[Guide] - Brightness Hotkey Remapping
onemanosx
Post by onemanosx » 07 Sep 2019, 07:58
06 Sep 2019, 15:17
but I'm still unable to map my brightness keys
Upon finding your EC method for brightness keys, did you proceed to the next step of patching DSDT?
MSI B360 Gaming Arctic
raelee
CPU: i5 - 5200U
Motherboard: Acer E5-473G-52FG
GPU: Nvidia GeF 940M+Intel HD5500
Post by raelee » 07 Sep 2019, 09:07
Hi onemanosx, I did patch my DSDT but forgot to edit _QD, QC :hammer ...now got my brightness keys mapped properly :cap , been looking for this kind of tutorial, hope you can make one for native power management cause my battery drains very fast, thank you for kind help, you guys are awesome! kudos to MaLd0n as well :guitar :guitar :guitar
onemanosx
Post by onemanosx » 07 Sep 2019, 09:13
07 Sep 2019, 09:07
Congrats! You may check out Useful Links for power management guide and others
raelee
CPU: i5 - 5200U
Post by raelee » 07 Sep 2019, 12:42
07 Sep 2019, 09:13
Sorry to bother you for the off topic again, but can you shed some light where should I start to make my battery works normal? one full charge only drains less half an hour :cry:
onemanosx
Post by onemanosx » 07 Sep 2019, 12:48
raelee, I use CPUFriend + CPUFriendDataProvider kexts for my laptop. Works great.
mut0u
CPU: i7-8565u
Motherboard: Dell-Inspiron-15-7580
GPU: UHD Graphics 620
Post by mut0u » 30 Sep 2019, 06:52
@onemanosx
Hi
After completing the guide I got EC Q66 and was F11 and F12,Have any suggestions
onemanosx
Post by onemanosx » 30 Sep 2019, 07:44
30 Sep 2019, 06:52
@onemanosx
Hi
technically, you should have 2 EC methods. One for increase and another for decrease. I suggest you check your work again.
You can also paste the below code into terminal. The result will tell you which EC methods are being used.
log show | grep -i acpidebug
mut0u
CPU: i7-8565u
Post by mut0u » 30 Sep 2019, 12:31
Hi
I tested many times
Fn+F11 decrease, Fn+F12 increase.
Is EC Q66
How do I upload an image?
If you don't mind
onemanosx
Post by onemanosx » 30 Sep 2019, 13:15
30 Sep 2019, 12:31
use imgur
Upload your sendme files
mut0u
CPU: i7-8565u
Post by mut0u » 30 Sep 2019, 14:40
Please check Attachment
onemanosx
Post by onemanosx » 30 Sep 2019, 14:53
mut0u, Please upload your EC method terminal image
mut0u
CPU: i7-8565u
Post by mut0u » 30 Sep 2019, 15:11
sorry,
Please check
hxxps://[External Link Removed for Guests]
mut0u is me my image
onemanosx
Post by onemanosx » 30 Sep 2019, 15:16
mut0u, Check if this works.
mut0u
CPU: i7-8565u
Post by mut0u » 30 Sep 2019, 15:29
No working
onemanosx
Post by onemanosx » 30 Sep 2019, 15:29
mut0u, Try again with this.
DSDT-02.aml.zip
mut0u
CPU: i7-8565u
Post by mut0u » 30 Sep 2019, 15:50
No working
onemanosx
Post by onemanosx » 30 Sep 2019, 15:58
mut0u, Does press F11 and F12 only affect anything or Fn+B & Fn+S
Anyways, one more try
Actually, there's 2 but lets try this first
mut0u
CPU: i7-8565u
Post by mut0u » 30 Sep 2019, 15:59
before,I used ssdts on working
onemanosx
Post by onemanosx » 30 Sep 2019, 16:02
mut0u, I just realised you enabled OSI to XOSI patch. That is not required. Disable it and try again with the DSDT.
Your SSDT has similar BRT6 patch.
mut0u
CPU: i7-8565u
Post by mut0u » 30 Sep 2019, 16:04
YES
fn+B and fn+s on working
You can switch to F11 and f12?
