Acer Aspire V15 Nitro Black Edition VN7-592G (High Sierra/Mojave/Catalina) (Dual boot Windows 10) – Success
Naveed Ahmad
CPU: i5 8400 + i3 7100U
Motherboard: GA-Z370M-D3H+Aspire Mob 7thGen
GPU: Intel UHD 630+ Intel HD 620
Acer Aspire VN7-592G (High Sierra/Mojave) (Dual boot Windows 10) – Success
Post by Naveed Ahmad » 14 Nov 2018, 15:49
04 Aug 2018, 13:19
Update: Mojave Direct Update (09/11/2018)
Update: Brightness slider works without AppleBackLightInjector.kext & backlight slider hot-patch (05/09/2018) [Local Link Removed for Guests]
Update: DSDT Fix to enable supported Wifi 26/08/2018 (See Post 5: [Local Link Removed for Guests] )
Update: DSDT edit to enable usb ports without injector kext 26/08/2018 (See post 4: [Local Link Removed for Guests])
Update: Added Clover Arbitrary for Thunderbolt 3 hot plug feature. Device still need to be switched on before system boot. 19/08/2018
Update: Was surfing Acer's website for Bios update details and found I dont need the framebuffer patch for Skylake 13/8/2018
Update: USB type C works with Display output and USB 3.1. (No means to test thunderbolt capabilities though 12/8/2018)
Update: Custom brightness hotkeys 11/08/2018
This is a quick rundown of how I set up my laptop for Sierra, High Sierra and Mojave Beta 10. In no way, I am an expert in hackintosh but one thing I have learnt when hackintoshing is that reading (like a lot!), google (yes!) and plenty of patience are essential. Its a daunting task LOL
Special thanks to Sampath Kumar and Maldon!
System Specs
CPU: Intel Core i7-6700HQ 2.6Ghz (Skylake)
GPU: GeForce GTX 960M (Optimus disabled by DSDT patch or use Olarila config02.plist in USB image), Intel HD 530
RAM: 8Gb DDR4 2133Mhz
Wifi: Qualcomm Atheros QCA4xxx (replaced with Mac OS supported BCM94352Z m.2 type)
Audio chipset: Realtek ALC255 (Layout ID=27)
Card Reader: Realtek (Not Supported)
System Drive: M.2 NVME 500GB (Natively Supported in High Sierra)
Secondary Drive: SATA Toshiba 1TB
How-to’s
1. WiFi and Bluetooth (BCM94352Z) – place kexts in Clover>kexts>other
(Reference Guide - [External Link Removed for Guests])
- FakePCIID.kext
- BrcmFirmwareData.kext
- BrcmPatchRam2.kext
- AirportBrcmFixup.kext
2. Full QE/CI Graphics
(Reference Guide: [External Link Removed for Guests])
- HD530, HDMI and usb-c port display
- Clover settings
a. inject intel <true>
b. ig-platform id: 0x191b0000
c. framebuffer patch (Rehabman)
Clover kext to patch
Kext: com.apple.driver.AppleIntelSKLGraphicsFramebuffer
Find Hex: 00002002 00005001
Replace Hex: 00003001 00009000
Comment: 0x19160000/etc, 32MB BIOS, 19MB framebuffer 9MB cursor bytes (credit RehabMan)
[Not required Update 13/08/2018]
DL LInk: [External Link Removed for Guests]
d. whatevergreen.kext (place kexts in Clover>kexts>other)
e. Lilu.kext (place kexts in Clover>kexts>other)
3. Realtek ALC255 Audio (place kexts in Clover>kexts>other)
- AppleALC.kext
- Lilu.kext
- Layout ID= 27
(microphone not working)
4. HDMI audio
- Full Guide [External Link Removed for Guests]
5. Ethernet (place kexts in Clover>kexts>other)
Reference link: [External Link Removed for Guests]
- RealtekRTL8111.kext
6. USB ports (place kexts in Clover>kexts>other)
USB Port limits info: [Local Link Removed for Guests]
- USBInjectAll.kext
- Optional: custom ssdt for USBInjectall kext
- High Sierra USB kext to patch
Find Hex: 837D880F 0F83A704 0000
Replace Hex: 837D880F 90909090 9090
Comment: USB 10.13.6 by PMHeart
7. Battery info (place kexts in Clover>kexts>other)
Reference Link: [External Link Removed for Guests]
- ACPIBatteryManager.kext
8. Keyboard (place kexts in Clover>kexts>other)
- VoodooPS2controller.kext
9. Trackpad & Gestures (place kexts in Clover>kexts>other)
Full Guide: [External Link Removed for Guests]
- voodooI2C.kext
- voodooI2CHID.kext
- DSDT patch (refer to attached link above)
10. Integrated webcam works (Native)
11. Native Power Management
- Clover> ACPI> SSDT> Generate options> plugin type =1
12. Clover DSDT rename patches
- GFX0>IGPU
- SAT0>SATA
- EC0>EC
- HDAS>HDEF
13. Brightness Slider
- AppleBackLightInjector.kext + SSDT-PNLF.aml + Clover kext to patch
14. Custom Brightness Hotkey
Debugging Method :
Applicable DSDT patch to VN7-592G
into method label _Q1D replace_content
begin
// Brightness Down\n
Notify(\_SB.PCI0.LPCB.KBD0, 0x0205)\n
Notify(\_SB.PCI0.LPCB.KBD0, 0x0285)\n
end;
into method label _Q1C replace_content
begin
// Brightness Up\n
Notify(\_SB.PCI0.LPCB.KBD0, 0x0206)\n
Notify(\_SB.PCI0.LPCB.KBD0, 0x0286)\n
end;
I noticed this laptop has problem with windows installation in "auto". That is, I faced problematic "unable to install ...." no matter what file system I created. Then I figured out a way to manually create GPT partition as described in the guide below.
How to Dual-boot (Bios is set to UEFI mode)
A.
1. Make UEFI Windows bootable disk using Rufus 2.7 or later([External Link Removed for Guests])
2. Boot into laptop with USB stick
3. When at Choose Disk to install page, Press shift+F10 to enter command mode
4. type diskpart
5. type list disk
6. select disk x (x is primary hd or ssd)
7. type convert gpt
8. type create partition efi size=200
9. type format fs=fat32 quick
10. type create partition primary size=xxxxxx (in MB)
11. type format fs=ntfs quick
12. type exit
13. continue to install till end
B. Go to Windows Disk utility and create a partition (Fat 32 file system) for MacOS
C. Shutdown windows once partition is created
D. Boot Olarila USB stick to proceed with MacOS installation.
Choose Olarila image here : [Local Link Removed for Guests]
Hi OneManOsX
my BCM94352Z M.2 WiFi is Successful working but not showing in PCI List Like This ?
Mobile
SkyLake
DELL LATiTUDE E-7470 14" 6th Gen
Display Touch Screen Working on Mojave-10.14.3
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Hynix 256 GiB Nvme SSD
Clover UEFI 10.14.3
:cap :frantics :guitar :shock:
onemanosx
Post by onemanosx » 14 Nov 2018, 22:55
14 Nov 2018, 15:49
1. Extract the file here
SSDT-ARPT.aml.zip
2. Open ssdt file with MacIASL
3. Change RP07 to RP0x (Use Ioreg to find out the location of your wifi card)
4. Save ssdt inside Clover/ACPI/Patched. Reboot. (if you are using sorted order, make sure to add the file to the table)
MSI B360 Gaming Arctic
Naveed Ahmad
Post by Naveed Ahmad » 15 Nov 2018, 09:03
14 Nov 2018, 22:55
1. Extract the file here SSDT-ARPT.aml.zip
PLZ share your EFI folder for assistance
Mobile
SkyLake
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Clover UEFI 10.14.3
onemanosx
Post by onemanosx » 15 Nov 2018, 09:09
:poke
Naveed Ahmad
Post by Naveed Ahmad » 15 Nov 2018, 09:11
[quote=onemanosx post_id=66504 time=1542272953 user_id=69706]
[/quote OneManOsX PLZ share your EFI folder for assistance I do not understand
Mobile
SkyLake
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Clover UEFI 10.14.3
onemanosx
Post by onemanosx » 15 Nov 2018, 09:14
use
15 Nov 2018, 09:11
Which part of the guide you do not understand?
Naveed Ahmad
Post by Naveed Ahmad » 15 Nov 2018, 09:24
I send u my EFI folder and ioreg check it
Mobile
SkyLake
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Clover UEFI 10.14.3
onemanosx
Post by onemanosx » 15 Nov 2018, 12:46
Naveed Ahmad, try this.
Naveed.zip
Naveed Ahmad
Post by Naveed Ahmad » 15 Nov 2018, 14:14
[quote=onemanosx post_id=66514 time=1542286003 user_id=69706]
Naveed Ahmad, try this.Naveed.zip
Great Work OneManOsX thanks.Bluetooth not working
Mobile
SkyLake
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Clover UEFI 10.14.3
onemanosx
Post by onemanosx » 15 Nov 2018, 14:24
15 Nov 2018, 14:14
Bluetooth use correct kexts and make sure USB for bluetooth is working. Read my guide and link
Naveed Ahmad
Post by Naveed Ahmad » 15 Nov 2018, 15:09
[quote=onemanosx post_id=66523 time=1542291847 user_id=69706]
Thanks OneManOsX Bluetooth Now Working :superman
Mobile
SkyLake
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Clover UEFI 10.14.3
Naveed Ahmad
Post by Naveed Ahmad » 27 Nov 2018, 10:51
09 Nov 2018, 15:46
Mojave Update
I wasn't planning to upgrade this laptop to Mojave. Well, not anytime soon anyway. But, installing Mojave on an external HD is close enough to see if anything will break due to the upgrade. Looks like its pretty much the same except for update of kext for I2c trackpad.
Beyond that, airdrop does not seem to work well. But, I did not spend too much time troubleshooting anyway.
hi onemanosx
Mobile
SkyLake
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Clover UEFI 10.14.3
onemanosx
Post by onemanosx » 27 Nov 2018, 12:08
27 Nov 2018, 10:51
hi onemanosx
:cap
Naveed Ahmad
Post by Naveed Ahmad » 27 Nov 2018, 12:44
27 Nov 2018, 12:08
:cap
Sir can you set my wifi card in DSDT, and set my USB in DSDT like your wifi card and your USB (zero to one method) iam trying to morning but not set. I extract my DSDT in windows 10 x64 I attached my vanilla DSDT PLZ all Patched Applied and Set these Wifi and USB.
barhi barhi maharbani. hahaha. :)
Mobile
SkyLake
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Clover UEFI 10.14.3
onemanosx
Post by onemanosx » 27 Nov 2018, 13:56
27 Nov 2018, 12:44
wifi card in DSDT
follow this guide [Local Link Removed for Guests]
27 Nov 2018, 12:44
Cannot help without your USB detail
I suggest you follow this guide first [Local Link Removed for Guests]
Naveed Ahmad
Post by Naveed Ahmad » 27 Nov 2018, 14:58
[quote=onemanosx post_id=67868 time=1543326977 user_id=69706]
[/quoteDear onemanosx
I found my wifi card in RP06. know how to add in dsdt to fix this and ad in Clover Acpi DSDT/Devices
my pics attached
Mobile
SkyLake
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Clover UEFI 10.14.3
onemanosx
Post by onemanosx » 27 Nov 2018, 15:04
Naveed Ahmad,
Find Device PXSX in RP06 and add in the script like in the picture Image
Device (PXSX)
            Name (_ADR, Zero)  // _ADR: Address
            Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method
                If ((Arg2 == Zero))
                    Return (Buffer (One)
                         0x03                                             // .
                Return (Package (0x0C)
                    "AAPL,slot-name",
                    "PCI Slot",
                    "built-in",
                    Buffer (One)
                         0x00                                             // .
                    "model",
                    Buffer (0x43)
                        "Broadcom Inc., BCM94352Z M.2 NGFF 802.11ac 867Mbps Wifi + BTLE 4.0"
                    "name",
                    Buffer (0x10)
                        "Airport Extreme"
                    "device_type",
                    Buffer (0x10)
                        "Airport Extreme"
                    "compatible",
                    "pci14e4,43a0"
Naveed Ahmad
Post by Naveed Ahmad » 27 Nov 2018, 15:23
27 Nov 2018, 15:04
Naveed Ahmad,
Device (PXSX)
            Name (_PRW, Package (0x02)  // _PRW: Power Resources for Wake
                0x09,
                0x04
                If ((Arg2 == Zero))
                         0x03                                             // .
                    "AAPL,slot-name",
                    "PCI Slot",
                    "built-in",
                    Buffer (One)
                         0x00                                             // .
                    "model",
                    Buffer (0x43)
                    "name",
                    Buffer (0x10)
                        "Airport Extreme"
                    "device_type",
                    Buffer (0x10)
                        "Airport Extreme"
                    "compatible",
                    "pci14e4,43a0"
plz add you your self in RP06 PXSX I have no idea plz
Mobile
SkyLake
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Clover UEFI 10.14.3
onemanosx
Post by onemanosx » 27 Nov 2018, 15:31
Naveed Ahmad,
Try
Naveed Ahmad
Post by Naveed Ahmad » 27 Nov 2018, 15:34
27 Nov 2018, 15:31
Naveed Ahmad,
Try
Dear onemanosx
know remove all kext and ssd-arpt.aml ?
Mobile
SkyLake
Cpu Intel i5-6300U
GPU QHD-540/520
Res FHD 2560 x 1440
Ram 12GB DDR4
Clover UEFI 10.14.3
