Guide - MSI B360 Gaming Arctic (Catalina)
onemanosx
Guide - MSI B360 Gaming Arctic (Mojave)
Post by onemanosx » 15 Jul 2019, 11:38
15 Jul 2019, 11:33
so first need to enable graphics, then I can move on to enable quick sync right?
No. Intel need not be full acceleration in quicksync mode. You should place your gtx back in the system
MacUser
CPU: Core i3 8100
Motherboard: Asus B 360M-A
GPU: Nvidia GTX 750
Post by MacUser » 15 Jul 2019, 11:54
15 Jul 2019, 11:38
Suppose if I put my GFX back in system can I able to enable intel quick sync feature with my monitor connected to GFX??
onemanosx
Post by onemanosx » 15 Jul 2019, 12:14
MacUser, I already explained.
MacUser
CPU: Core i3 8100
GPU: Nvidia GTX 750
Post by MacUser » 01 Aug 2019, 06:51
Moderator,
Now i am using High sierra 10.13.6 OS.and also enable USB 3 using clover and ioreg(I don't know how to enable 3.1).but while checking speed of my USB 3 ports it shows USB 2 Speed,any help.
Thanks and Regards,
onemanosx
Post by onemanosx » 01 Aug 2019, 06:59
01 Aug 2019, 06:51
Moderator,
Thanks and Regards,
scroll to previous posts and download my custom USB kext. Place in clover/kext/other folder and delete any other usb kexts you might have.
MacUser
CPU: Core i3 8100
GPU: Nvidia GTX 750
Post by MacUser » 01 Aug 2019, 07:17
01 Aug 2019, 06:59
I tried Sir,but after placing your Kext in other folder usb Mouse and KBD becomes dead.
onemanosx
Post by onemanosx » 01 Aug 2019, 07:20
MacUser, are you using similar MSI B360 Gaming Arctic? I am assuming you are .. :) my kext is specific to this board only.
Anyway, upload sendme files so I can take a look later when I am on my mac
MacUser
CPU: Core i3 8100
GPU: Nvidia GTX 750
Post by MacUser » 01 Aug 2019, 07:24
01 Aug 2019, 07:20
No i am using Asus B360MA, here is my Send me file....
onemanosx
Post by onemanosx » 01 Aug 2019, 07:29
01 Aug 2019, 07:24
that explains it then. Sorry for my assumption. I will take a look at your config later the day. Btw, did you test USB 3.0 ports with a proper USB 3.0 device?
MacUser
CPU: Core i3 8100
GPU: Nvidia GTX 750
Post by MacUser » 01 Aug 2019, 07:38
yes i am using Sandisk Dual Drive USB Type-C 32 GB pen drive for testing.
onemanosx
Post by onemanosx » 01 Aug 2019, 07:43
MacUser, based on your clover boot arg for 15 ports USB, let me know which ports are USB type C, USB 2.0 and 3.1 speed.
MacUser
CPU: Core i3 8100
GPU: Nvidia GTX 750
Post by MacUser » 01 Aug 2019, 14:50
01 Aug 2019, 07:43
Here is my USB list :-
HS07 :- USB 2.0 Connected Keyboard
HS08 :- USB 2.0 Mouse Connected
HS10 :- Front Right USB 2.0
HS11 :- Front left USB 2.0
SS01 :- Back USB 3.1
SS02 :- Back USB 3.1
SS03 :- Back USB Type C
SS04 :- Internal USB I havent tested.
SS05 :- Internal USB I havent tested.
SS06 :- Internal USB I havent tested.
Thanks,
onemanosx
Post by onemanosx » 01 Aug 2019, 15:28
MacUser, Block USBInjectAll and XHCI-unsupported kext in clover so that they will not load.
Upload a copy of Ioreg as proof.
ASUS-B360-USB.kext.zip
More can be done to further tweak your build but there are no ACPI tables in origin folder.
And, your clover driver folder needs to be cleaned up. Basically, you either use just aptiomemoryfix or combo of osxaptiofix3+emuvariable. NOT ALL at the same time. You also do not need legacy aptiomemoryfix-64 driver in UEFI
MacUser
CPU: Core i3 8100
GPU: Nvidia GTX 750
Post by MacUser » 01 Aug 2019, 15:38
01 Aug 2019, 15:28
As per your Instruction i have removed 2 kext from "Other" folder and Place your compiled kext.but USB 3 Speed is same as previous.
onemanosx
Post by onemanosx » 01 Aug 2019, 15:40
01 Aug 2019, 15:38
Proof of ioreg. As I had said, use a true USB type C device to test. Not all devices comply. Do you have other USB type C devices to test?
MacUser
CPU: Core i3 8100
GPU: Nvidia GTX 750
Post by MacUser » 01 Aug 2019, 15:46
01 Aug 2019, 15:40
Did i need to remove usb comment from clover for using new USB kext?
And the Device i am using is brand new,its working very well In Windows 10.
onemanosx
Post by onemanosx » 01 Aug 2019, 15:54
01 Aug 2019, 15:46
Yes, you can remove the boot argument. Its only useful if used with USBInjectAll kext. You can also remove Clover's kext to patch USB Patch Limit.
The IOReg shows USB type C speed is detected.
FYI,
0x9 or 0x0A = USB TYPE C
0X3 = USB 3.0
Press F4 at clover bootloader and upload files in clover/acpi/origin folder.
You can also remove the unused kexts as highlighted.
MacUser
CPU: Core i3 8100
GPU: Nvidia GTX 750
Post by MacUser » 02 Aug 2019, 05:51
As per your Instruction i have remove USB boot argument as well as unwanted kexts. And uploaded Origin folder...
onemanosx
Post by onemanosx » 02 Aug 2019, 10:49
MacUser, Place DSDT in clover/acpi/patched
Use renames in Clover
change HDAS to HDEF
change HECI to IMEI
change SAT0 to SATA
Upload new sendme files for checking.
MacUser
CPU: Core i3 8100
GPU: Nvidia GTX 750
Post by MacUser » 02 Aug 2019, 14:20
02 Aug 2019, 10:49
change HDAS to HDEF
change HECI to IMEI
change SAT0 to SATA
Why i need to mentioned above comments in config.plist?As i having issue with my USB Speed not with Audio
