OS X Yosemite 10.10 bootable USB for Intel PCs
sumek80
CPU: X9100
Motherboard: 0X564R
GPU: NVIDIA Quadro NVS160M
Re: OS X Yosemite 10.10 bootable USB for Intel PCs
Post by sumek80 » 05 Mar 2015, 21:00
Mate, i don't know how to fix this problem, many user with e6400/e6500/m4400 will be glad if this boot os x 10.10 for pc works, me to. Windows for me - no problem, os x - know this 5 days. Only os x 10.6 works on this Dell but is old and not work properly. I want to fix the problem but i do not know how and where to start
javi_m
CPU: Intel i3-2310
Motherboard: Lenovo
GPU: Intel HD3000
Post by javi_m » 21 Apr 2015, 18:02
Hi, i have a lenovo g570. Intel i3-2310, with intel HD3000
i made a bootable usb with imageusb (win32diskmanager didn't work on win8) and yosemite 10.10 for intel pcs (downloaded from TPB).
I get the clover boot selection, and when i choose "boot mac os x from os x install usb", i get the following (see images).
So, i can't do anything. Black screen, apple logo, progress bar, and then that weird screen, appearing like an animation (it shows from opacity 0, to opacity 100%, something like that).
What am i doing wrong?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 21 Apr 2015, 19:20
about hd 3000
and should read here first page .. install solutions
javi_m
CPU: Intel i3-2310
Motherboard: Lenovo
GPU: Intel HD3000
Post by javi_m » 22 Apr 2015, 17:02
Thanks, i found the config.plist necessary to boot the installer. thanks for the great work here! i need to read A LOT. i'm familiarized with gnu/linux and windows installations, but is quite different here, haha!
Sallice
CPU: AMD FX-8320
Motherboard: Asus Sabertooth 990FX R2.0
GPU: Asus R9 280 OC Strix
Post by Sallice » 01 May 2015, 18:37
Hello, I own Lenovo G50-70
CPU: Intel Core i3-4010U with HD 4400 (Turned off virtualization in BIOS)
GPU: AMD Radeon R5 M230 (I disabled it in BIOS)
I disabled secure boot in BIOS and enabled legacy boot.
I used win32diskimager to write .raw image to my pendrive.
I used tips from this topic: [Local Link Removed for Guests]
I enabled: Kernel PM Patch, USB Ownership
My boot arguments are: -v npci=0x2000 kext-dev-mode=1 (this three are auto filled every boot of Clover) and I added: -gux_defer_usb2 -gux_no_idle
With all this I take care of: Missing Bluetooth Controller Transport, Automatic reboot, EHCI controller unable to take control from BIOS, AppleUSBEHCI: unable to obtain ownership, Still waiting for root device and Scrambled verbose boot screen with forbidden sign.
But when I try to boot it starts loading and it stuck with spam of massage: disk1s2: media is not present.
Can anyone help me?
gunsize
CPU: i5 3470 Quad-core @3.2 Ghz
Motherboard: ASRock B75 Pro 3
GPU: Intel HD 2500
Post by gunsize » 11 Jul 2015, 16:07
Hi,
Is there a way to run it with Intel HD 2500 ? :)
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 11 Jul 2015, 20:03
u can see here a possible solution
gunsize
GPU: Intel HD 2500
Post by gunsize » 12 Jul 2015, 11:14
Damnnn...I better look for an HD5850 because i sold my HD7790...or get a macbook instead later this year.
samiljak
CPU: Intel Core i7-3770
Motherboard: Asus P8H77-M PRO
GPU: NVIDIA GeForce GTX 960
Post by samiljak » 26 Jul 2015, 16:00
Hello,
I'm trying to install Yosemite from your bootable USB, but I get stuck at this screen:
Apparently is the "famous" Missing Bluetooth Controller Transport, but I've tried the method posted in "Common problems":
fsck -fy
mount -uw /
mkdir /kext_backup
cd /System/Library/Extensions
mv AppleIntelHD* AppleIntelSNB* AppleIntelFramebuffer* AMD* ATI* GeForce* NVDA* /kext_backup
kextcache -prelinked-kernel
reboot
And I'm still stuck at the same screen.
What should I do?
Sorry, I'm completely new to this and I don't know a thing... :S
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 26 Jul 2015, 18:42
have u try to boot in safe mode
-x
samiljak
Post by samiljak » 26 Jul 2015, 18:48
Yes, I've just tried that, but it gets stuck at the same point... is there any other thing that I could try?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 26 Jul 2015, 19:17
u can try remove the nvidia .. and try to install with onboard graphics
samiljak
Post by samiljak » 26 Jul 2015, 20:36
I tried but no luck, still stuck at the same point.
I removed my gtx 960 and tried both normal and safe boot, but it didn't work.
It usuallly gets on hold like 20 secs on the previous line... I don't know if that could mean anything...
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 26 Jul 2015, 21:45
try to google for ur hardware ...
and see if anyone have that issue.. i don't have ur hardware .. can test it
samiljak
Post by samiljak » 26 Jul 2015, 21:47
Ok, should I google my CPU, my motherboard, gpu... which of them could be causing the issue?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 26 Jul 2015, 22:01
nvidia and mobo
check first mobo .. is little old .. never good idea mix new hardware with old ..
samiljak
Post by samiljak » 27 Jul 2015, 08:25
Mmmmm you mean that if I try a previous version of OS X that might work?
samiljak
Post by samiljak » 02 Aug 2015, 22:56
I finally managed to install Yosemite 10.10 and update to 10.10.4.
If anyone has the same hardware as me, the solution is to boot the installer with the flags dart=0 and nv_disable=1 (apart from the ones that come by default in clover).
When you finish to install it, you will notice it will seem quite slow... that's because the graphic card is disabled. Install all the drivers with multishit and upgrade to 10.10.4 via the App Store. Reboot and then download the Nvidia alternate graphic drivers from here:
Reboot and select the Nvidia graphics instead of the Mac OS native (you can do it by pressing the new icon in the upper bar). Reboot and you'll notice everything goes smoother.
I had problems with the audio, in my case Realtek ALC892. The issue can be solved by installing generic drivers and not the Realtek ones. Just follow these instructions:
Hope that helps someone! :)
Ahmed M.Osman
CPU: Toshiba C55
Motherboard: intel inside core 5i
GPU: Toshiba C55
Post by Ahmed M.Osman » 10 Aug 2015, 16:33
hallo all :)
im trying to install this ( raw ) format on my toshiba C55 :
intel core i 5
4GB ram
AMD 1GB graphic card
500 GB hard disk
i can't reach installing screen :
i change my BIOS sitting to :
CSM boot NOT UEFI boot
security boot is disabled
but nothing happened ,, loading screen and reboot ,,
here is the video which is happening
:oops: :oops: :oops: :oops: :oops: :oops:
please help
zodywoolsey
CPU: intel pentium g3258
Motherboard: msi H81M-P33
GPU: Radeon hd 7850
Post by zodywoolsey » 15 Aug 2015, 18:46
My system stops at xcpm: registered.
Return to “Yosemite (10.10)”
