asus p5q deluxe
zeg66
CPU: Ivy Bridge i7-3770
Motherboard: GA-Z77-HD3 bios F1
GPU: HD4000
asus p5q deluxe
Post by zeg66 » 08 Aug 2018, 19:47
Sorry that didn't work. Found this kext:
and installed it with Kext Utility. Yes the Ethernet appears to work (the port LEDs are on) but now the nVidia installation is broken. I can only boot with nv_disable=1 flag. How can I repair the nVidia installation?
Could this be a problem with AppleKextExcludeList.kext? Should I try a newer Clover version? Using 3333 now.
zeg66
GPU: HD4000
asus p5q deluxe
Post by zeg66 » 14 Aug 2018, 18:51
Could you please tell me how to activate the ALC883 (six connectors) onboard audio in Mavericks 10.9.5?
asus p5q deluxe
Post by MaLd0n » 14 Aug 2018, 19:28
u try a applehda patcher?
zeg66
GPU: HD4000
asus p5q deluxe
Post by zeg66 » 14 Aug 2018, 20:16
thank you for your reply, Mald0n. I will try version 1.8 (version 1.9 does not support Mavericks) and report back. Which ioreg version should I use with 10.9.5?
asus p5q deluxe
Post by MaLd0n » 14 Aug 2018, 20:47
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] thank you for your reply, Mald0n. I will try version 1.8 (version 1.9 does not support Mavericks) and report back. Which ioreg version should I use with 10.9.5?
zeg66
GPU: HD4000
asus p5q deluxe
Post by zeg66 » 14 Aug 2018, 21:20
Used applehdapatcher 1.8, chose desktop alc883 id:7 and it created a MironeAudio folder on the desktop. Edited config.plist to add dict's and audio entry. Installed patched applehda.kext to s/l/e with kext utility. still not working. have I forgotten something?
asus p5q deluxe
Post by MaLd0n » 14 Aug 2018, 21:31
i think no
post in applehda patcher topic
zeg66
GPU: HD4000
asus p5q deluxe
Post by zeg66 » 14 Aug 2018, 22:10
is that topic here in olarila? by the way I am not sure I have ALC883 after all. This is the audio system in more detail:
Intel Corporation 82801H (ICH8 Family) HD Audio Controller [8086:284b]
It's working! Turns out it is ALC888, not 883, this is so weird, the mobo manufacturer website has wrong info, wow !!!
applehdapatcher worked fine, installed (patched) applehda.kext, codeccommander.kext and hdaenabler.kext with Kext Utility in S/L/E and didn't edit config.plist.
maybe there is a better method with dsdt/ssdt patching but I don't know how to do that.
asus p5q deluxe
Post by MaLd0n » 14 Aug 2018, 22:31
for audio u can use it withouyt any problem, DSDT is for a fine tune, put hack like one real mac
zeg66
GPU: HD4000
asus p5q deluxe
Post by zeg66 » 14 Aug 2018, 22:46
yes I know that you are an expert in dsdt/ssdt editing.
I don't see the nvidia hdmi audio out device (only onboard audio) and when I shut down the cpu fan doesn't stop. would you like me to provide dsdt/ssdt and maybe other files for you to take a look at?
asus p5q deluxe
Post by MaLd0n » 14 Aug 2018, 22:48
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests] yes I know that you are an expert in dsdt/ssdt editing.
zeg66
GPU: HD4000
asus p5q deluxe
Post by zeg66 » 14 Aug 2018, 23:16
ioreg dump failed, retrying.... (this is Mavericks).
Perhaps there is an older version of Runme.app that works in 10.9, for us who don't like flat icons that much ;-)
asus p5q deluxe
Post by MaLd0n » 14 Aug 2018, 23:56
oh yes, extract dsdt and ioreg
zeg66
GPU: HD4000
asus p5q deluxe
Post by zeg66 » 15 Aug 2018, 05:50
Here they are:
zeg-mac-pro.zip
asus p5q deluxe
Post by MaLd0n » 15 Aug 2018, 16:00
[Local Link Removed for Guests] wrote: [Local Link Removed for Guests]Here they are:
MagicNAS
CPU: Intel i7 3770k
Motherboard: GA Z77H-UD5H
GPU: HD 4000
asus p5q deluxe
Post by MagicNAS » 25 Jan 2019, 19:20
Can somebody help me with sleep in Mojave, I put DSDT.aml in clover folder, set darkwake 0/1/2 nothing. Hack goes to sleep but when I press keyboard or mouse nothing happens, when I press button on the pc case, fans turn on but monitor is black.
Bios settings:
POWER
SUSPEND MODE [s3 ONLY]
REPOST VIDEO ON S3 RESUME [YES]
ACPI 2.0 SUPPORT [ENABLE]
ACPI APIC SUPPORT [ENABLE]
Return to “Mavericks (10.9)”
