4600
Post by ShunWong167 » 17 May 2019, 06:45
Hi MaLdoN, sorry for disturb you again, pls see below startup video, thanks.
Post by MaLd0n » 17 May 2019, 12:49
ShunWong167, idk about this error, u need change things in bios/uefi and check if work
ShunWong167
CPU: i5-4300m
GPU: HD4600
Post by ShunWong167 » 13 Jun 2019, 10:52
Hi MaLdoN, finally, i can boot up with Olarila High sierra installer and finish the setup, after copy the NOTEBOOKS CHIPSET SERIES 5, 6, 7, 8, 9 (NEHALEM / SANDY BRIDGE / IVY BRIDGE / HASWELL / BROADWELL) EFI folder into the boot partition, it halted as attached screen, pls kindly help, thanks. :)
Post by MaLd0n » 13 Jun 2019, 12:23
ShunWong167, use all hackintosh kexts in clover/kexts/other, only
Return to “Laptop”
