Patches for Asus Z170 Deluxe
DrDrumm
CPU: I7 8086K
Motherboard: Asus ROG Maximus X (Wi-Fi)
GPU: Vega 64
Post by DrDrumm » 08 Apr 2019, 11:08
So why can't I boot with it?
The apple progress bar just hangs and it doesn't reach the finder.
I'll boot verbose, and see where it hangs.
Btw, it works perfectly without both the DSDT and the SSDT. In fact, it gave me another speed step (9, compared to 8 with SSDT).
If it works great without DSDT and SSDT, do I still need them for some reason I can't see?
Thanks for your help! :D
Post by MaLd0n » 08 Apr 2019, 13:30
DrDrumm, hackintosh never work good without dsdt, our bios/uefi is not for macos, we need many changes
DrDrumm
CPU: I7 8086K
GPU: Vega 64
Post by DrDrumm » 09 Apr 2019, 15:49
OK, so this is weird:
I couldn't load Mojave with the perfectly working DSDT that you so graciously patched for me (AKA: DSDT-Original.aml) the worked great on High Sierra.
I downloaded a DSDT you edited for ASUS Maximus Code and it worked perfectly. (AKA: DSDT.aml).
Can you please tell me why and is it safe to use?
Post by MaLd0n » 09 Apr 2019, 16:04
DrDrumm, use Olarila Clover folder for ur chipset and extract send_me with correct folder, after it i apply my patches
Return to “Sierra (10.12)”
