onemanosx
Post by onemanosx » 03 Apr 2019, 16:00
03 Apr 2019, 15:48
onemanosx [External Link Removed for Guests] ... -Twist.txt yes signal done SSDT-BTAC yes patched yes
no idea what you want. Sorry. :poke
Intel i7-6700HQ, 8GB RAM (UEFI Clover Mojave)
MSI B360 Gaming Arctic
Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Mojave)
ford2201
Geek
Geek
CPU: i3-2120
Motherboard: ASUS h61m-k
GPU: Nvidia gts 480
Post by ford2201 » 03 Apr 2019, 17:52
because you are saying that DSDT itself does so and I will give you why to explain to me SSDT-BATC
onemanosx
Post by onemanosx » 15 Apr 2019, 13:02
bulibasha, test for battery status
bulibasha-DSDT.aml.zip
rogeriovasco
CPU: core i3 3110m
Motherboard: NP270E4E-KD4BR
GPU: intel hd graphcs 4000
Post by rogeriovasco » 16 Apr 2019, 11:43
can you help me im trying to fix my battery status but always got error
am i doing it wrong?
into device label H_EC code_regex B1RA,\s+16, replace_matched begin BRA0,8,BRA1,8, end;
into device label H_EC code_regex B1DF,\s+16, replace_matched begin BDF0,8,B1DF,8, end;
into device label H_EC code_regex B1PR,\s+16, replace_matched begin BPR0,8,BPR1,8, end;
into device label H_EC code_regex B1VO,\s+16, replace_matched begin BVO0,8,BVO1,8, end;
into device label H_EC code_regex B1DA,\s+16, replace_matched begin BDA0,8,BDA1,8, end;
into device label H_EC code_regex B1DV,\s+16, replace_matched begin BDV0,8,BDV1,8, end;
into device label H_EC code_regex B1DL,\s+16, replace_matched begin BDL0,8,BDL1,8, end;
into device label H_EC code_regex CYLC,\s+16, replace_matched begin CYL0,8,CYL1,8, end;
onemanosx
Post by onemanosx » 16 Apr 2019, 14:38
rogeriovasco, You got the first part of patching correct.
Now its time to correct these errors:
e.g for B1DA -> B1B2(\_SB.PCI0.LPCB.H_EC.BDA0,\_SB.PCI0.LPCB.H_EC.BDA1)
1. Find B1DA in DSDT
2. Paste
over "B1DA" like so
Do the same for all the remaining 9 errors.
And lastly introduce the B1B2 and EC essential patches.
rogeriovasco
CPU: core i3 3110m
Post by rogeriovasco » 16 Apr 2019, 19:51
16 Apr 2019, 14:38
2. Paste
over "B1DA" like so
thank you now i can see the battery icon i appreciate your help
the problem now is battery status show at top bar but it not update status it stay 37% the whole time. When I connect or disconect charge the sistem stop work it freezes
onemanosx
Post by onemanosx » 17 Apr 2019, 10:59
rogeriovasco, Looks like you missed out BTPC, 16, integer to fix.
Always a good practice to double check our works.
rogeriovasco
CPU: core i3 3110m
Post by rogeriovasco » 18 Apr 2019, 21:02
17 Apr 2019, 10:59
yeah sure, finelly got it to work thank you for your help
onemanosx
Post by onemanosx » 19 Apr 2019, 01:18
rogeriovasco, :cap :guitar
jrapbit
CPU: q8200
Motherboard: asus p5kpl-am/ps
GPU: leadtek 9600gt
Post by jrapbit » 02 May 2019, 08:57
My battery status shows percent just fine after I install(without doing nothing) but when I plug/unplug charger. It freeze. So I try to patch the battery and I see this screen. What should I do? Thanks in advance!
onemanosx
Post by onemanosx » 02 May 2019, 11:20
02 May 2019, 08:57
What should I do?
Maybe, read and follow the guide?
minhphan244
CPU: i7-4600U
Motherboard: Intel
GPU: HD4400
Post by minhphan244 » 03 May 2019, 15:06
My DSDT doesn't have Embeddedcontrol @@ How to solve it, please help me
onemanosx
Post by onemanosx » 03 May 2019, 16:35
minhphan244, what happens if you install battery kext?
minhphan244
CPU: i7-4600U
Motherboard: Intel
GPU: HD4400
Post by minhphan244 » 04 May 2019, 06:56
03 May 2019, 16:35
It works (show exactly percentage, warning low battery) but battery indicator not recognize when i plug/unplug AC adapter and percentage battery still increase, system report still recognize charging, i don't know how to solve it @@
onemanosx
Post by onemanosx » 04 May 2019, 08:57
minhphan244, No idea. Never faced a DSDT like yours before.
hawkins1986
CPU: Intel Core i7 (3rd Gen) 3667U
Motherboard: Mobile Intel QM77 Express
GPU: Intel HD Graphics 4000
Post by hawkins1986 » 05 May 2019, 02:04
syntax error, unexpected parseop_if
syntax error, unexpected parseop_method, expecting $end and premature end-of-file
any ideas?
onemanosx
Post by onemanosx » 05 May 2019, 02:08
hawkins1986, no idea without your DSDT file and/or description of what you attempted to get that error.
hawkins1986
Post by hawkins1986 » 05 May 2019, 02:15
I'm trying to fix my battery icon. I'm trying the hp elite x2 patch on my hp Elitebook. I can't upload .dsl file.
onemanosx
Post by onemanosx » 05 May 2019, 02:19
05 May 2019, 02:15
Scroll down and look for the add files icon. Or, upload somewhere in your prefered cloud e.g google drive
hawkins1986
Post by hawkins1986 » 05 May 2019, 02:27
