NEW HACK - Would be the quite best
erroruser
CPU: AMD Ryzen 7 3700X
GPU: Sapphire rx 5700 XT
Post by erroruser » 31 Dec 2018, 17:39
ruglau, for usb to work follow this guide [External Link Removed for Guests]
Asus z390-A, i9 9900k, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, sapphire rx 590, fractal celcius s36
:superman :superman
ruglau
CPU: 9900k
Motherboard: Asus rog maximus hero XI
GPU: rtx2070 + rx580
Post by ruglau » 31 Dec 2018, 18:11
I just followed that guide guys! And thanks to this guide I was able to make works the 3.1 gen2, but still 3.0 doesn't work! :( :(
Theese my USB ports... I'm right?
onemanosx
Post by onemanosx » 31 Dec 2018, 18:41
ruglau,
1. I think you need to understand what HSxx and SSxx are by reading the quick response [Local Link Removed for Guests]
2. There is no "probably my two port type-c". You need to test all ports type A and type C using appropriate testing devices i.e you will need a reliable USB type 3 device or USB type C device and so on. Reading your motherboard documentations helps.
3. There is no "maybe my 3.0 unworking" on HSxx port.
3. It is also helpful for users to know their motherboard specifications e.g what type of USB chipset is in use. Only intel chipsets are fully supported.
4. Lastly, Hackintosh are not perfect Apple product.
Having said that, I have no issues detecting my USB type C and USB type A on my build. Hint: Use reliable detection device for testing.
MSI B360 Gaming Arctic
ruglau
CPU: 9900k
Post by ruglau » 31 Dec 2018, 18:46
so you mean that I have to test unused port with the proprly usb device? On a 2.0 port I have to connect 2.0 on 3.0 only 3.0 etc in IOREG?
what If I don't have an type-c device?
onemanosx
Post by onemanosx » 31 Dec 2018, 18:52
ruglau, Yes you should test ALL ports (as per the guide suggests) with proper device (as per the guide suggests). I think the answer is obvious that you will not be able to determine which ports are used by USB type C if you do not have the tools and possibly lose other ports due to the lack of test method.
erroruser
Post by erroruser » 31 Dec 2018, 18:53
ruglau,
reading through the guides many times helps to get through, if you do not have any type-c you can not properly activate them using fbpatcher helps with the activating the ports so you know what is working in the ioreg
:superman :superman
ruglau
CPU: 9900k
Post by ruglau » 08 Jan 2019, 17:41
I connected 2 fan on AIO_FAN on my motherboard, and after that the system stack at the start, is that possible?
erroruser
Post by erroruser » 08 Jan 2019, 19:34
ruglau, the fans should plug in to chasis fan or cpu fan on motherboards the aio is for the cpu pump
:superman :superman
ruglau
CPU: 9900k
Post by ruglau » 08 Jan 2019, 19:43
right, but with some setting in BIOS now works good also in AIO PUMP,
but still I can't see fan (speed/control) on HWmonitor. :(
erroruser
Post by erroruser » 08 Jan 2019, 19:52
ruglau, show pic of monitor an upload your clover folder
:superman :superman
ruglau
CPU: 9900k
Post by ruglau » 08 Jan 2019, 20:30
Here they are
erroruser
Post by erroruser » 08 Jan 2019, 20:53
now test this
Clover.zip
:superman :superman
ruglau
CPU: 9900k
Post by ruglau » 08 Jan 2019, 22:27
No works also with iStat...
maybe some cover configuration?
ruglau
CPU: 9900k
Post by ruglau » 09 Jan 2019, 16:04
27 Dec 2018, 01:17
ruglau, Your monitor needs to support DDC/CI for this app to work.
what happens if u connect device usb in usb3 ports?
Maldon, recapping: when I will test USB I have to use:
- one dispositive Type-c gen2 for test usb-c port.
- one dispositive 3.0 for test usb 3.0
- one dispositive 3.1 gen2 for test usb 3.1 gen2 (the red usb)
- one dispositive 2.0 for test usb 2.0
is that correct?
Also you know why I can't see FAN control on my asus rog maximum hero XI?
Post by MaLd0n » 11 Jan 2019, 00:27
ruglau, I think need only usb2 and usb3 devices, if have usb-c too
fan control? or fan rpm with sensors?
ruglau
CPU: 9900k
Post by ruglau » 12 Jan 2019, 14:52
11 Jan 2019, 00:27
Hi dear!
yes but I have usb 3.1 gen2, so for testing that speed I read that I have to use a 3.1 gen2 device, is that right?
I can't see fan sensor on HWmonitr, so I can't see fan and also I can't control them!
Post by MaLd0n » 12 Jan 2019, 16:02
ruglau, check here a usb patch
ruglau
CPU: 9900k
Post by ruglau » 13 Jan 2019, 11:23
ok Maldon, i'll try to see, and for fan? I followed some people on facebook but nothing works..
Post by MaLd0n » 13 Jan 2019, 11:47
ruglau, i don't understand what u need for fan
ruglau
CPU: 9900k
Post by ruglau » 13 Jan 2019, 11:59
I saw some people display and control FAN on HWmonitor, instead my hack didn't recognize none fans connected :(
