DELL INSPIRON 15R 5520 Laptops (Mojave) (Dual boot Windows 10) -Success
Sampath007
CPU: i7-8550u
Motherboard: Acer Nitro 515-31
GPU: UHD 620
Re: DELL INSPIRON 15R 5520 Laptops (Mojave) (Dual boot Windows 10) -Success
Post by Sampath007 » 06 Mar 2019, 17:51
Same laptop? Then check your bios all setting them update BIOS
Sampath007
CPU: i7-8550u
GPU: UHD 620
Post by Sampath007 » 11 Mar 2019, 19:24
04 Mar 2019, 07:31
when i repalce files i got restart loop
Can u share -v boot pic
kareemahmed
CPU: 2.49 GHz Intel Core i5
Motherboard: dell inspiron n5520
GPU: Intel HD Graphics 4000
Post by kareemahmed » 15 Mar 2019, 11:16
plz need ufei file to dell inspiron 15r 5520 (mojave)
Sampath007
CPU: i7-8550u
GPU: UHD 620
Post by Sampath007 » 16 Mar 2019, 19:21
15 Mar 2019, 11:16
U contact me here
cyblet
CPU: i5
Motherboard: Dell
GPU: HD4000
Post by cyblet » 03 Apr 2019, 17:27
Sampath,
I have some questions. On Post-Install step 5, Open Usb Then Go Files Folder Clover BootLoader.
I do not have a Clover Bootloader folder. Is this supposed to be on the Olarila USB? I only see Clover Configurator and Configurator Pro. Would it be one of those?
Also, what is With Out Patch and With Patch? Would I do both? What does these files do?
Post by MaLd0n » 03 Apr 2019, 17:31
cyblet, [External Link Removed for Guests]
-Donated? Send me one PM-
Sampath007
CPU: i7-8550u
GPU: UHD 620
Post by Sampath007 » 05 Apr 2019, 09:00
03 Apr 2019, 17:31
:meeting
skilltom1974
CPU: Dell inspiron
Motherboard: Dell
GPU: Intel
Post by skilltom1974 » 18 Jul 2019, 19:56
did what it said still won't load clover on startup
04 Oct 2018, 14:06
Special thanks Maldon and Vinoth,Andres, Jenny David,Razz,Etc,.
System Specs:
CPU: Intel :Intel Core i5-3210M (3rd Gen) Its Applicable I3&I7 too
GPU: AMD Radeon HD 7670M disabled by DSDT patch or use Olarila High Sierra config02.plist in USB image), Intel HD 4000
RAM: 8Gb DDR3 1600Mhz
Ethernet: : Realtek 8105E
Wifi: Qualcomm Atheros AR5B195) Replaced(Its Only for 10.13 and below)
Mojave 9285 Guide Given Here :poke
Audio chipset:Conexant HD CX20590
(Layout ID=03)
Card Reader: Realtek (Not Supported)
System Drive:Samsung Evo 850 Sata Ssd 250GB (Natively Supported in Mac os)
Secondary Drive: SATA Segate 1TB
Lets Start
Bios Settings:
1. 1St Update Latest Version Bios via Windows.
2. Power on the system. As soon as the first logo screen appears, immediately press F2 to enter the BIOS.
3. Go Sata Set IDE to AHCI.
4. Disabel Secure Boot.
5. Disable Lagcy Boot and Boot Set UEFI Only .
6. Press the F10 key and select Yes to save the changes and exit the BIOS.
OS Images Get Here:
:guitar Creating Mojave USB Installer:
(Windows Based Guide)
After Download Olarila Mojave .raw Extract Zip Using WinZip After Extract Restore
Using Win32 Disk Imager([External Link Removed for Guests])
:hammer (Mac OS Based Guide)
After Download Olarila Mojave.raw Extract Zip Using WinZip After Extract Restore
Using Etcher.app([External Link Removed for Guests])
YouTube Guide
Post Installation:
1. Press F12 the boot Menu.
2. Choose Olarila Usb
3. At the Clover Screen, choose your new Mojave installation.
4. Complete macOS setup
5.Open Usb Then Go Files Folder Clover BootLoader.
:frantics How to install Clover bootloader – LEGACY& UEFI
Without Patched:
After Finished Boot loader Open usb then go Files folder Open EFI Mounter pro Mount HDD EFI Folder Open EFI Delete Clover folder then replace with this clover reboot.
With Out patch.zip
2. With All Patched: Special Credit only for Maldon Best Man Always..
Get Here
patched.zip
Work ????
1. Sleep, Restart and Shutdown
2. Close Lid and Wake LID (Sleep and Wake via LID)
3. Audio Mic and Audio output
4. Touchpad
5. FN + Brightness Up + Down
6. Fn + Volume Up + Down
7. Dual Boot with Windows 10
8. All USB ports and Super Speed USB 3.0 Work (5GB / s)
Not work ??
- Etc
:wallbash How to Do Dual-boot (Bios Only UEFI mode)
1. Make EUFI Windows bootable disk using Rufus 2.7 or later([External Link Removed for Guests])
2. Boot into laptop with USB stick
3. When at Choose Disk to install page, Press shift+F10 to enter command mode
4. Type diskpart
5. Type list disk
6. Select disk x (x is primary hd or ssd)
7. Type convert gpt
8. Type create partition efi size=200 if its not created
9. Type format fs=fat32 quick
10. Type create partition primary size=xxxxxx (in MB)
11. Type format fs=ntfs quick
12. Type exit
13. Continue to install till end
60% Clover Automatically fetch Windows Boot Folder ifts Not work We Need Add Manually Using Easy UEFI Guide Given Below
Step 1:
Run EasyUEFI and See which Boot Entries are available,now we gonna add Missing Entry for OSX Bootloader ( Clover Bootloader ).
Disk0 is usually the internal Hard Drive / SSD. In the Boot order section, we can see that only Windows Boot Manager is detected. There is no mention of Clover UEFI anywhere.
Step 2: To solve this problem, click on the Add button (the second button you see on the right)
Step 3: Now Change Type fromWindows BootManager to Linux or Other OS , Type Name in Description Box (Whatever you want Clover Bootloader or Mac OSX Bootloader or Else depends upon you), and Click Browse Button.
Step 4: Now Expand EFI => BOOT or CLOVER Folder , Select any of Bootx64.efi or Cloverx64.efi , Both are Clover Bootloader files Choose one or add Entry for Both but one is Enough to Boot Clover then why you waste your time but if you having Issue with and Then Use Another Option.
Step 5: Add Newly Created Option In Bios Boot Menu Choose as Boot Device Save then reboot
All Done Enjoy :superman
Happy Hackintosh
Sharing is Caring Donate Olarila Maldon :help
skilltom1974
CPU: Dell inspiron
Motherboard: Dell
GPU: Intel
Post by skilltom1974 » 20 Jul 2019, 05:43
for this laptop can I get higher resolution on laptop screen or just got to usb monitor?
Sampath007
CPU: i7-8550u
GPU: UHD 620
Post by Sampath007 » 20 Jul 2019, 09:34
20 Jul 2019, 05:43
This laptop screen not support High resolution if u need u can use external high resolution monitors
Sampath007
CPU: i7-8550u
GPU: UHD 620
Post by Sampath007 » 20 Jul 2019, 09:35
18 Jul 2019, 19:56
Kindly read this guide Corry it's work surly
skilltom1974
CPU: Dell inspiron
Motherboard: Dell
GPU: Intel
Post by skilltom1974 » 21 Jul 2019, 03:25
I waisted three days on and just now realized that highest resolution of that laptop screen
skilltom1974
CPU: Dell inspiron
Motherboard: Dell
GPU: Intel
Post by skilltom1974 » 21 Jul 2019, 04:29
How to get to boot on it’s own without USB is not working with the guide supplied with clover ego and no sound on movave just sound on high Sierra plz help
Sampath007
CPU: i7-8550u
GPU: UHD 620
Post by Sampath007 » 21 Jul 2019, 10:29
21 Jul 2019, 04:29
It's my fb id u came there I can help
kareemahmed
Post by kareemahmed » 05 Sep 2019, 20:25
hdmi work or not
thank you
Sampath007
CPU: i7-8550u
GPU: UHD 620
Post by Sampath007 » 05 Sep 2019, 23:45
It's working perfectly :superman
Added in 1 minute 16 seconds:
05 Sep 2019, 20:25
hdmi work or not
thank you
