Asus N580GD (Help me for install High Sierra)
onemanosx
Post by onemanosx » 24 Jul 2019, 14:55
Graissechel, I guess I was to slow to update the last post.
Use this config.plist. DSDT and SSDT remains.
config.plist.zip
MSI B360 Gaming Arctic
Graissechel
CPU: i7-8750H
Motherboard: Asus X580GD
GPU: GTX 1050
Post by Graissechel » 24 Jul 2019, 15:02
It doesn't change anything with the config.plist you gave me, touchpad still not working.
Here is the SendMe : [External Link Removed for Guests]
onemanosx
Post by onemanosx » 25 Jul 2019, 23:35
Graissechel, Trackpad can work in interrupt mode? I think its common in most Asus, has buggy GPI0 and thus can only work in polling mode. Anyway, happy to assist getting the track pad working :)
Mac93
CPU: i7-8750h
Motherboard: Asus N580GD
GPU: GTX1050
Post by Mac93 » 03 Sep 2019, 08:26
Any News For Mojave Installation on this laptop? I have the same laptop, and at first I was able to install using clover, but now I'm with the formatted SSD, and I can't start the installation anymore. Sorry if I do OT on this discussion, but it's the same laptop.
Sorry for bad English
onemanosx
Post by onemanosx » 03 Sep 2019, 12:15
03 Sep 2019, 08:26
This laptop should work fine with Mojave.
Use the guide here : [Local Link Removed for Guests]
Your English is fine. ;)
Mac93
CPU: i7-8750h
GPU: GTX1050
Post by Mac93 » 09 Sep 2019, 17:18
03 Sep 2019, 12:15
Do you also think about the video card ?? For now, I managed to install mojave via clover (pendrive replaced), but I'm downloading that olarila ... I ask for advice for the video card that is a GTX1050, for this video card drivers you can use mojave or better highsierra?
onemanosx
Post by onemanosx » 09 Sep 2019, 22:57
Mac93, if there is no intel graphics then High Sierra
pchitech
CPU: Intel Core i7-8750H
GPU: Intel UHD Graphics 630
Post by pchitech » 26 Oct 2019, 08:38
20 Jul 2019, 12:06
Graissechel, In case you are curious previous attempts are to eliminate SSCN FMCN Acpi errors and were resolved successfully.
kernel: (kernel) VoodooI2CPCIController::pci8086,a368 Starting I2C controller
kernel: (kernel) VoodooI2CPCIController::pci8086,a369 Starting I2C controller
kernel: (kernel) VoodooI2CPCIController::pci8086,a368 Set PCI power state D0
kernel: (kernel) VoodooI2CPCIController::pci8086,a368 Publishing nub
kernel: (kernel) VoodooI2CControllerDriver::pci8086,a368 Probing controller
kernel: (kernel) VoodooI2CControllerDriver::pci8086,a368 Found valid Synopsys component, continuing with initialisation
kernel: (kernel) VoodooI2CPCIController::pci8086,a369 Set PCI power state D0
kernel: (kernel) VoodooI2CPCIController::pci8086,a369 Publishing nub
kernel: (kernel) VoodooI2CControllerDriver::pci8086,a368 Got bus configuration values
This next one is trying to implement polling mode with zero GPI0
DSDT-SBFB.aml.zip
Hi onemanosx,
I have the same notebook described in the first post.
After several attempts I was able to get the trackpad to work using this dsdt file you modified.
Now I can't get the function keys for the brightness and the backlight keys to work. Every time I try to patch the dsdt the trackpad stops working.
Can you help me please.
Sorrry for my English
onemanosx
Post by onemanosx » 26 Oct 2019, 09:09
pchitech, follow this guide for your brightness hotkeys
pchitech
Post by pchitech » 26 Oct 2019, 11:07
26 Oct 2019, 09:09
I tried to follow this guide and others but when I compile the dsdt I have a whole series of errors and if I try to solve them the trackpad stops working.
The trouble is that having started from a dsdt your, for the solution of the problem to the trackpad, surely something escapes me
onemanosx
Post by onemanosx » 26 Oct 2019, 11:52
pchitech, Boot your laptop without DSDT and run the app [Local Link Removed for Guests]
Upload the sendme file created on desktop.
pchitech
Post by pchitech » 26 Oct 2019, 15:25
26 Oct 2019, 11:52
Sorry for the delay
onemanosx
Post by onemanosx » 26 Oct 2019, 16:15
pchitech, Read this guide and answer the 7 important hints highlighted in RED. [Local Link Removed for Guests]
Reboot with this DSDT and extract new Sendme files. Upload files in I2C thread above and continue our discussion there
As for your brightness hotkeys for ASUS laptops read here: [External Link Removed for Guests]
