How to get SMBios MacBookPro8,2 working on my Asus G73sw?
FCU4ever
CPU: Intel Core I7 2630 QM 2.0GHz
Motherboard: Mobile Intel HM65 Express
GPU: Nvidia GeForce GTX 460M 1.5 GB
Post by FCU4ever » 16 Mar 2019, 10:23
I succesfully installed MacOS Sierra 10.12.6 on my Asus G73sw laptop with the MacBookPro10,1 SMBios. My Hackintosh also work with the MacBookPro10,1 SMBios. The problem is that MacBookPro10,1 is for “Ivy Bridge” laptops and not for “Sandy Bridge” like mine.
My Asus G73sw laptop has an Intel I7-2630QM processor and a Nvidia GTX460m videocard. The SMBios that comes close to my specifications is the MacBookPro8,2 SMBios. I changed the SMBios to MacBookPro8,2 with CloverConfigurator, copied the config.plist to my EFI folder and reboot -> black screen.
Then I tried a few things to get the MacBookPro8,2 SMBios working:
- Changed the SMBIOS to MacBookPro8,2 and add the below to KextToPatch
com.apple.driver.AppleGraphicsDevicePolicy
BA050000 00
BA000000 00
Prevent AGDP from loading
Reboot -> Apple bar won’t load
- Changed the SMBIOS to MacBookPro8,2 and changed productname to iMac13,2
Reboot -> Apple bar load but get a blackscreen
- Changed the SMBIOS to MacBookPro8,2 and changed productname to iMac13,2 and add the below to KextToPatch
BA050000 00
BA000000 00
Reboot -> laptop boots good
So the laptop boots with the MacBookPro8,2 SMBios when I changed the productname and add a few lines to my kextToPatch. Changing the productname isn’t the right solution I think.
Can someone help me to get the MacBookPro8,2 SMBios working or is it no problem to stay on MacBookPro10,1 SMBios? Even this SMBios is for Ivy Bridge laptops and not Sandy Bridge.
Post by MaLd0n » 16 Mar 2019, 12:20
use a MacBookPro10,1 and generate new SSDT with pike script, u see a warnings, just ignore
check if work good, pm etc
FCU4ever
Post by FCU4ever » 17 Mar 2019, 09:22
In Clover I've set generate P-states and C-states. Does this the same as the SSDT generated by pike? Our is it better to use the SSDT generated with pike script?
Post by MaLd0n » 17 Mar 2019, 11:33
FCU4ever, sandy bridge and ivy bridge i use SSDT from Pike, much better
FCU4ever
Post by FCU4ever » 19 Mar 2019, 17:34
MaLd0n, thanks for your reply. I just generated the SSDT with Pike. First ignored the error Image
and let the script run. After finish I went to the export map and see a lot of SSDT files. Wich one do I have to copy to my Clover folder?Image
Post by MaLd0n » 19 Mar 2019, 17:50
FCU4ever, send me this file
FCU4ever
Post by FCU4ever » 20 Mar 2019, 17:08
Here is the file ;)
Post by MaLd0n » 20 Mar 2019, 18:43
FCU4ever,
SSDT.aml.zip
FCU4ever
Post by FCU4ever » 20 Mar 2019, 19:38
MalD0n, many thanks for the file! Can I use this file in combination with the generate P-states and C-states in my config.plist or do you recommend to uncheck this boxes with clover configurator in my config.plist?
Post by MaLd0n » 20 Mar 2019, 21:31
FCU4ever, uncheck, ssdt have it
FCU4ever
Post by FCU4ever » 21 Mar 2019, 11:21
MaLd0n,
Many thanks for your help, I will uncheck it.
FCU4ever
Post by FCU4ever » 23 Mar 2019, 12:41
MaLd0n,
See the output of terminal with the SSDT.aml you send me and P- and C states unchecked.
Post by MaLd0n » 23 Mar 2019, 13:33
FCU4ever, not perfect p states, but work good, c3, c6, c7
