notebook Samsung NP270E4E-kd4br
Post by MaLd0n » 23 Apr 2019, 13:15
rogeriovasco,
rogeriovasco
CPU: core i3 3110m
Motherboard: NP270E4E-KD4BR
GPU: intel hd graphcs 4000
Post by rogeriovasco » 26 Apr 2019, 07:25
23 Apr 2019, 13:15
rogeriovasco, DSDT.aml.zip
vlw muito obrigado me ajudou muito
rogeriovasco
CPU: core i3 3110m
Post by rogeriovasco » 06 May 2019, 16:17
23 Apr 2019, 13:15
maldon eu estou com problema na hibernaçao, logo que hiberna ele ja volta em seguida, pesquisei muito tentando resolver e nada
ate que resolvi tirar a dsdt que vc me mandou, depois disso a hibernaçao voltou a funcionar corretamente
tem algo que vc poderia mudar nessa dsdt pra voltar a funcionar a hibernaçao com ela
a dsdt que vc editou
caso precise desse
Send me Rogerios-MacBook-Air.zip
Post by MaLd0n » 06 May 2019, 16:35
rogeriovasco, é só remover ou adicionar _prw dentro do device
rogeriovasco
CPU: core i3 3110m
Post by rogeriovasco » 06 May 2019, 17:11
06 May 2019, 16:35
entao agora entra normal na hibernaçao so que quando volta dela da tela preta, e quando ligo o notebook logo depois do sistema iniciar ele ja hiberna sozinho sem eu aperta nada
rogeriovasco
CPU: core i3 3110m
Post by rogeriovasco » 06 May 2019, 20:26
MaLd0n, consegui resolver utilizando esse patch
valw ae pela ajuda
#Maintained by: RehabMan for: Laptop Patches
#usb_prw_0x0d_xhc.txt
# remove _PRW methods to prevent instant wake
# delete any existing XHC1 device
into device label XHC1 name_adr 0x00140000 remove_entry;
# delete any existing USB2 device
into device label USB2 name_adr 0x001D0000 remove_entry;
# if _PRW objects are methods
into method label _PRW parent_adr 0x001D0000 remove_entry;
into method label _PRW parent_adr 0x001A0000 remove_entry;
into method label _PRW parent_adr 0x00140000 remove_entry;
into method label _PRW parent_adr 0x001B0000 remove_entry;
# some other LAN cards use 0x00190000
into method label _PRW parent_adr 0x00190000 remove_entry;
# if _PRW methods are stuffed into a separate scope
into method label _PRW parent_label _SB.PCI0.EHC1 remove_entry;
into method label _PRW parent_label _SB.PCI0.EHC2 remove_entry;
into method label _PRW parent_label _SB.PCI0.XHC remove_entry;
into method label _PRW parent_label \_SB.PCI0.EHC1 remove_entry;
into method label _PRW parent_label \_SB.PCI0.EHC2 remove_entry;
into method label _PRW parent_label \_SB.PCI0.XHC remove_entry;
# if _PRW objects are names
into device name_adr 0x001D0000 code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\}\) remove_matched;
into device name_adr 0x001A0000 code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\}\) remove_matched;
into device name_adr 0x00140000 code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\}\) remove_matched;
into device name_adr 0x001B0000 code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\}\) remove_matched;
into device name_adr 0x00190000 code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\}\) remove_matched;
# some _PRW have three entries in the Package
into device name_adr 0x001D0000 code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\n.*\}\) remove_matched;
into device name_adr 0x001A0000 code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\n.*\}\) remove_matched;
into device name_adr 0x00140000 code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\n.*\}\) remove_matched;
into device name_adr 0x001B0000 code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\n.*\}\) remove_matched;
into device name_adr 0x00190000 code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\n.*\}\) remove_matched;
# seems to work better if _PRW is present, but returns 0 (original was 3) for sleep state
into device name_adr 0x001D0000 insert begin Name(_PRW, Package() { 0x0D, 0 }) end;
into device name_adr 0x001A0000 insert begin Name(_PRW, Package() { 0x0D, 0 }) end;
into device name_adr 0x00140000 insert begin Name(_PRW, Package() { 0x0D, 0 }) end;
into device name_adr 0x001B0000 insert begin Name(_PRW, Package() { 0x0D, 0 }) end;
into device name_adr 0x00190000 insert begin Name(_PRW, Package() { 0x0D, 0 }) end;
# USB property injection for 7-series boards (originally HM76)
# Insert Apple USB properties into EHC1
into method label _DSM parent_adr 0x001D0000 remove_entry;
begin
{\n
If (LEqual (Arg2, Zero)) { Return (Buffer() { 0x03 } ) }\n
Return (Package()\n
{\n
"subsystem-id", Buffer() { 0x70, 0x72, 0x00, 0x00 },\n
"subsystem-vendor-id", Buffer() { 0x86, 0x80, 0x00, 0x00 },\n
"AAPL,current-available", 2100,\n
"AAPL,current-extra", 2200,\n
"AAPL,current-extra-in-sleep", 1600,\n
"AAPL,device-internal", 0x02,\n
"AAPL,max-port-current-in-sleep", 2100,\n
})\n
}\n
end;
# Insert Apple USB properties into EHC2
into method label _DSM parent_adr 0x001A0000 remove_entry;
begin
{\n
Return (Package()\n
{\n
})\n
}\n
end;
# Insert Apple USB properties into USB 3.0 XHC
into method label _DSM parent_adr 0x00140000 remove_entry;
begin
{\n
Return (Package()\n
{\n
})\n
}\n
end;
# special cases... (not in u430 DSDT)
#into scope label _SB.PCI0.XHC.RHUB.HS05 set_label begin _SB.PCI0.XHC1.RHUB.HS05 end;
Return to “Laptop”
