problem on hp probook 450 cuting in pointer move when working
yassernono2000
CPU: i7
Motherboard: hp
GPU: intel uhd 620
Post by yassernono2000 » 15 Feb 2019, 07:34
my system is work well ,but when move pointer or working in system Notes cuting move ,don't Quick response for move pointer
help me plz for catch my error and fix it
Allan
CPU: i5-3210M
Motherboard: InsydeH20
GPU: IntelHD 4000
Post by Allan » 15 Feb 2019, 18:33
How did you had installed your macOS?
yassernono2000
CPU: i7
Motherboard: hp
GPU: intel uhd 620
Post by yassernono2000 » 17 Feb 2019, 06:38
thanks for reply ,my system is well work everything ,but my tarkpad is based driver i cant control it , i want fix the problems only ,plz help me do it , i have anther hard ntfs , but i am instaing my system in APFS
yassernono2000
CPU: i7
Motherboard: hp
GPU: intel uhd 620
Post by yassernono2000 » 17 Feb 2019, 07:56
i catching some error but i cant fix it
onemanosx
Post by onemanosx » 17 Feb 2019, 10:21
Your patch may not be correctly implemented for I2C trackpad. Is the trackpad working?
Upload a full dump of your system using Run_me app.
MSI B360 Gaming Arctic
yassernono2000
CPU: i7
Motherboard: hp
GPU: intel uhd 620
Post by yassernono2000 » 17 Feb 2019, 14:33
thanks for reply
onemanosx
Post by onemanosx » 17 Feb 2019, 14:57
yassernono2000,
1. You have unnecessary and outdated applebacklight kexts. Whatevergreen has backlight brightness feature.
2. For trackpad, its either you use voodooi2c kexts or applePs2smartouchpad kext. not both.
3. I dont know why you even have voodoops2controller kext and where you got your voodoops2trackpad since you are using appleps2smartouchpad kext
4. You should clean up your usb injector kexts to suit your laptop
5. You should clean up your ethernet kexts to suit your laptop
My suggestion,
1. delete all voodooI2C kexts and only use appleps2smartouchpad kext and see if trackpad works.
2. delete voodoops2controller and voodoops2trackpad kext
3. delete all applebacklight injector kexts
4. delete AtherosE2200ethernet, IntelMausiEthernet and realtek8100 kexts
5. delete nullcpupowermanagement kext
6. delete origin.dsl
7. delete SSDT-ACPIBATT.dsl
8. delete SSDT-BATC.dsl
yassernono2000
CPU: i7
Motherboard: hp
GPU: intel uhd 620
Post by yassernono2000 » 18 Feb 2019, 11:51
thanks for reply, i will do
onemanosx
Post by onemanosx » 18 Feb 2019, 12:34
yassernono2000, report back if you face issues ;)
yassernono2000
CPU: i7
Motherboard: hp
GPU: intel uhd 620
Post by yassernono2000 » 20 Feb 2019, 20:08
thanks for Interest :D
full dump
i think move the pointer is better now , i dont know if there any error or not ,i use some fix in my config.plist
but i cant control or custom trackpad for example i want open menu (secondary click) by two finger not three i cant change it by system preference or other application ,when use other app i dont found name trackpad
onemanosx
Post by onemanosx » 20 Feb 2019, 23:23
yassernono2000, use only needed kexts in clover> kexts> other. Not in all version folders with many more conflicting kexts.
No idea with using third party app for gestures.
