[Guide] - SSDT with Pike's PM Script and use with CPUFriend
iSn0wCrypt0
CPU: i5-7200U
Motherboard: P385
GPU: IntelHD620
Post by iSn0wCrypt0 » 20 May 2019, 12:00
[External Link Removed for Guests]How can I know that my ssdt is working?
*HP Notebook 15 bs527ns*
Intel i5-7200U <Kaby Lake>, 8 GB 2133 MHz DDR4, Intel HD Graphics 620 - 2048 MB
*Asus F55VD*
Intel i3-3110M <Ivy Bridge>, 8GB 1333MHz DDR3, Intel HD 4000 - 1536 MB
Oraoo
CPU: i7 4790K
Motherboard: Gigabyte Z97P-D3
GPU: Intel HD Graphics 4600 1536 MB
Post by Oraoo » 20 May 2019, 12:48
Intel Power Gadget
iSn0wCrypt0
CPU: i5-7200U
Motherboard: P385
GPU: IntelHD620
Post by iSn0wCrypt0 » 20 May 2019, 13:33
20 May 2019, 12:48
Intel Power Gadget
if I have it installed, but how do I know if it is working? [url][External Link Removed for Guests]]
*Asus F55VD*
onemanosx
Post by onemanosx » 20 May 2019, 13:55
cf-frequency-data should show in ioreg
MSI B360 Gaming Arctic
iSn0wCrypt0
CPU: i5-7200U
Motherboard: P385
GPU: IntelHD620
Post by iSn0wCrypt0 » 20 May 2019, 16:40
20 May 2019, 13:55
When I compiled the file, I said 0 corrections, this is so?
or should I put 1 correction
*Asus F55VD*
iSn0wCrypt0
CPU: i5-7200U
Motherboard: P385
GPU: IntelHD620
Post by iSn0wCrypt0 » 20 May 2019, 19:23
Could you create my ssdt? Please
i5-7200,15,800,2500,3100,2,4
*Asus F55VD*
onemanosx
Post by onemanosx » 20 May 2019, 20:29
iSn0wCrypt0, try kext method instead of ssdt
iSn0wCrypt0
CPU: i5-7200U
Motherboard: P385
GPU: IntelHD620
Post by iSn0wCrypt0 » 20 May 2019, 22:02
doesnt works
*Asus F55VD*
onemanosx
Post by onemanosx » 21 May 2019, 00:10
iSn0wCrypt0, this is something you have to do it on your own
iSn0wCrypt0
CPU: i5-7200U
Motherboard: P385
GPU: IntelHD620
Post by iSn0wCrypt0 » 21 May 2019, 08:37
If I can explain myself well, I speak English very badly!
perform all the steps of the post ... but it does not work for me, as you already know
you told me to perform the steps with the option of kext ..
Now I can not move from here: ./ssdtPRGen.sh -p 'i5-7200' -f 2500 -turbo 3100
send me an announcement: not such directory
Paste my .cfg, but I still throwing the same error
*Asus F55VD*
onemanosx
Post by onemanosx » 21 May 2019, 09:12
21 May 2019, 08:38
Did you place pike's folder in the directory as instructed? Did you replace the Data folder? Did you key in your CPU type in the .cfg file as instructed? You will need to go through it slowly. Good luck.
iSn0wCrypt0
CPU: i5-7200U
Motherboard: P385
GPU: IntelHD620
Post by iSn0wCrypt0 » 21 May 2019, 10:35
I repeat, I followed all the steps to the letter
I have repeated it 20 times .. always the same CPU error
Everything is copied / pasted / and chewed thousands of times
Could you check if my ssdt.aml is correct?
2 weeks ago everything went well and compile the file without problems ..
But I had to restore from scratch and now I have this problem (because you said you would have to appear in IOreg) but it does not appear to me like you ..
Then can you look at my ssdt?
*Asus F55VD*
onemanosx
Post by onemanosx » 21 May 2019, 10:43
I cant check if I don't know exactly what you did. Anyone can claim they followed instructions to the letter but without proof, you see.
Anyway, ssdt looks good. So, as per my suggestion, using the existing files you had, you an easily create kext. Read post 2 of the guide.
iSn0wCrypt0
CPU: i5-7200U
Motherboard: P385
GPU: IntelHD620
Post by iSn0wCrypt0 » 22 May 2019, 16:20
21 May 2019, 10:43
First, thank you for answering ..
hello I decided to start again (post1) everything went perfect ..
but when restarting it stays stuck here ..
*Asus F55VD*
anibalin
Post by anibalin » 04 Jun 2019, 17:01
Hey guys. I got a 9700k. Do I need to do this procedure? (I already did, just want to know if its pointless). I read that 9900 was not necessary. Which models does not need this?
Moreover, after all this, do I need to uncheck PluginType in clover?
Thanks.
Post by MaLd0n » 04 Jun 2019, 17:11
anibalin, desktops just use PlugIn type in config.plist, ssdt or dsdt
this way is for solve HWP bug in notebooks
anibalin
Post by anibalin » 04 Jun 2019, 18:47
04 Jun 2019, 17:11
Thanks ;)
nasca
CPU: Intel Xeon E5-2695 v3
Motherboard: MSI X99A Raider
GPU: Nvidia GTX 1060 3GB
Post by nasca » 05 Jun 2019, 14:27
Hi, everyone...
After the procedure to resolve Unknown CPU I have in finder same result even if in other applications the CPU is shown...
I have proceeded in this mode:
Downloaded:
curl -o ~/ssdtPRGen.sh [External Link Removed for Guests]
Copy our modded downloaded DATA folder [Local Link Removed for Guests]
and edit "User Defined.cfg" with:
'E5-2695 v3',120,1200,2300,3300,14,28
after in the terminal
chmod +x ~/ssdtPRGen.sh
again...
sudo ~/ssdtPRGen.sh -p 'E5-2695 v3' -f 2300 -turbo 3300
cd ~/Desktop/CPUFriend-master/ResourceConverter
Download CPUFriend master zip [External Link Removed for Guests]
terminal:
./ResourceConverter.sh --acpi /Users/apple/Library/ssdtPRGen/SSDT.aml
Combining CPUFriend data into Pike's SSDT and save the ssdt.aml and copy to Clover/acpi/patched
Or NOT and...
2. Drag ssdt.aml from ~/Library/ssdtPRgen folder to terminal and Press Enter
3. Your CPUFriendDataProvider.kext will be generated and can be found at ~/Desktop/CPUFriend-master/ResourceConverter folder
4. Place both CPUFriendDataProvider.kext and CPUFriend.kext in clover/kext/others
./ResourceConverter.sh --kext /Users/apple/Library/ssdtPRGen/SSDT.aml
and also
sudo chmod -R 755 kextfile.kext
sudo chown -R root:wheel kextfile.kext
But the CPU in Finder (about this MAC) result unknown (sconosciuta in italian)
Many thanks
Nasca.
Image Image
Post by MaLd0n » 05 Jun 2019, 14:29
nasca, Use cpu type in config.plist 0x0a05
check second option here
nasca
Post by nasca » 05 Jun 2019, 14:45
:o
Many Thanks
