Wizzard
CPU: Intel m3-7Y30
Motherboard: Teclast F6 Pro
GPU: Intel HD 615
Post by Wizzard » 02 Apr 2019, 05:46
02 Apr 2019, 02:46
Wizzard, link?
onemanosx
Post by onemanosx » 02 Apr 2019, 07:14
02 Apr 2019, 05:46
[External Link Removed for Guests] ... st-1859518
Did you also implement the second part of the the patch as well?
Intel i7-6700HQ, 8GB RAM (UEFI Clover Mojave)
MSI B360 Gaming Arctic
Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Mojave)
Wizzard
CPU: Intel m3-7Y30
GPU: Intel HD 615
Post by Wizzard » 02 Apr 2019, 07:52
02 Apr 2019, 07:14
I don't know what is second part of the patch.
onemanosx
Post by onemanosx » 02 Apr 2019, 07:54
02 Apr 2019, 07:52
its in the link you provided by the OP
Wizzard
CPU: Intel m3-7Y30
GPU: Intel HD 615
Post by Wizzard » 02 Apr 2019, 08:06
I really dont know what you mean. I just changed the string "Ones" by "7200" in "Name (BPKG, Package (0x0D)" function as in that provided link and I can see the battery status, although not very exact.
onemanosx
Post by onemanosx » 02 Apr 2019, 08:16
02 Apr 2019, 08:06
Looks to me, that is not the only change made by the OP. See screenshot
Wizzard
CPU: Intel m3-7Y30
GPU: Intel HD 615
Post by Wizzard » 02 Apr 2019, 08:21
Yes, I noticed later, you are right. I may try that change too, but I think more important is that "7200" or another number.
onemanosx
Post by onemanosx » 02 Apr 2019, 09:02
For the sake of sharing, I just read up on this interesting ACPI method. The information is definitely usable in this case.
onemanosx
Post by onemanosx » 02 Apr 2019, 12:23
Wizzard, for sake of troubleshooting, try this and report back.
Wizzard
CPU: Intel m3-7Y30
GPU: Intel HD 615
Post by Wizzard » 02 Apr 2019, 19:46
It works, but still it shows the percentage higher than in Linux (approx. 95 percent against 90 percent) so maybe it still needs another tweaking.
onemanosx
Post by onemanosx » 02 Apr 2019, 20:14
Does percentage decrease or increase with use?
ford2201
Geek
Geek
CPU: i3-2120
Motherboard: ASUS h61m-k
GPU: Nvidia gts 480
Post by ford2201 » 03 Apr 2019, 03:18
instructions on whether I can convert the DSDT itself for operation SSDT-BAT please, please give me the whole information
Wizzard
CPU: Intel m3-7Y30
GPU: Intel HD 615
Post by Wizzard » 03 Apr 2019, 05:29
02 Apr 2019, 20:14
Decrease, of course :) The percentage is always 3-5 percent higher than in Linux.
onemanosx
Post by onemanosx » 03 Apr 2019, 11:15
03 Apr 2019, 05:29
The difference between OS is commendable, I think. You may try and input your custom _BIF as per the documentation ([External Link Removed for Guests]), if you are up for it.
Anyway, appreciate if you can test this DSDT and see if battery status works. Thanks in advance.
Added in 6 minutes 38 seconds:
03 Apr 2019, 03:18
whole information here [External Link Removed for Guests]
ford2201
Geek
Geek
CPU: i3-2120
GPU: Nvidia gts 480
Post by ford2201 » 03 Apr 2019, 13:48
[External Link Removed for Guests] yes signal done SSDT-BTAC
Wizzard
CPU: Intel m3-7Y30
GPU: Intel HD 615
Post by Wizzard » 03 Apr 2019, 15:14
03 Apr 2019, 11:22
Yes, works, but still showing percentage a few percent higher than Linux/Windows.
onemanosx
Post by onemanosx » 03 Apr 2019, 15:17
03 Apr 2019, 15:14
Thank you for testing. This DSDT proves that battery capacity patch is not required. Appreciate your feedback.
I wont worry abt the few % off linux/windows.
Wizzard
CPU: Intel m3-7Y30
GPU: Intel HD 615
Post by Wizzard » 03 Apr 2019, 15:23
Thank you very much for your help effort. I think I can live with that :)
onemanosx
Post by onemanosx » 03 Apr 2019, 15:26
:cap
ford2201
Geek
Geek
CPU: i3-2120
GPU: Nvidia gts 480
Post by ford2201 » 03 Apr 2019, 15:48
onemanosx [External Link Removed for Guests] ... -Twist.txt yes signal done SSDT-BTAC yes patched yes
