OS X Yosemite 10.10 bootable USB for Intel PCs
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 04 Nov 2014, 23:39
-Download
- Copy the .raw file to an USB stick
For Windows
or
If you have error during copy, eject and re-connect the pen drive. When Windows asks if you want to format it, cancel and run Image Writer again.
If the problem persists, disable your anti-virus software, it may be blocking raw write to the drive.
For OS X
- Boot the USB drive and install.
Default boot loader is Clover
If you want to use Chameleon press 1 at boot
UEFI boot is for Aptio BIOS only. For other BIOS use legacy boot to install, you can fix UEFI boot later
Common problems booting the installer
You need at least one free partition, use Disk Utility (in the Utilities menu) to erase it as Mac Os Extended (Journaled).
If you want to install the boot loader in this partition and you use MBR, it must be a primary (not extended/logical) partition.
Wait for the installation to finish and restart.
- Boot the USB drive, then choose to boot the HD you just installed OS X (not the installer USB again).
Post install instructions
The boot argument (kernel flag) kext-dev-mode=1 allows unsigned kexts (or with invalid signature) to be included in kernelcache. That means you need this argument to be able to install patched or unsigned kexts in /System/Library/Extensions. If you put those kexts in EFI/CLOVER/kexts/10.10 this parameter is not necessary.
- When you format the USB drive as FAT/NTFS you'll notice its size was reduced. Just open Disk Management (Administrative Tools), remove the 7 GB partition and create a new one using all the drive.
saifulapm
CPU: Dell N4050
Motherboard: Intel
GPU: Intel HD 3000
Re: OS X Yosemite 10.10 bootable USB for Intel PCs
Post by saifulapm » 06 Nov 2014, 23:22
Hello,
My Laptop is Dell n4050 i3 .
Graphics: Intel HD 3000
I can't reach the Installer screen.
I tried with dart=0, npci=0x200, npci=0x3000, PCIRootUID=0 also 1, -f, -x,
I also tried moving kext.
But al last i failed.
Please help me. See this when i enable usb ownership
Please help.
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 06 Nov 2014, 23:41
try to use
USBBusFix=Yes
and use usb2 port
saifulapm
CPU: Dell N4050
Motherboard: Intel
GPU: Intel HD 3000
Post by saifulapm » 07 Nov 2014, 10:50
Using USBBusFix=yes in clover, i got same result.
But using USBBusFix=Yes in chemelon, I have successfully installed Yosemite In my Dell n4050.
I also installed all kext and everything working fine.
But i have one problem. I have a wimax usb modem. When i insert usb modem , then installer coming. I have installed this modem apps and open this modem app but there no modem found.
Please help me. why modem not detecting .
Please help me.
thanks
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 07 Nov 2014, 11:06
u must read .. this is not windows install .. take a time and read the info present here in forum ..
USBBusFix=Yes is a chameleon flag
something for clover is not the same way
u don't start to install a advanced operating system .. and don't know nothing about .. what is a boot loader .. how it works .. what is the commands..
saifulapm
CPU: Dell N4050
Motherboard: Intel
GPU: Intel HD 3000
Post by saifulapm » 08 Nov 2014, 05:49
Thanks . Finally I have done.
But what about my WiMax USB Modem. This is not detecting. Can anyone Help me.
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 08 Nov 2014, 08:36
what is that ? a wifi usb pen ?
not all are supported by os x .. it have drivers for mac os x ?
maybe u need to buy a supported wifi usb pen..
In-versemn
CPU: E5300
Motherboard: idk Probably Dell's cheap MB
GPU: Geforce G210 256mb
Post by In-versemn » 09 Nov 2014, 14:37
Hello. I'm trying to install Mac OS X on my Dell Optiplex 380 PC.every time I boot the installer it shows me this. My motherboard only supports IDE and no option to AHCI but I managed to put IDE Compatible IOATAFAMILY.kext in the USB using Ubuntu. I think there is no problem with IDE since I was able to boot to leopard snow leopard and lion. Someone help me
koske
Post by koske » 13 Nov 2014, 22:47
Hello,
Does someone can help me with the following: USB Legacy Off Done
When I try to install Yosemite via Cameleon bootloader PC is constantly being reset.
I was trying to type into the Chameleon bootloader following flags:
-v -x -f
-x -v-f
GraphicsEnabler=Yes PCIRootUID=0 darkwake=0 dart=0
GraphicsEnabler=Yes PCIRootUID=0 -v
USBBusFix=Yes npci=0x2000
-v kext-dev-mode=1
...and many more combinations, always reset PS.
Send and display pictures and where exactly is restarted PC
I currently have installed OS X Mavericks 10.9.4 with unishit method
My spec:
Mobo: GAEP-45DS4 f10 bios (latest)
Processor: Intel Q6600 @ 2.4ghz Core2Quad
VGA: GeForce 9800 gainward 1024MB
memory: 8GB kingston
Any ideas?
thanks all
koske
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 13 Nov 2014, 23:12
have u check ur bios set for usb ?
Chucky
CPU: Intel Core i3 4150 3.5GHz
Motherboard: ASUS BM85-E
GPU: ZOTAC NVIDIA GTX-750ti 1GB
Post by Chucky » 15 Nov 2014, 09:53
Hi,
I tried to install on PC, but it restarts back to Clover right after the screen as shown in the attachment.
Please let me know what the error is.
Many thanks!
koske
Post by koske » 15 Nov 2014, 18:48
thanks, but why Yosemite freezes after an hour and a half or two of work.
Everything is working, but i've have random freeze when watching youtube video.
I will try to install 10.10.1, it's not the graphics driver may?
Any Clues?
thanks
kidimon
CPU: i3 2120
Motherboard: p8-h61 m/le
GPU: gtx650 ti
Post by kidimon » 09 Dec 2014, 16:21
Hi everything is great and yosemite rezognized mine gtx 650 it out of the box but i have problem that my apple wired keaboard dont work on hackintosh and dont even show up in bios but works fine on wifes windows machine. Any ideas how to fix this?
mendietinha
CPU: i5 750
Motherboard: Intel
GPU: GTX760
Post by mendietinha » 09 Dec 2014, 17:30
dont show up in bios?
what do you mean?
malik22
CPU: 4770k
Motherboard: asus maximus hero
GPU: 290x
Post by malik22 » 24 Dec 2014, 12:07
Hello guys im trying to install threw usb and get this error all the time.
vimrul
CPU: Intel Core i5 (3rd Gen) 3210M
Motherboard: Mobile Intel HM76 Express
GPU: Intel HD Graphics 4000
Post by vimrul » 28 Dec 2014, 18:32
hello, I am using HP Probook 4440s. My specs:
How can can I install yosemite? I dont have any mac book to cerate an USB :(
pernacabeluda
Post by pernacabeluda » 28 Dec 2014, 19:54
malik22 wrote:Hello guys im trying to install threw usb and get this error all the time.
USB 3.0 chipset Intel Series 7/Panther Point
vimrul wrote:How can can I install yosemite? I dont have any mac book to cerate an USB :(
Read instructions for Windows in opening post.
honeytung
CPU: Intel Core i7-4702MQ 2.2GHz
Motherboard: Acer Aspire V3 772G
GPU: Nvidia GTX 760M 2GB GDDR5
Post by honeytung » 23 Jan 2015, 04:55
Hi,
I have been trying to install 10.10 and I fixed some errors by following the Common Problems.
enabled the kernel_pm_patch, the infinite reboot stopped
added -gux_defer_usb2 -gux_no_idle in Boot Args and it fixed the "still waiting for root device"
moved video kexts from single user and it fixed the Missing Bluetooth Controller Transport message
But now I have encountered a new problem that is not in the Common Problems
When trying to boot the installer, an error message appeared:
"com.apple.xpc.launchd[1] (com.apple.securityd127) <notice>: service exited due to signal: Abort Trap: 6"
My Computer Specs:
Model: Acer Aspire V3 772G (Laptop, 17.3'')
Processor: Intel i7 4702MQ Quad core @ 2.2GHz
Video: Nvidia GTX 760M 2GB GDDR5 with Intel HD Graphics 4600
RAM: 12GB 1600MHz (4GB+8GB)
Can anyone help me?
Thanks!!
sumek80
CPU: X9100
Motherboard: 0X564R
GPU: NVIDIA Quadro NVS160M
Post by sumek80 » 05 Mar 2015, 09:28
Dell E6500
CPU: X9100
GPU: Nvidia Quadro NVS 160N
RAM: 4GB
Mainboard: 0X564R
Bios: A29
HDD: 250GB
Bluetooth: Dell Wireless 370
LAN: Intel 82567LM Gigabit
Wi-FI: Intel 5300 AGN
3G Modem: Dell DW5560
Other: Control Valut w/Fingerprint Swipe Sensor
Hdd only for OS x 10.10, boot from pendrive ok, Clover - booting failed, stop on bluetooth when detect.
Chameleon boot line command:
-v -x -f
-x -v-f
-v kext-dev-mode=1
Stop on Backtrace - look on attachment
Any solution for this problem how to?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 05 Mar 2015, 10:26
try to use another fakesmc.kext
Return to “Yosemite (10.10)”
