Instructions are very clear [External Link Removed for Guests][Local Link Removed for Guests] wrote: [Local Link Removed for Guests]22 Jul 2019, 13:19Indeed, it is a rather complicated problem. I will try to install Mojave in a clean installation. On the other hand, for the AsusSMC, I just saw on GitHub that a DSDT patch was needed. Is the one I own okay to install this kext or not ?
-->Donations via PayPal [External Link Removed for Guests]
Asus N580GD (Help me for install High Sierra)
- onemanosx
- Olarila Staff
- CPU: Intel i7-6700HQ HM170 Chipset
- Motherboard: Acer Aspire VN7-592G Laptop
- GPU: Intel HD 530 + Nvidia GTX 960M
MSI B360 Gaming Arctic
- CPU: i7-8750H
- Motherboard: Asus X580GD
- GPU: GTX 1050
I tried to upgrade my PC to Mojave without success. It's okay, I came back on High Sierra. I managed to fix the Fn Keys problem (and at the same time the keyboard backlighting), thanks you onemanosx for providing me with the link to AsusSMC.
I now have to solve the other problems so that everything can be operational, namely:
- The touchpad
- The SD card reader
- The HDMI port
- iMessage and FaceTime
- Sleep
- Airplane mode ? (I don't know if it's possible)
And possibly Bluetooth if possible.
I know that I couldn't activate my Nvidia card because it acts here as a dGPU and this feature is not supported. It doesn't matter, I'll do a dual-boot on Windows.
- The touchpad
- The HDMI port
- Sleep
- onemanosx
- Olarila Staff
Graissechel, One last try from me. Hopefully this works.
Bluetooth and wifi only works with Native Apple cards. You need to replace it.
HDMI port, you may use hackintool app. [External Link Removed for Guests]
iMessage and Facetime need to use real Apple SMBIOS to work.
Sleep? Mald0n may help with that issue
- CPU: i7-8750H
- GPU: GTX 1050
Not yet, my touchpad doesn't work. On Windows 10, however, there is no problem.
Here is the link to SendMe : [External Link Removed for Guests]
- CPU: i7-8750H
- GPU: GTX 1050
I thought I had found the culprit. From what I understand from the screenshot, it seems that the kext com.alexandred.VoodooI2CHID can't load due to an error. I think that this error could be the cause of the problem.[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]23 Jul 2019, 15:13Graissechel, One last try from me. Hopefully this works.
(I just posted this same message on the VoodooI2C page on gitter to see if the community has already faced the same problem)
Link to the screenshot : [External Link Removed for Guests]
- onemanosx
- Olarila Staff
Graissechel, that screenshot shows problem in kext loading. This issue was not seen before this. I know you followed instructions at gitter and this happened.
- CPU: i7-8750H
- GPU: GTX 1050
I put the kext VoodooI2C and VoodooI2CHID in /Library/Extensions. I no longer have the problem of "kext failed to load". On the other hand my touchpad is still not functional and I have this in the kernel log :[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]23 Jul 2019, 21:36Graissechel, that screenshot shows problem in kext loading. This issue was not seen before this. I know you followed instructions at gitter and this happened.
- onemanosx
- Olarila Staff
Lets wait for Ben to assist you in troubleshooting. Kernel logs you posted are no different from our previous efforts (except for SSCN/FMCN error which we had managed to resolve).[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]24 Jul 2019, 12:04I put the kext VoodooI2C and VoodooI2CHID in /Library/Extensions. I no longer have the problem of "kext failed to load". On the other hand my touchpad is still not functional and I have this in the kernel log :
I'd be interested how the problem will be solved. Especially with "initializing community.." which I have figured has something to do with newer versions of GPIO pinning method.
- CPU: i7-8750H
- GPU: GTX 1050
Ok I'll try to solve this problem on gitter, I'll post the solution here when it's found.[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]24 Jul 2019, 12:10Lets wait for Ben to assist you in troubleshooting. Kernel logs you posted are no different from our previous efforts (except for SSCN/FMCN error which we had managed to resolve).
In the meantime we can try to solve the other problems.
For the HDMI port, it is connected to my Nvidia graphics card so it will not work. However I have an alternative to this problem, I have a USB C to VGA converter and it works very well, the display is perfectly fine so no problems at this level, my USB C port is fine.
For iMessage and FaceTime, I had tried to make them work before reinstalling macOS and I got this error code each time:
"Your Apple id "xxx@xxx.com" can't be used to set up iMessage at this time"
However, in Clover, my SMBIOS does send me an invalid serial number, which is necessary to avoid conflicts with existing devices. So I don't really know how to solve this.
For the sleep problem, when I click on the button to sleep in the Apple menu, my PC puts a black screen on me and then goes into sleep. However, it turns on again immediately after I have touched nothing. To restore the display, I have to press the Space bar to turn the screen back on.
For the SD player problem I don't know where it comes from either.
- onemanosx
- Olarila Staff
For this to work, having a valid serial from an actual mac is the easiest. Then again, I only got this to work temporarily once. Now dont work anymore.[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]24 Jul 2019, 12:29iMessage and FaceTime
Need to check in Console for "Wake Reason". Possibly a filled USB or Ethernet is a common issue as far as I know. Yours could be different. So yeah, check from console.[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]24 Jul 2019, 12:29sleep problem
BTW, if you have a bootable USB and would like to help me further "probe" the I2C issue, can you boot using these files? Block DSDT and just use the SSDT. Thanks in advance.
- CPU: i7-8750H
- GPU: GTX 1050
Luckily, I kept the High Sierra installation key. I boot on it with what you gave me and here's what's going on (SendMe archive) :
- onemanosx
- Olarila Staff
Graissechel, I think we are on to something here.
If you can make a backup of you EFI to the USB. Then boot directly, with these files is much appreciated. Remember, block the DSDT if any.
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,a369 I2C Transaction error details
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,a369 slave address not acknowledged (7bit mode)
kernel: (VoodooI2C) VoodooI2CControllerDriver::pci8086,a369 I2C Transaction error: 0x08800001 - aborting
kernel: (VoodooI2CHID) VoodooI2CHIDDevice::ELAN1300 Request for HID descriptor failed
- CPU: i7-8750H
- GPU: GTX 1050
I'm stuck at "End Randomseed" when I block DSDT, so I reactivate it.
Here the SendMe : [External Link Removed for Guests]
- onemanosx
- Olarila Staff
Sorry about that.[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]24 Jul 2019, 13:37I'm stuck at "End Randomseed" when I block DSDT
Just place DSDT-01 and SSDT in patched folder and boot with config-02.plist
- CPU: i7-8750H
- GPU: GTX 1050
With this version I can boot. However, the touchpad is still not working and I have lost the Fn Keys and the ability to decrease or increase the brightness of the screen.
Here is the SendMe : [External Link Removed for Guests]
They replied to my message on Gitter and told me :
"@Graissechel You shouldn't be patching ETPD._STA, revert to original"
- onemanosx
- Olarila Staff
Dont worry about those for now since the SSDT is not patched for that yet. Our target is is I2C.[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]24 Jul 2019, 14:08With this version I can boot. However, the touchpad is still not working and I have lost the Fn Keys and the ability to decrease or increase the brightness of the screen
- CPU: i7-8750H
- GPU: GTX 1050
Still no functional touchpad. I don't know if you saw it, I edited the message above by putting what I was put on Gitter, hoping it would help you.
- onemanosx
- Olarila Staff
Graissechel, My patches for tonight do not include the Return (0x0F) for ETPD._STA
You can give the latest sendme or debug.sh for him and see his comment, too!
- onemanosx
- Olarila Staff
Graissechel, New Patch for SSCN Error.
Appologies, please reboot with this config.plist. Last config was botched.
DSDT and SSDT remains.
- CPU: i7-8750H
- GPU: GTX 1050
Sorry, but it still doesn't work.
EDIT : I just saw that you added the config.plist, I'll try again with it.
