[Guide] - SSDT with Pike's PM Script and use with CPUFriend
onemanosx
Post by onemanosx » 05 Jan 2019, 05:50
Update: Creating injector kext with CPUFriend script [Local Link Removed for Guests]
What is CPUFriend?
Step A. Creating SSDT Using Pike's Script
1. Go to Pike’s Github and download ZIP master [External Link Removed for Guests]
2. Extract “ssdtPRGen.” folder and copy and paste to /Users/YourUsername/Library
4. Download attached “Data” folder and replace existing Data folder in “/ssdtPRGen”
Data.zip
5. Open “User Defined.cfg” file in “ssdtPRGen/Data” folder
6. Open Coffee Lake.cfg file and look for your processor type ( in this example, I will be using “i5-8600”)
7. Paste your CPU details in User Defined.cfg and save file
Note: If you plan to use a different clock speed frequency (mostly for energy saving) or base/turbo frequency, here is where you make the desired frequency changes. The example in the screenshot above is setting using clock speed of 500 instead of OEM 800.
8. Open Terminal
9. Type
cd ~/Library/ssdtPRGen/
Hit Enter
10. Type CPU format as such (for i5-8600) :
./ssdtPRGen.sh -p 'i5-8600' -f 3100 -turbo 4300
11. Press Enter
12. Let the script run and when script asks Do you want to open ssdt.dsl (y/n)? Just return N.
13. Your ssdt.aml and ssdt.dsl can be found in ~/Library/ssdtPRgen folder
Step B: Generating SSDT data using CPUFriend script
1. Download CPUFriend master zip [External Link Removed for Guests]
While you’re there, download CPUFriend kext from the release tab and place the kext in Clover/Kext/Other
2. Extract CPUFriend-master folder to desktop
3. Open terminal
4. Type
cd ~/Desktop/CPUFriend-master/ResourceConverter
Hit Enter
5. Type
./ResourceConverter.sh --acpi
Then drag ssdt.aml from ~/Library/ssdtPRgen folder into terminal window and press ENTER
6. Your ssdt-data.dsl result can be found at ~/Desktop/CPUFriend-master/ResourceConverter folder
Step C: Combining CPUFriend data into Pike's SSDT
1. Open the ssdt-data.dsl and copy the whole scope of “cf-frequency-data”
2. Go to ~/Library/ssdtPRgen folder and open the file ssdt.aml
3. Find the _DSM section
4. Paste “cf-frequency-data’ like shown in the screenshot. Also, delete 0x02 in the Return line leaving just the brackets or else your will not be able to compile.
5. You can save the ssdt.aml and copy to Clover/acpi/patched.
Reboot and enjoy!
Note: If you do not find the cf-frequency-data as shown like in the IOReg screenshot below, it means the SSDT is not injecting properly. You might want to consider creating CPUFriendDataProvider kext instead.
Data.zip
Credits:
Pike
MSI B360 Gaming Arctic
onemanosx
Post by onemanosx » 05 Jan 2019, 09:17
Some of us might prefer to use injector kext instead of SSDT. This is how its done.
1. Type
./ResourceConverter.sh --kext
2. Drag ssdt.aml from ~/Library/ssdtPRgen folder to terminal and Press Enter
3. Your CPUFriendDataProvider.kext will be generated and can be found at ~/Desktop/CPUFriend-master/ResourceConverter folder
4. Place both CPUFriendDataProvider.kext and CPUFriend.kext in clover/kext/others
Unknown CPU
What if I have a CPU that is unknown and not in the .cfg list? Can I still generate ssdt using Pike's script?
Yes. And this is what we have to do.
1. Determine CPU details by going through [External Link Removed for Guests] and fill in the details for an i5-8600 as an example.
Code Name: Coffee Lake
Processor Number: i5-8600
Max TDP: 65
Low Frequency Mode: 3100
Clock Speed: 800
Max Turbo Frequency: 4300
No. of Cores: 6
No. of Threads: 6
The format to be input in Coffee Lake. cfg and User Defined.cfg will look like this
i5-8600,65,800,3100,4300,6,6
[Guide] - Configure CPUFriend and use with Pike's PM Script
Post by MaLd0n » 05 Jan 2019, 11:02
:guitar :cap
onemanosx
[Guide] - Generate Pike's PM Script and use with CPUFriend
Post by onemanosx » 05 Jan 2019, 11:46
05 Jan 2019, 11:02
:guitar :cap
A good sleep is all I need :lol: :lol:
erroruser
CPU: i9 9900k
Motherboard: asus z390-a
GPU: rx 590
Post by erroruser » 05 Jan 2019, 16:06
:superman :superman :superman :superman
Asus z390-A, i9 9900k, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, sapphire rx 590, fractal celcius s36
:superman :superman
Sampath007
CPU: i7-8550u
Motherboard: Acer Nitro 515-31
GPU: UHD 620
Post by Sampath007 » 05 Jan 2019, 16:59
vinvilli
CPU: i7-4960X
Motherboard: P9PROx79
GPU: GTX 770
Post by vinvilli » 06 Jan 2019, 06:16
Thank You onemanosx, for Detailed links and instructions :guitar
onemanosx
Post by onemanosx » 06 Jan 2019, 06:43
vinvilli, :guitar :cap You're welcome!
agussuratno
CPU: Intel Core i3-3217U 1.8 GHz
Motherboard: Intel® HM76 Chipset
GPU: Intel HD Graphics 4000 + eGPU
Post by agussuratno » 06 Jan 2019, 11:08
Thank you @onemanosx, for detailed links and instructions
onemanosx
Post by onemanosx » 06 Jan 2019, 11:28
agussuratno, :guitar :guitar You're welcome!
FedeBad95
CPU: i7 8700k
Motherboard: Z370 Taichi
GPU: GTX 1080
Post by FedeBad95 » 06 Jan 2019, 16:46
Hi guys I did everything to guide but at the final step I can not fill it out and save who can help me? thanks again I am attaching files
Post by MaLd0n » 06 Jan 2019, 16:48
FedeBad95, u don't need it
FedeBad95
CPU: i7 8700k
GPU: GTX 1080
Post by FedeBad95 » 06 Jan 2019, 17:52
06 Jan 2019, 16:48
Ok Thanks
brynts
CPU: i7 - 3630QM
Motherboard: ASUS N46VZ
GPU: GeForce GT 650M/HD 4000
Post by brynts » 14 Jan 2019, 11:18
what should I do if no _DSM in my ssdt.aml?
onemanosx
Post by onemanosx » 14 Jan 2019, 12:01
[ref]brynts[/ref], never experienced that in all of my 4 hack machines.
Post by MaLd0n » 14 Jan 2019, 12:07
[ref]brynts[/ref], if u don't like .aml/.dsl, generate a kext injector instead
erroruser
CPU: i9 9900k
GPU: rx 590
Re: [Guide] - SSDT with Pike's PM Script and use with CPUFriend
Post by erroruser » 03 Feb 2019, 16:09
Completed with cpufriend
with out cpufriend
:cap
:superman :superman
Post by MaLd0n » 03 Feb 2019, 16:10
03 Feb 2019, 16:09
with out cpufriend
:cap
:mrgreen:
onemanosx
Post by onemanosx » 04 Feb 2019, 08:25
MaLd0n, erroruser, please do one with overclocked settings :whistle :geek: :mrgreen:
Post by MaLd0n » 04 Feb 2019, 10:06
04 Feb 2019, 08:25
onemanosx,
with i9 i forgot the overclock :mrgreen:
