[Guide] - SSDT with Pike's PM Script and use with CPUFriend
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 26 Jun 2019, 01:37
No support for mobile processors? :(
onemanosx
Post by onemanosx » 26 Jun 2019, 02:12
26 Jun 2019, 01:37
Laptops and Desktops with Intel processors are supported
MSI B360 Gaming Arctic
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 26 Jun 2019, 03:47
26 Jun 2019, 02:12
I was found out that the Coffe Lake data file does not have the i7 8750h, what should I do then?
onemanosx
Post by onemanosx » 26 Jun 2019, 04:28
26 Jun 2019, 03:47
read second post
janjao
CPU: i3 6100
Motherboard: gigabyte H110M
GPU: GT 710
Post by janjao » 20 Jul 2019, 20:41
Is this necessary?
Post by MaLd0n » 20 Jul 2019, 21:41
janjao, for mobiles ye, desktop don't need it, but u can use too
futuramexico
CPU: 8750H Dell G3 17
Motherboard: HM370 Chipset
GPU: Intel UHD Graphics 630 1536 MB
Post by futuramexico » 29 Aug 2019, 02:46
15 Apr 2019, 16:55
osxfr33k
HI , Here the same problem, I have dell g3 i7 8750H, 17 inch, you find the solution ? Im on Mojave 10.4.6
raelee
CPU: i5 - 5200U
Motherboard: Acer E5-473G-52FG
GPU: Nvidia GeF 940M+Intel HD5500
Post by raelee » 07 Sep 2019, 23:34
onemanosx, my battery still drains very fast. SSDT copied on clover/acpi/patch. CPUFriend.kext and CPUFriendDataProvider.kext on kext/other folder. But upon checking on IOREG I cannot see cf frequency, can you tell me how to fix that, thank you.
Edit; I think I finally I got it sorted :crazy: , thank you for detailed guide :cap :guitar
onemanosx
Post by onemanosx » 08 Sep 2019, 02:33
07 Sep 2019, 23:34
Great! On other note, you might want to have EC0 to EC rename to load "AppleBusPowerController" i.e Apple's USB power properties
raelee
CPU: i5 - 5200U
Post by raelee » 08 Sep 2019, 02:51
08 Sep 2019, 02:33
do you mean from my config.plist?
onemanosx
Post by onemanosx » 08 Sep 2019, 02:56
08 Sep 2019, 02:51
Yes.
Rename EC0 to EC
Find: 45 43 30 5F
Replace: 45 43 5F 5F
osxfr33k
CPU: i9-9900k
Motherboard: Asus Z390-E Gaming
GPU: AMD RX 590 8gb
Post by osxfr33k » 06 Oct 2019, 03:43
Is this method for CPU after first generation i7? I have a i7-920m CPU can I use this method for that CPU?
OP-LP3 OverPowered Laptop 17 inch, i7-8750H, 32GB memory, 256GB NvMe stock with windows 10 and added 512GB NvMe Samsung 970 Pro with MacOS 10.14.6. Asus G750JX Laptop with Nvidia GTX770m 3GB native support working in Catalina natively. Intel Integrated Graphics Disabled by ASus. Best MacBook Pro Clone ever had!
onemanosx
Post by onemanosx » 06 Oct 2019, 03:49
06 Oct 2019, 03:43
for first gen cpu just use SSDT only. CPUfriend is not required.
Other easier link to achieve the ssdt by using automated script [Local Link Removed for Guests]
osxfr33k
CPU: i9-9900k
GPU: AMD RX 590 8gb
Post by osxfr33k » 06 Oct 2019, 18:05
06 Oct 2019, 03:49
Maybe this processor is not supported in PRgen? Tried it and get an error unsupported. Looked over a bunch of CFG files and I don't see anything less than 2nd generation intel i7/i5/i3. I will see if adding this CPU to the CFG will help any but is that the only reason why for the error or os it possible PRgen was not coded to work with 1st generation CPU?
the_whip
CPU: i7 3930K
Motherboard: P9X70 Pro
GPU: RX 580
Post by the_whip » 07 Oct 2019, 16:34
Hi,
I get an error...
Could this be that my DSDT is wrong?
Also, when I go to paste the frequency info, I have no _DSM:
ASUS P9X79 Pro - i7 3930K
erinviegas
CPU: Intel Core i5 8250u
Motherboard: Lenovo
GPU: Intel UHD 620
Post by erinviegas » 28 Nov 2019, 19:44
07 Sep 2019, 23:34
onemanosx
How did you figure it out?
juanvascas
CPU: i7-8750H
Motherboard: HM370
GPU: Gtx 1060 Max-Q
Post by juanvascas » 29 Nov 2019, 07:12
15 Apr 2019, 23:21
in the data folder that is in your ⁨Users⁩ ▸ yourname ▸ ⁨LibraryssdtPRGen⁩ data folder in the user defined doc did you add as so
i7-8750H,35,600,2200,4100,6,12
as i added an give it a try
User Defined.cfg.zip
Hey I got also the i7-8750H, I wonder if lowering the tdp data does help saving energy? Also what is that 600 value which I cannot seem to find at intel’s website and current post Data folder contains the cpu but instead of 600 it has there a 500 value. How do you get default value for a cpu and how do you define which value is better?
Thanks.
Rhoqr
CPU: E5-2690 V4
Motherboard: Z10PA-U8
GPU: Quadro
Post by Rhoqr » 06 Dec 2019, 12:10
i tried this with a macpro 6,1 smbios and ssdtPRGen seemed to run fine. i then added the cf-frequency-data, ran it through iasl and put the result in clover's patched folder. during verbose boot i could see the success message from X86PlatformPlugin. i have also set clover's plugin type to 1 and used the haswell-e fakecpuid because 10.12 wouldn't boot with the original broadwell id.
however, it had no effect. the frequency graph of Intel's Power Gadget was still straight. no vertical movement at all.
i did this with 10.12.6 and with windows the power management works fine. so i guess my bios settings are okay. so what did i miss?
