OS X Yosemite 10.10.5 Upgrade problems with netflix, YouTube
icecold
CPU: i7 950
Motherboard: Intel DX58SO Extreme
GPU: Sapphire Radeon 6870HD
Post by icecold » 23 Jan 2017, 16:38
After I upgraded Yosemite 10.10, from a successful installed USB, as explained here >>>[Local Link Removed for Guests]
I wasn't able to connect to any streaming services such as You Tube, Netflix etc, It's not my router because i am able to connect using Lion on the same rig, installed on another hard disk.
I did a direct upgrade from the Apple Store. Yosemite 10.10 had glitches but worked, I mean it video became frozen for a few seconds while audio was still playing fine, but that was all, since the upgrade, it fails to connect ...
I'm clueless, I thought it might be a permissions problem so I used kext wizard to fix all my kexts, but same errors.
icecold
CPU: i7 950
Re: OS X Yosemite 10.10.5 Upgrade problems with netflix, You
Post by icecold » 25 Jan 2017, 20:04
Well I solved this! :D
The problem was the wrong AppleIntelE1000e.kext
I found another one online and it worked!
BTW FYI my Intel Chipset uses the 82567LF for the Gigabit Network although is recognized a 100Mbps instead of 1Gbit
Return to “Yosemite (10.10)”
