Hig sierra
seantocheski
CPU: i3
Motherboard: gibabyte
GPU: 500
Hig sierra
Post by seantocheski » 29 Jul 2019, 21:47
Boa noite.
Good night.
I'm trying to hig sierra on this motherboard: tuf h310m-plus gamin with gtx 1050 ti card. but I can't enter the screen to install
Hig sierra
Post by MaLd0n » 29 Jul 2019, 23:11
seantocheski,
<dict>
					<key>Comment</key>
					<string>Fix bug SKL+</string>
					<key>Disabled</key>
					<false/>
					<key>Find</key>
					<data>
					oAqTU1RBUwE=
					</data>
					<key>Replace</key>
					<data>
					oAqRCv8L//8=
					</data>
				</dict>
-Donated? Send me one PM-
seantocheski
CPU: i3
GPU: 500
Hig sierra
Post by seantocheski » 30 Jul 2019, 11:07
Good Morning.
I'm a hacker, where do I put this code?
Thanks in advance for your help
Hig sierra
Post by MaLd0n » 30 Jul 2019, 13:51
seantocheski, :shock:
seantocheski
CPU: i3
GPU: 500
Hig sierra
Post by seantocheski » 31 Jul 2019, 11:33
Good Morning.
Can you help me activate my gtx 1050 t.i on hig sierra 10.3.6 17g65
Hig sierra
Post by MaLd0n » 31 Jul 2019, 12:40
seantocheski, [Local Link Removed for Guests]
onemanosx
Hig sierra
Post by onemanosx » 31 Jul 2019, 12:58
29 Jul 2019, 23:11
<dict>
					<key>Comment</key>
					<key>Disabled</key>
					<false/>
					<key>Find</key>
					<data>
					oAqTU1RBUwE=
					</data>
					<key>Replace</key>
					<data>
					oAqRCv8L//8=
					</data>
				</dict>
What does this do, Mald0n?
MSI B360 Gaming Arctic
Hig sierra
Post by MaLd0n » 31 Jul 2019, 13:03
onemanosx, some mobos have a _STA inside Real Time Clock device, we need remove it
a universal rtc device
Device (RTC)
                    Name (_HID, EisaId ("PNP0B00") /* AT Real-Time Clock */)  // _HID: Hardware ID
                    Name (_CRS, ResourceTemplate ()  // _CRS: Current Resource Settings
                        IO (Decode16,
                            0x0070,             // Range Minimum
                            0x0070,             // Range Maximum
                            0x00,               // Alignment
                            0x02,               // Length
use ever it inside Low Pin Count device and avoid many problems
onemanosx
Hig sierra
Post by onemanosx » 31 Jul 2019, 13:15
31 Jul 2019, 13:03
Device (RTC)
IO (Decode16,
0x00, // Alignment
0x02, // Length
Similar to FixRTC?
Hig sierra
Post by MaLd0n » 31 Jul 2019, 13:19
onemanosx, no, i think fixrtc(acpi tab) by clover just remove irq and applertc(kernel and kexts patches) solve rtc problems after sleep in some mobos
onemanosx
Hig sierra
Post by onemanosx » 31 Jul 2019, 13:33
MaLd0n, Thank you! Muito obrigado! Terima kasih!
Hig sierra
Post by MaLd0n » 31 Jul 2019, 13:38
onemanosx, :meeting
seantocheski
CPU: i3
GPU: 500
Hig sierra
Post by seantocheski » 01 Aug 2019, 19:57
31 Jul 2019, 13:19
Hi don't work. :(
onemanosx
Hig sierra
Post by onemanosx » 01 Aug 2019, 22:04
01 Aug 2019, 19:57
Hi don't work. :(
be specific. What doesnt work? upload new sendme files
seantocheski
CPU: i3
GPU: 500
Hig sierra
Post by seantocheski » 02 Aug 2019, 11:04
I installed the nvidia web drive, but not active.
Is there any other procedure I can do?
onemanosx
Hig sierra
Post by onemanosx » 02 Aug 2019, 11:05
02 Aug 2019, 11:04
Upload your sendme dump files.
