Drovosek
CPU: i5-6200U
Motherboard: HP 820C
GPU: Nvidia Geforce 940MX
Post by Drovosek » 11 Jul 2019, 06:42
Wrong link to MaciASL. Please, fix it.
onemanosx
Post by onemanosx » 11 Jul 2019, 13:22
11 Jul 2019, 06:42
Fixed! Thanks!
MSI B360 Gaming Arctic
Clawric
CPU: Intel Core i7-740QM 2.93 GHz
Motherboard: OEM Motherboard
GPU: Geforce GT 330M
Post by Clawric » 19 Aug 2019, 11:46
when I press patch it shows me nothing, there's no text no nothing its completely empty
onemanosx
Post by onemanosx » 19 Aug 2019, 11:51
19 Aug 2019, 11:46
What are you trying to patch specifically?
Clawric
Post by Clawric » 19 Aug 2019, 12:16
onemanosx, I was just following the steps for the battery problem and it said press patch and scroll down to bat
onemanosx
Post by onemanosx » 19 Aug 2019, 12:20
19 Aug 2019, 12:16
Did you find a patch specific for your laptop?
Clawric
Post by Clawric » 19 Aug 2019, 13:21
onemanosx, no, because it shows me nothing when I go into patch and look for bat. everything is blank.
onemanosx
Post by onemanosx » 19 Aug 2019, 13:24
19 Aug 2019, 13:21
Then you will need to do your custom patch.
lasak12
CPU: Intel i5
Motherboard: Lenovo e130
GPU: Intel 4000
Post by lasak12 » 22 Aug 2019, 07:13
01 Jan 2019, 04:01
hallo onemanosx,
I follow your tutorial, but i confused how to change it on my lenovo thinkpad e130
i need help
tks
my laptop thinkpad E130
intel core i5, RAM 8GB, INTELHD 4000 (High Sierra)
DSDT_PATCHACPI_Bat_err.zip
This my dsdt error wrote:
onemanosx
Post by onemanosx » 22 Aug 2019, 10:56
lasak12, Can you upload your original DSDT.aml and your intended custom patch?
I cant tell whats going on by just looking at your patched DSDT.
lasak12
CPU: Intel i5
GPU: Intel 4000
Post by lasak12 » 22 Aug 2019, 11:16
22 Aug 2019, 10:56
yes, i can
this is DSDT Origin mylaptop
trims
onemanosx
Post by onemanosx » 22 Aug 2019, 11:45
22 Aug 2019, 11:16
Since you did not upload your custom patch, can you list the bit integers that requires patching from the embeddedcontrol?
lasak12
CPU: Intel i5
GPU: Intel 4000
Post by lasak12 » 23 Aug 2019, 17:13
22 Aug 2019, 11:45
I'm Sorry, just replied
Yes, this my list
This My List wrote: SBRC, 16,
SBFC, 16,
SBAE, 16,
SBRS, 16,
SBAC, 16,
SBVO, 16,
SBAF, 16,
SBBS, 16
SBMD, 16,
SBCC, 16
SBDV, 16,
SBOM, 16,
SBSI, 16,
SBDT, 16,
SBSN, 16
SBCH, 32
SBMN, 128
SBDN, 128
[External Link Removed for Guests] [External Link Removed for Guests]
Correct me if i wrong
trims
onemanosx
Post by onemanosx » 24 Aug 2019, 02:56
lasak12, You are only expected to patch integers which are being called again in DSDT. SBRC as an example, is not being called anywhere else in DSDT. So, this is not required.
You also missed a few integers. SMD0 is an example of that.
darkbluecode
CPU: I7 7700
Motherboard: asus gl553vd
GPU: HD630
Post by darkbluecode » 01 Sep 2019, 12:53
HI . can you fix battery for my laptop ?
Please look img :
I'm using [External Link Removed for Guests] for show battery number , but it's not right !
In mac OS battery always charge Full (100% ) , it's very bad for battery health but in Win 10 jut charge up to 97% or 96% or stoping charge in other number like 92% !
onemanosx
Post by onemanosx » 01 Sep 2019, 14:08
darkbluecode, Have you read the guide and troubleshoot what you might have missed?
darkbluecode
CPU: I7 7700
GPU: HD630
Post by darkbluecode » 01 Sep 2019, 14:29
01 Sep 2019, 14:08
yes , I try that but ....
I can't compile the DSDT.aml bc it shows the errors...
onemanosx
Post by onemanosx » 02 Sep 2019, 10:04
01 Sep 2019, 14:29
Solved the compile error for you.
Wizzard
CPU: Intel m3-7Y30
Motherboard: Teclast F6 Pro
GPU: Intel HD 615
Post by Wizzard » 13 Oct 2019, 19:12
Hi, friends. I just installed Catalina and the last thing that does not work for me is the battery stats. Would you please help me? Thank you very much!
onemanosx
Post by onemanosx » 14 Oct 2019, 02:19
Wizzard, new laptop? You can find the working DSDT in page 4 if you are still using your teclast
