Sierra Olarila 10.12.6
Mohanmp3
CPU: I3 5005u
Motherboard: Intel
GPU: Hd5500
Post by Mohanmp3 » 23 Aug 2018, 05:19
when i boot from bootable olarila usb an error show
more detail available in attached image
Added in 19 minutes 3 seconds:
olarila siera not boot in my laptop
Post by MaLd0n » 23 Aug 2018, 05:44
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] when i boot from bootable olarila usb an error show
u can create ur personal installer, check our app, have all info there
ahmedkiko
CPU: 2.79 GHz Intel Core 2 Duo
Motherboard: hp dc7900 tower
GPU: PNY GeForce 8400 GS 512 MB
Post by ahmedkiko » 29 Aug 2018, 01:59
no keyboard and mouse detected to finish step install
Post by MaLd0n » 29 Aug 2018, 02:03
U need fix it if don't work, via dsdt or one injector, what chipset?
ahmedkiko
Post by ahmedkiko » 29 Aug 2018, 02:18
i installed in my pc evry week but now stuck in finsh last install
my pc core 2 duo ... hp dc 7900
8400 gs 512 nivida .... 6g ram
Post by MaLd0n » 29 Aug 2018, 02:26
check bios config
ahmedkiko
Post by ahmedkiko » 29 Aug 2018, 03:29
i check my bios and try install again .. arag worked for me evry time drao=0 and uncheck all dste
in first step install evrysting is work in final not work usb key and mouse
ahmedkiko
Post by ahmedkiko » 29 Aug 2018, 07:51
@MaLd0n
i install 10.12.6 but when restart after colver its boot and open but no mouse and key board deceted 😥😥😥
Post by MaLd0n » 29 Aug 2018, 14:02
No idea, u need check bios config or drivers for clover or dsdt patch for fix it
Neo_1979
Post by Neo_1979 » 02 Oct 2018, 19:40
Hello all, I have a problem with intel usb 3.0 ports.
My laptop is a Dell Mobile Workstation M6700:
cpu i7-3940xm extreme
qm77 chipset
24gb ram ddr3 1600mhz
nvidia quadro k3000m 2gb gdrr5 (I use this as my video card, optimus disabled in bios)
17,3" fullhd 1920x1080
ssd1 samsung 850 250gb (windows 10 os)
ssd2 crucial mx300 525gb (downloads)
ssd3 crucial mx300 750gb (caddy) (data and virtual machines)
ssd4 lite-on msata 256gb (sierra mac os)
5 usb ports:
2 usb 2.0 (work flowlessly)
1 usb/eSata combo port (work flowlessly)
2 usb 3.0 intel ports (work as 2.0 ports)
I can't figure it out to make 3.0 ports work at their full speed. Tried usbinjectall.kext and clover port limit patch for sierra (and rename ehc1 to eh01.....), nothing.
Tried dsdt.amd patching with 7-series/8-series usb, nothing (this method worked for other 2 laptops)
Tried fakepciid.kext + fakepciid_xhcimux.kext, nothing.
They always work as 2.0 ports. In profiler there are 2 usb 2.0 controllers ehci. Not an XHCI is shown/found.
Hope you can give me some advice to fix the problem.
Post by MaLd0n » 03 Oct 2018, 00:07
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]cpu i7-3940xm extreme
u need check if ur usb3 is intel, post ur dump here
Neo_1979
Post by Neo_1979 » 03 Oct 2018, 21:35
The picture shows how it is recognized under windows 10.
Here it is. Remember, I'm using NVIDIA QUADRO K3000M as video card.
Post by MaLd0n » 04 Oct 2018, 02:01
03 Oct 2018, 21:35
add in config.plist/acpi tab
change EHC1 to EH01
45484331
45483031
change EHC2 to EH02
45484332
45483032
use usbinjectall
Neo_1979
Post by Neo_1979 » 04 Oct 2018, 21:47
Unfortunately, nothing changed :(
Post by MaLd0n » 04 Oct 2018, 21:51
send me new SEND_ME
Neo_1979
Post by Neo_1979 » 04 Oct 2018, 21:56
Here it is
Post by MaLd0n » 04 Oct 2018, 22:12
u disable xhci(usb3) in bios?
check there
Neo_1979
Post by Neo_1979 » 04 Oct 2018, 22:20
No, of course. I'm a pc technician since 13 years and I already thinked and verified that.
Also, in Windows they work properly.
Post by MaLd0n » 04 Oct 2018, 22:38
extract untouched dsdt with f4 key in clover boot screen, ill check if device exist
Neo_1979
Post by Neo_1979 » 04 Oct 2018, 22:42
I attached all ORIGIN folder
Return to “Sierra (10.12)”
