[Guide] - SSDT with Pike's PM Script and use with CPUFriend
erroruser
CPU: i9 9900k
Motherboard: asus z390-a
GPU: rx 590
Post by erroruser » 15 Apr 2019, 17:09
osxfr33k, did you add the information for the cpu in the data files if its not listed in them
Asus z390-A, i9 9900k, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, sapphire rx 590, fractal celcius s36
:superman :superman
osxfr33k
CPU: i9-9900k
Motherboard: Asus Z390-E Gaming
GPU: AMD RX 590 8gb
Post by osxfr33k » 15 Apr 2019, 23:06
15 Apr 2019, 17:09
Yep followed the guide perfectly. Maybe for some reason which I cannot explain it’s not reading the Coffee Lake.cfg. I know it’s reading the User Defined.cfg because if I leave a couple spaces or something the CFG file should not contain it complains in the output showing such lines in cfg needs attending to. This happens when you don’t edit them in terminal with like nano or equivalent editor that will not change the format of the cfg. If I remove the Coffee Lake.cfg it doesn’t complain is why I suspect that for some reason ssdtPRGen is not reading the Coffee Lake.cfg file but it is reading the User Defined.cfg.
I have never been so baffled by something like this.
OP-LP3 OverPowered Laptop 17 inch, i7-8750H, 32GB memory, 256GB NvMe stock with windows 10 and added 512GB NvMe Samsung 970 Pro with MacOS 10.14.6. Asus G750JX Laptop with Nvidia GTX770m 3GB native support working in Catalina natively. Intel Integrated Graphics Disabled by ASus. Best MacBook Pro Clone ever had!
erroruser
CPU: i9 9900k
GPU: rx 590
Post by erroruser » 15 Apr 2019, 23:21
in the data folder that is in your ⁨Users⁩ ▸ yourname ▸ ⁨LibraryssdtPRGen⁩ data folder in the user defined doc did you add as so
i7-8750H,35,600,2200,4100,6,12
as i added an give it a try
User Defined.cfg.zip
:superman :superman
osxfr33k
CPU: i9-9900k
GPU: AMD RX 590 8gb
Post by osxfr33k » 15 Apr 2019, 23:53
15 Apr 2019, 23:21
Yes added that exactly as you have and exactly as instructions say.
erroruser
CPU: i9 9900k
GPU: rx 590
Post by erroruser » 15 Apr 2019, 23:59
try with the one i sent see if that helps
:superman :superman
osxfr33k
CPU: i9-9900k
GPU: AMD RX 590 8gb
Post by osxfr33k » 16 Apr 2019, 01:12
15 Apr 2019, 23:59
Wow thanks so much it worked!! NOw I Have to figure out why mine does not work I attached mine can you see what is wrong?
erroruser
CPU: i9 9900k
GPU: rx 590
Post by erroruser » 16 Apr 2019, 01:19
looks like you added in wrong
:superman :superman
osxfr33k
CPU: i9-9900k
GPU: AMD RX 590 8gb
Post by osxfr33k » 16 Apr 2019, 01:21
16 Apr 2019, 01:19
I attached the wrong file I was testing my friends CPU check the new file I attached and let me know if you see anything wrong with it.
erroruser
CPU: i9 9900k
GPU: rx 590
Post by erroruser » 16 Apr 2019, 01:23
there is no file
:superman :superman
osxfr33k
CPU: i9-9900k
GPU: AMD RX 590 8gb
Post by osxfr33k » 16 Apr 2019, 01:28
16 Apr 2019, 01:23
there is no file
Sorry here it is this one does not work maybe you can explain I cannot see anything wrong with it.
erroruser
CPU: i9 9900k
GPU: rx 590
Post by erroruser » 16 Apr 2019, 01:35
this is how it should be
:superman :superman
osxfr33k
CPU: i9-9900k
GPU: AMD RX 590 8gb
Post by osxfr33k » 16 Apr 2019, 01:42
Sorry I made another mistake again sent you the wrong file. Here is the one that is not working.
erroruser
CPU: i9 9900k
GPU: rx 590
Post by erroruser » 16 Apr 2019, 01:51
look at the pic i posted as its the same as i posted in the pic as it shows your missing the "#"
yours
gUserDefinedCPUList=(
my edit
:superman :superman
osxfr33k
CPU: i9-9900k
GPU: AMD RX 590 8gb
Post by osxfr33k » 16 Apr 2019, 02:15
16 Apr 2019, 01:51
yours
my edit
Well either way thanks for really helping me try to understand I thought the # just comments out anything so it won't think its part of the script I didn't realize you need the # before the close parenthesis ")"
Ok One last time what is wrong with this file, I left 2 devices inside this file does not work either.
erroruser
CPU: i9 9900k
GPU: rx 590
Post by erroruser » 16 Apr 2019, 02:32
all i can think of is cause your removed all the other information
:superman :superman
osxfr33k
CPU: i9-9900k
GPU: AMD RX 590 8gb
Post by osxfr33k » 16 Apr 2019, 02:37
16 Apr 2019, 02:32
Exactly what I am thinking to but something is going wrong and maybe that is why others have reported same issue unknown CPU then aborts. I stripped down your original cfg down to just one device took out everything left no spaces. Just left information above. Here is your file stripped down works perfect. So maybe a good idea to have your file in that DATA folder, because I kept downloading that DATA folder using a new User Defined.cfg and added the information exactly as the one I have attached just now and the one I modify from that DATA folder never works but the one you sent I can hack it to death and it works no matter what.
See attached and thanks again!
Edited:
I think I know the possible problem something with the filename or the way the file was created. To prove this what I did is create an empty file in terminal with the touch command , then pasted all the contents of the file I attached in this post and ssdtPRGen runs fine and creates both the ssdt.dsl and ssdt.aml ACPI files.
Edited Again:
To compound this issue even more something really strange happens when I get a message unknown software and it aborts, I open the user cfg file up again using nano and it shows me an older cfg file not the current one as though somehow it was kept in buffer even though I exited nano cleanly so now I am thinking its something going on with nano in terminal under 10.14.4 causing these problems. I have to think about using a different editor maybe vi or an editor specific to cfg files, maybe a gui editor for MacOS.
stevedj57
CPU: i7 6700k
Motherboard: asus z170 deluxe
GPU: amd radeonHD 7970
Post by stevedj57 » 11 May 2019, 12:33
05 Jan 2019, 05:50
./ssdtPRGen.sh -p 'i5-8600' -f 3100 -turbo 4300
[/quotei5-3340M,35,1200,2700,3400,2,4
iSn0wCrypt0
CPU: i5-7200U
Motherboard: P385
GPU: IntelHD620
Post by iSn0wCrypt0 » 18 May 2019, 14:12
Hello brother, when you get to this part:
./ResourceConverter.sh --acpi + drag ssdt.aml returns (invalid) and I can not continue because the route is invalid
*HP Notebook 15 bs527ns*
Intel i5-7200U <Kaby Lake>, 8 GB 2133 MHz DDR4, Intel HD Graphics 620 - 2048 MB
*Asus F55VD*
Intel i3-3110M <Ivy Bridge>, 8GB 1333MHz DDR3, Intel HD 4000 - 1536 MB
onemanosx
Post by onemanosx » 18 May 2019, 14:38
18 May 2019, 14:12
Did you drag the ssdt file into terminal after typing "./ResourceConverter.sh --acpi " ?
MSI B360 Gaming Arctic
iSn0wCrypt0
CPU: i5-7200U
Motherboard: P385
GPU: IntelHD620
Post by iSn0wCrypt0 » 18 May 2019, 15:01
solved bro
*Asus F55VD*
