High Sierra Olarila 10.13.6
beatthecatagain
CPU: i5 8250
Motherboard: Laptop Ideapad 330s
GPU: intel uhd 620
High Sierra Olarila 10.13.2 HFS / APFS Final
Post by beatthecatagain » 14 Aug 2018, 19:12
i tried doing that with the 2 files you mentioned above, i did remove aptiomemoryfix from the same folder
however, it doesn't reboot now, but still stay stuck in the same place. just hangs there forever lol
So, i opened my laptop. It has currently 8gigs. However, 4 gigs is builtin soldered, and the other 4gb is one stick in the only place it can go. So there isn't anywhere to move the stick.
junior3d
CPU: i7 6700k
Motherboard: Gigabyte Z170X-UD5
GPU: EVGA GeForce GTX 980
Post by junior3d » 17 Aug 2018, 00:09
MaLd0n e pessoal, estava seguindo o Guide do Youtube e na parte mais para o final antes da pós instalação, simplesmente parou na posição mostrada na figura. Alguma ideia do que pode ser?
Post by MaLd0n » 17 Aug 2018, 00:15
desmarca o injectintel
junior3d
CPU: i7 6700k
Post by junior3d » 17 Aug 2018, 00:49
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]desmarca o injectintel
No menu do clover?
Post by MaLd0n » 17 Aug 2018, 01:05
pressiona O na tela de boot do clover, Graphics
junior3d
CPU: i7 6700k
Post by junior3d » 17 Aug 2018, 23:07
Foi para frente, mas depois de colocar meu nome, nome da conta/senha.. quando era para entrar a tela da Área de trabalho(Mesa), correu algumas linhas e a tela fica escura :?:
Post by MaLd0n » 17 Aug 2018, 23:09
tem de instalar o web drivers e ter a nvram funcionando
junior3d
CPU: i7 6700k
Post by junior3d » 17 Aug 2018, 23:17
Marcar web drivers lá mo menu do clover?
E o que seria "nvram funcionando"?
Post by MaLd0n » 17 Aug 2018, 23:23
usa a aptiomemoryfix que a nvram funciona nativamente
junior3d
CPU: i7 6700k
Post by junior3d » 18 Aug 2018, 00:20
MaLd0n onde eu acho esse aptiomemoryfix no menu do Clover? Apertei o O mas não acho de jeito nenhum.
Post by MaLd0n » 18 Aug 2018, 01:57
é driver, fica dentro da pasta Clover/drivers64UEFI
junior3d
CPU: i7 6700k
Post by junior3d » 18 Aug 2018, 02:06
Bom segui tudo igualzinho está no video, substitui a pasta Clover do sistema pela que baixei do site para o meu chipset, instalei o clover que estava na pasta do PenDrive, mas no final quando diz "Reboot and enjoy"parou na tela abaixo :oops:
Post by MaLd0n » 18 Aug 2018, 02:20
desabilita a intelHD no bios, se vc for usar as duas, tem de configurar
junior3d
CPU: i7 6700k
Post by junior3d » 18 Aug 2018, 02:43
Funcionou valeu. Amanhã eu te passo os arquivos para gerar o DSDT.aml
Abs
beatthecatagain
CPU: i5 8250
GPU: intel uhd 620
Post by beatthecatagain » 28 Aug 2018, 15:09
Sem sucesso ainda. O laptop continua travado no Randomseed.
Nao e possivel que nao haja uma solucao pra isso.
Post by MaLd0n » 28 Aug 2018, 15:19
usa a última versão do high sierra com o config2.plist que existe dentro da imagem
beatthecatagain
CPU: i5 8250
GPU: intel uhd 620
Post by beatthecatagain » 28 Aug 2018, 21:02
Nao entendo...
Voce recomenda pra fazer o download desse [External Link Removed for Guests] ?
Hoje eu tentei com o mojave beta 8 e config2 sem sucesso tambem. Parou no randomseed e restart.
Post by MaLd0n » 28 Aug 2018, 21:23
vc tem de descobrir o que está causando o restart
vc pode baixar o nosso app e montar o seu usb bootável tb
beatthecatagain
CPU: i5 8250
GPU: intel uhd 620
Post by beatthecatagain » 29 Aug 2018, 01:36
nao da pra usar o app, eu nao tenho mac.
Eu so tenho duas opcoes pra montar a imagem, pelo linux ou windows.
Post by MaLd0n » 29 Aug 2018, 02:01
use intelgfx com 0x12345789
vc consegue fazer isso pelo boot, aperta a tecla O na tela de boot do Clover/Graphics
