onemanosx
Post by onemanosx » 15 Jun 2019, 17:50
15 Jun 2019, 16:41
Im dealing with a new problem...I had to reinstall everything due to a bad kext, now my patched dsdt makes my comp not boot. Is this normal? Do i need to repatch my dsdt? I thought my patched dsdt would have been fine.
DSDT should be fine with last working config
MSI B360 Gaming Arctic
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 15 Jun 2019, 19:41
15 Jun 2019, 17:50
Thinking my config.plist is f'd up. That would make me not boot. Correct? Is my full config.plist in that file I uploaded?
ASUS VivoBook Flip 14 TP412UA-IH31T
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 15 Jun 2019, 21:41
14 Jun 2019, 12:00
yamvmax, Before I go any further, lets test your own patched DSDT. Please download smcbatterymanager.kext and replace acpibatterymanager.kext.
When using virtualsmc.kext, it is paired with smcbatterymanager.kext and not acpibatterymanager.kext
I am back up running, I tried what you said....Nothing, still no battery. Are any edits to be done to my dsdt???
Added in 22 minutes 30 seconds:
I think my biggest issue is patching my dsdt...I get errors. I try using MacIASL, but i get syntex errors
Added in 2 minutes 29 seconds:
Also, I still have ACIPoller.kext...Leave that?
onemanosx
Post by onemanosx » 16 Jun 2019, 02:49
yamvmax, No idea what ACIPoller kext does.
Disable all patches shown here
There are also other patches you dont need. But that is not the scope in this topic here.
Try this:
Use Virtualsmc +SMCBatteryManager Kexts
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 16 Jun 2019, 11:15
16 Jun 2019, 02:49
Try this: DSDT.aml.zip.
It wont boot. It starts, then i get the zero with slash through it
Added in 8 minutes 5 seconds:
Did you use my patched dsdt??? Because the one you uploaded is my original. My patched is patched for touchscreen and track pad working, which do with the patched.
onemanosx
Post by onemanosx » 16 Jun 2019, 11:51
yamvmax, I'll post the patch and you do it. That will be better.
#16 bits registers
into device label H_EC code_regex B1DC,\s+16, replace_matched begin ONE0,8,MAN1,8, end;
into device label H_EC code_regex B1FV,\s+16, replace_matched begin VF10,8,VF11,8, end;
into device label H_EC code_regex B1FC,\s+16, replace_matched begin CF10,8,CF11,8, end;
into device label H_EC code_regex B1CR,\s+16, replace_matched begin RC10,8,RC11,8, end;
into device label H_EC code_regex B1RC,\s+16, replace_matched begin CR10,8,CR11,8, end;
into device label H_EC code_regex B1LC,\s+16, replace_matched begin CL10,8,CL11,8, end;
Manual Patch
B1DC - B1B2(\_SB_.PCI0.LPCB.H_EC.ONE0,\_SB_.PCI0.LPCB.H_EC.MAN1)
B1FV - B1B2(\_SB_.PCI0.LPCB.H_EC.VF10,\_SB_.PCI0.LPCB.H_EC.VF11)
B1FC - B1B2(\_SB_.PCI0.LPCB.H_EC.CF10,\_SB_.PCI0.LPCB.H_EC.CF11)
B1CR - B1B2(\_SB_.PCI0.LPCB.H_EC.RC10,\_SB_.PCI0.LPCB.H_EC.RC11)
B1RC - B1B2(\_SB_.PCI0.LPCB.H_EC.CR10,\_SB_.PCI0.LPCB.H_EC.CR11)
B1LC - B1B2(\_SB_.PCI0.LPCB.H_EC.CL10,\_SB_.PCI0.LPCB.H_EC.CL11)
Standard H_EC patch
into method label B1B2 remove_entry;
into definitionblock code_regex . insert
begin
Method (B1B2, 2, NotSerialized) { Return(Or(Arg0, ShiftLeft(Arg1, 8))) }\n
end;
#Standard utility methods to read/write buffers from/to EC
into device label H_EC insert
begin
Method (RE1B, 1, NotSerialized)\n
{\n
	OperationRegion(ERAM, EmbeddedControl, Arg0, 1)\n
	Field(ERAM, ByteAcc, NoLock, Preserve) { BYTE, 8 }\n
	Return(BYTE)\n
}\n
Method (RECB, 2, Serialized)\n
{\n
	ShiftRight(Arg1, 3, Arg1)\n
	Name(TEMP, Buffer(Arg1) { })\n
	Add(Arg0, Arg1, Arg1)\n
	Store(0, Local0)\n
	While (LLess(Arg0, Arg1))\n
		Store(RE1B(Arg0), Index(TEMP, Local0))\n
		Increment(Arg0)\n
		Increment(Local0)\n
	}\n
	Return(TEMP)\n
}\n
end;
begin
Method (WE1B, 2, NotSerialized)\n
{\n
    Store(Arg1, BYTE)\n
}\n
Method (WECB, 3, Serialized)\n
{\n
    Store(Arg2, TEMP)\n
    Store(0, Local0)\n
    {\n
        WE1B(Arg0, DerefOf(Index(TEMP, Local0)))\n
        Increment(Arg0)\n
        Increment(Local0)\n
    }\n
}\n
end;
Read the guide on 1st post on how-to
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 16 Jun 2019, 12:10
16 Jun 2019, 11:55
#16 bits registers
Manual Patch
Standard H_EC patch
begin
end;
begin
{\n
	Return(BYTE)\n
}\n
{\n
	Store(0, Local0)\n
		Increment(Arg0)\n
		Increment(Local0)\n
	}\n
	Return(TEMP)\n
}\n
end;
begin
{\n
    Store(Arg1, BYTE)\n
}\n
{\n
    Store(Arg2, TEMP)\n
    Store(0, Local0)\n
    {\n
        Increment(Arg0)\n
        Increment(Local0)\n
    }\n
}\n
end;
I have been trying manual patches for weeks. I just cant figure it out. Im so lost.
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 16 Jun 2019, 23:33
I get errors when adding these.
onemanosx
Post by onemanosx » 17 Jun 2019, 08:52
yamvmax, What error? I used the same patch to your DSDT and compiled with no errors.
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 17 Jun 2019, 11:49
Syntax errors,,end of line or something. Gonna try again today. If not, I'm done. I have no idea what I'm doing. All I need is battery working, so I'm get touchpad settings working.
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 17 Jun 2019, 12:52
OK, so my error is actually the b1 files are missing. How do I place them?
onemanosx
Post by onemanosx » 17 Jun 2019, 12:54
yamvmax, post screenshot.
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 17 Jun 2019, 13:33
its a zip
onemanosx
Post by onemanosx » 17 Jun 2019, 13:35
yamvmax, This is expected. You must now go to that error line and replace manually the second set of patches. Read the guide on post 1 under the section "Fixing 16 bit Method"
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 17 Jun 2019, 13:40
OK, i get that. right now it says b1dc, so i channge it to b1b2??? Then change b1fv to b1 b2????
onemanosx
Post by onemanosx » 17 Jun 2019, 13:41
yamvmax, Did you read the guide?
Replace B1DC with
And B1FV with
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 17 Jun 2019, 13:55
17 Jun 2019, 13:41
Replace B1DC with
And B1FV with
I read it. Its foreign language to me. Sorry, im sure its easy for you. Im trying the best i can. Thanks, will see if i can do this
onemanosx
Post by onemanosx » 17 Jun 2019, 13:57
yamvmax, We have to start somewhere. ;)
yamvmax
CPU: i3
Motherboard: asus
GPU: intel
Post by yamvmax » 17 Jun 2019, 14:19
OK, I replaced all files...im stuck with this error. Im so close!
Added in 55 seconds:
17 Jun 2019, 13:57
Yes we do...I have one error left...Heres a screen shot.
Added in 36 minutes 3 seconds:
Update!!!!!! Got a battery showing! Unfortunately its zero percent :(
Added in 3 minutes 47 seconds:
I will be buying you some beers when i get paid next week. You have been very patient with me!
onemanosx
Post by onemanosx » 17 Jun 2019, 15:13
yamvmax, not at my mac right now. But, which battery kext are you using? Try to rebuild cache and permissions and see if that helps
Also, upload debug files by running this app [Local Link Removed for Guests]
