CPU Power Management SSDT Problem
pavle
CPU: Intel Core i3 2100 @ 3.10GHz
Motherboard: Gigabyte H61M-S2-B3
GPU: NVIDIA GeForce GTS 450 (1 GB)
Post by pavle » 09 Aug 2019, 08:16
I have ssdt generated with Piker Alpha's ssdtPRGen for my cpu and I placed it inside /EFI/EFI/CLOVER/ACPI/patched and I dropped CpuPm and Cpu0lst in Acpi section of config.plist and when I reboot and login pc reboots itself after 30 seconds
and that repeats whenever pc boots up
I am using SMBIOS 13,2 and I used this arguments -target 0 -p i3-2100 -m iMac12,2 -b Mac-942B59F58194171B to generate ssdt
My System Specs:
Video: - nVidia GeForce GTS 450 (1GB)
CPU: - Intel Core i3 2100 @ 3.1GHz
MB: - Gigabyte H61M-S2-B3
RAM: - 8GB Dual-Channel DDR3 @ 665MHz Kingston
Generated ssdt file is located in EFI.zip for which I posted link below
Can someone please help me to properly setup CPU Power Management?
EFI folder: [External Link Removed for Guests]
Post by MaLd0n » 09 Aug 2019, 19:19
pavle, the ssdt is for ivy bridge
check here
-Donated? Send me one PM-
pavle
Post by pavle » 09 Aug 2019, 20:32
09 Aug 2019, 19:19
check here
How do you mean ssdt is for ivy bridge? SSDT is generated for i3 2100 cpu which is sandy bridge.
Post by MaLd0n » 09 Aug 2019, 23:53
pavle, Image
pavle
Post by pavle » 10 Aug 2019, 06:09
09 Aug 2019, 23:53
pavle, Image
Someone generated ssdt for my cpu because when I tried to run script I got errors below:
Compiler aborting due to parser-detected syntax error(s)
/Users/pavle/Library/ssdtPRGen/ssdt.dsl 20: External (_PR_.._PR, DeviceObj)
Error 6126 - ^ Invalid character (0x2E), expecting ASL keyword or name
Error 6126 - ^ syntax error, unexpected PARSEOP_NAMESEG, expecting ')'
/Users/pavle/Library/ssdtPRGen/ssdt.dsl 21: External (_PR_.._PR, DeviceObj)
onemanosx
Post by onemanosx » 10 Aug 2019, 07:07
10 Aug 2019, 06:09
Not a good idea for someone to generate PM script on a separate machine.
Have you tried this link? [Local Link Removed for Guests]
MSI B360 Gaming Arctic
pavle
Post by pavle » 10 Aug 2019, 07:45
10 Aug 2019, 07:07
I will get same error: compiler aborting due to parser-detected syntax error(s)
onemanosx
Post by onemanosx » 10 Aug 2019, 07:48
10 Aug 2019, 07:45
will get same error Compiler aborting due to parser-detected syntax error(s)
.."I will get same error.." Does this imply you are assuming without even trying? :shock:
Read the guide again. Download the DATA folder and Pike's folder direct from github as documented. Good luck.
pavle
Post by pavle » 10 Aug 2019, 20:34
10 Aug 2019, 07:48
I followed guide and I downloaded data folder and I used same arguments -target 0 -p i3-2100 -m iMac12,2 -b Mac-942B59F58194171B to generate ssdt and it generated successfully. After that I opened it and compiled it and after placing it inside /EFI/EFI/CLOVER/ACPI/patched pc still reboots itself after 30 seconds.
SSDT file: [External Link Removed for Guests]
pavle
Post by pavle » 11 Aug 2019, 08:10
Why pc reboots itself after 30 seconds when booted?
onemanosx
Post by onemanosx » 11 Aug 2019, 10:33
11 Aug 2019, 08:10
Investigate the cause by finding the panic report via Console. Hopefully, there's a useful clue in there.
pavle
Post by pavle » 11 Aug 2019, 11:25
Which command I should use to get logs in terminal?
onemanosx
Post by onemanosx » 11 Aug 2019, 11:31
pavle, Console
pavle
Post by pavle » 11 Aug 2019, 14:39
11 Aug 2019, 11:31
pavle, Console
I went to System Reports and I didn't find panic report
onemanosx
Post by onemanosx » 11 Aug 2019, 15:06
pavle, Its possible the issue is a hardware failure. But, lets see what others have to say about your problem.
pavle
Post by pavle » 11 Aug 2019, 15:18
11 Aug 2019, 15:06
It's not hardware failure. Hardware is working perfectly on Windows 10.
pavle
Post by pavle » 13 Aug 2019, 11:40
11 Aug 2019, 15:06
I found DSDT for my motherboard on [External Link Removed for Guests]
I downloaded it and compiled it(here is output: [External Link Removed for Guests]) and placed it inside /EFI/EFI/CLOVER/ACPI/patched and now pc doesn't reboot anymore after 30 seconds.
DSDT file: [External Link Removed for Guests]
I took output files from SystemInformation, IORegistryExplorer, Intel Power Gadget and AppleIntelInfo when pc booted up:
I also took output files without generated ssdt for my cpu: [External Link Removed for Guests]
Can you please check if output is correct?
onemanosx
Post by onemanosx » 13 Aug 2019, 13:33
pavle, Didnt know your were running DSDT-less. I strongly recommend using your own ACPI table instead of using a DSDT from the internet (although it may be of the same build and same bios version).
pavle
Post by pavle » 13 Aug 2019, 15:49
13 Aug 2019, 13:33
I pressed F4 when I was at clover menu and then I logged in. Files from below image were added to origin folder.
I tried to compile DSDT.aml and I got two errors: [External Link Removed for Guests]
I fixed them by commenting Store (Local0, Local0) in lines 287 and 292: [External Link Removed for Guests]
pavle
Post by pavle » 13 Aug 2019, 19:06
After adding compiled DSDT.aml with fixed errors pc again reboots after 30 seconds.
DSDT.aml: [External Link Removed for Guests]
Return to “Sierra (10.12)”
