OS X Mavericks 10.9.5 bootable USB for Intel PCs
pernacabeluda
Re: OS X Mavericks 10.9 GM bootable USB for Intel PCs
Post by pernacabeluda » 18 Oct 2014, 17:57
mew wrote: I can't get it even to Clover (the USB sticks run fine on other PCs, but on this one it simply skips the drive.....
Tried booting from a bootmanager on USB stick (PLOP) however I get an error that the drive doesn't contain a valid boot sector signature ( i've tried 10.9 image, 10.9.5 and 10.10)
Try setting your BIOS to boot legacy instead of UEFI.
vorloc
CPU: Core i5
Motherboard: ASUS
GPU: GT 520
Post by vorloc » 20 Oct 2014, 18:03
Hi
I also happen to get stuck while booting from chameleon, installed to the OS X partition.
I get stuck at the
iobluetoothhcicontroller completed
like many around :!:
But i have tried everything given in order to get it to work,
  • :arrow: I moved the graphics kexts(even the bluetooth kexts)
  • :arrow: I tried the safe mode,
  • :arrow: i tried every switch for the boot ( -x -v -f GraphicsEnabler=No),
  • :arrow: i even tried changing the chameleon revision to an older one (rev 2266)
  • :arrow: Also installed the two FakeSMC and the null... kexts
But none of those seem to help :cry: .
The problem here is, I CAN STILL boot from the installation USB and select the primary partition where OS X is installed. That way, it works! but I will have to have the USB with me at all times.! (Chameleon 2.2 rev 2266 is in the USB, that is why i tried a downgrade earlier in the OS)
also even though i can boot up with the help of the USB, i still can't get my ethernet, bluetooth, wireless or audio working.
:idea: I wanna know if I can somehow make the bootloader and it's config as it is in the USB installation media.
Please help me out.. :cry: :/
I'm on an inspiron 15R (N5110) by Dell,
it has a GT 525M video card, core i5 2.5GHz processor.
Zer01neDev
CPU: Intel Core i5 4690K
Motherboard: MSi Z97-G45 Gaming
GPU: Radeon HD 6450 1GB DDR3
Post by Zer01neDev » 26 Oct 2014, 16:30
i have a problem for installing [Local Link Removed for Guests] on my computer.
it Freezing on Blutooth related device.
Its show another line after said iTune/AppleStores, error blahblahblah a,d freeze.
Kuvar
CPU: i5-2450M
Motherboard: Intel PCH HM67Dell Vostro 3550
GPU: ATI Mobility Radeon HD 6630m
Post by Kuvar » 27 Oct 2014, 12:36
Can I install this on Original macbook pro 2008 model,If yes then As normal Procedure or something else . On macbookpro currently I have windows 7 installed fully,means no mac partition or boot camp etc.
Thnx in advance :?
Dell Vostro 3550, i5-2450M(2.50 GHz-Turbo Boost3.10 GHz) , RAM - 4 GB , Graphic - ATI Mobility Radeon HD 6630m 1GB(Switchable Graphics) , Chipset Intel PCH HM67, Yosmite 10.10/ Win 8.1 Pro x64/ Dualboot Chamelionwizard
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 27 Oct 2014, 14:03
little google it help
vojkan7
CPU: Intel i5
Motherboard: Gigabyte H55M-UD2H
GPU: Nvidia GTS 450 1GB
Post by vojkan7 » 01 Nov 2014, 12:29
Hi ,I have problem please help me! :( When I boot wih usb os x Yosemite
pernacabeluda
Post by pernacabeluda » 01 Nov 2014, 12:35
Hi,
try to enable USB fixes in Clover options menu.
erdem555
CPU: q6600
Motherboard: Gigabyte GA-P35-DS3P rev2.1
GPU: gt8800
Post by erdem555 » 13 Dec 2014, 17:42
I completed install mavericks succsessfuly. It's working But didn't boot directly from HDD. I have to use usb stick for boot and select HDD boot option in the usb stick.
But I want to boot directly from HDD. I don't want to use USB stick. How can I do?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 13 Dec 2014, 18:21
install a boot loader in the hd
QueenOfHearts
CPU: i7-4790k
Motherboard: Asus Z97-A
GPU: GTX 750Ti
Post by QueenOfHearts » 17 Dec 2014, 19:56
Hi,
I have tried using the Olarila USB images for both, Yosemite and Mavericks but I get stuck before I reach the installer.
I've followed all the bios settings recommended.
The first problem that I had was getting stuck at PCI Configuration begin but I fixed that by booting with npcx=0x1000.
Now I'm stuck at "Still waiting for Root device"
Things I've tried and didn't work:
-Using -gux_defer_usb2 and -gux_no_idle flags but it didn't work.
-Enabling the USB Ownership in clover also did not work.
-Using only one Memory Stick
-Using maxmen=4096
Could anyone help me please? Attached is the error screen.
My system is:
Core i7-4790k
Asus z97-A
GTX 750 Ti
16gb RAM
Thanks!
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 17 Dec 2014, 20:01
see minimum options in ur bios
and that nvidia .. go give u problems
QueenOfHearts
CPU: i7-4790k
GPU: GTX 750Ti
Post by QueenOfHearts » 17 Dec 2014, 20:28
I already followed the settings provided in that post for bios but it's still the same error :/
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt » 17 Dec 2014, 23:34
try remove from installer
GenericUSBXHCI.kext
u boot from clover
so must access efi folder
clover/kext
QueenOfHearts
CPU: i7-4790k
GPU: GTX 750Ti
Post by QueenOfHearts » 19 Dec 2014, 02:37
I'm trying to use Transmac to remove the kext from my USB but Transmac cannot see my USB. I tried it on two different USB and it still cannot see the Install USB in Windows 7. Any solutions to this?
**EDIT**
Okay I was able to get Transmac to read the install USB but I can't find the EFI/Clover folder :(
This is the Olarila bootable USB image.
pernacabeluda
Post by pernacabeluda » 19 Dec 2014, 11:48
Use the EFI shell.
fs0:
cd EFI\CLOVER\kexts\10.10
rm -r GenericUSBXHCI.kext
QueenOfHearts
CPU: i7-4790k
GPU: GTX 750Ti
Post by QueenOfHearts » 19 Dec 2014, 14:31
Thanks! I was able to remove the kext but still doesn't boot. I'm still getting stuck at the same screen :/
malik22
CPU: 4770k
Motherboard: asus maximus hero
GPU: 290x
Post by malik22 » 24 Dec 2014, 11:58
Hello guys im trying to install threw usb and get this error all the time.
pernacabeluda
Post by pernacabeluda » 25 Dec 2014, 00:45
omisayeee
CPU: intel core i3 370m
Motherboard: hewllet-packard 144a
GPU: intel graphics
Post by omisayeee » 17 Jan 2015, 22:45
Hi all this tutorial's looks simple to me but when i tried it, is another thing all together.
First : i downloaded image-writer and used it to copy OS x to my 62g flash. i tried to dual boot my hp pavilion dv6, selected my 62g flash i copied OS x ,press space bar in Clover and selected booting in single user mode...
when the clover tried to proceed to installer i got this error nanoseconds 121212183311......
please if you wouldn't mind could you help me to get away from this challenge, this have kept me from learning how to develop OS App for two good months now.thank for your help.
J_Marley
CPU: Intel i7 4.0GHz
Motherboard: ASUS Maximus Hero VI
GPU: NVidia Geforce GTX 750 Ti
Post by J_Marley » 18 Feb 2015, 03:33
Okay, I apologize ahead of time as I'm betting this has been answered before, but I am a complete noob when it comes to anything hackintosh related. I have usually had either a Mac or a PC and this is my first system build trying to run both off the same machine. I am able to boot from the USB drive into Clover, but when I select to Boot the Mac OSX from the USB to install I get a terminal screen (or DOS like screen) that starts rattling through a bunch of language I don't understand, shows a few errors, and then I get a large white circle with a line through it in the middle of the page before the text on the screen all starts to merge together. I am completely lost as to what to do and how to install the OSX onto the secondary HDD I have installed in the computer.
Current Computer specs from Everest:
Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
ASUS MAXIMUS VI HERO Motherboard
NVIDIA GeForce GTX 750 Ti (2048 MB)
WDC WD10EZEX-00BN5A0 (931 GB) x2 (one for Windows 8.1 and the other hopefully for OS X)
16GB DDR3 1600 (8GBx2)
Return to “Mavericks (10.9)”
