🎉 NEW Discord server!
How to patch AppleHDA
sleepynow
CPU: I3 370M
Motherboard: Acer 4749
GPU: Intel HD Graphics Arrandale
Post by sleepynow »
21 Jan 2019, 12:02
sleepynow, u try a AppleHDAPatcher?
MaLd0n, yes I tried applehda patcher, all of code 269 and 271x cant bring my sound out
Mirone
Developer
Developer
CPU: Intel Core i7-8700k
GPU: Radeon RX 560 - 4GB
Post by Mirone »
MaLd0n,
Biba to sem whats, se for mandar a parada hoje me envia um PM ou e-mail.
Post by MaLd0n »
Mirone, já te respondi PM
paolot0rr3s
CPU: Intel i5
Motherboard: Dell Latitude 3440
GPU: Intel
Post by paolot0rr3s »
this link does not work anymore [External Link Removed for Guests]
Is there anyone who can point me where I can download it?
Post by MaLd0n »
paolot0rr3s, check now
paolot0rr3s
CPU: Intel i5
GPU: Intel
Hi Peeps,
I hope someone can help me. I tried the Apple Patch HDA 1.9 but not work. So it pointed me here and I tried the dump. I kinda followed everything but here is the dump. Let me know if you need some more. I have a Dell Latitude 3440 running Mojave.
Codec: Realtek ALC3223
Address: 0
AFG Function Id: 1 (unsol 1)
Vendor Id: 283902595
Subsystem Id: 271058438
Revision Id: 1048579
No Modem Function Group found
Default PCM:
    rates [1376]: 44100 48000 96000 192000
    bits [14]: 16 20 24
    formats [1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 1:
  Power states:  D0 D1 D2 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 2 [Audio Output] wcaps 1053: Stereo Amp-Out
  Control: name="Speaker Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Amp-Out caps: ofs=87, nsteps=87, stepsize=2, mute=0
  Amp-Out vals:  [61 61]
  Converter: stream=5, channel=0
  PCM:
    bits [14]: 16 20 24
    formats [1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 3 [Audio Output] wcaps 1053: Stereo Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
  Device: name="ALC3223 Analog", type="Audio", device=0
  Amp-Out vals:  [0 0]
  PCM:
    bits [14]: 16 20 24
    formats [1]: PCM
Node 4 [Vendor Defined Widget] wcaps 15728640: Mono
Node 5 [Vendor Defined Widget] wcaps 15728640: Mono
Node 6 [Audio Output] wcaps 1553: Stereo Digital
  Converter: stream=0, channel=0
  Digital:
  Digital category: 0
  IEC Coding Type: 0
  PCM:
    rates [1504]: 44100 48000 88200 96000 192000
    bits [14]: 16 20 24
    formats [1]: PCM
  Power: setting=D3, actual=D3
Node 7 [Vendor Defined Widget] wcaps 15728640: Mono
Node 8 [Audio Input] wcaps 1049883: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In caps: ofs=23, nsteps=63, stepsize=2, mute=1
  Amp-In vals:  [39 39]
  SDI-Select: 0
  PCM:
    bits [14]: 16 20 24
    formats [1]: PCM
  Connection: 1
     35
Node 9 [Audio Input] wcaps 1049883: Stereo Amp-In
  Amp-In vals:  [151 151]
  SDI-Select: 0
  PCM:
    bits [14]: 16 20 24
    formats [1]: PCM
  Connection: 1
     34
Node 10 [Vendor Defined Widget] wcaps 15728640: Mono
Node 11 [Audio Mixer] wcaps 2097419: Stereo Amp-In
  Control: name="Headset Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=1, ofs=0
  Control: name="Headset Mic Playback Switch", index=0, device=0
  Control: name="Headphone Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=2, ofs=0
  Control: name="Headphone Mic Playback Switch", index=0, device=0
  Amp-In caps: ofs=23, nsteps=31, stepsize=5, mute=1
  Amp-In vals:  [128 128] [128 128] [128 128] [128 128] [128 128]
  Connection: 5
     24 25 26 27 29
Node 12 [Audio Mixer] wcaps 2097419: Stereo Amp-In
  Amp-In caps: ofs=0, nsteps=0, stepsize=0, mute=1
  Amp-In vals:  [0 0] [128 128]
  Connection: 2
     2 11
Node 13 [Audio Mixer] wcaps 2097419: Stereo Amp-In
  Connection: 2
     3 11
Node 14 [Vendor Defined Widget] wcaps 15728640: Mono
Node 15 [Audio Mixer] wcaps 2097418: Mono Amp-In
  Amp-In vals:  [0 0]
  Connection: 1
     13
Node 16 [Vendor Defined Widget] wcaps 15728640: Mono
Node 17 [Audio Input] wcaps 1049883: Stereo Amp-In
  Converter: stream=1, channel=0
  SDI-Select: 0
  PCM:
    bits [14]: 16 20 24
    formats [1]: PCM
  Connection: 1
     18
Node 18 [Pin Complex] wcaps 4195339: Stereo Amp-In
  Control: name="Internal Mic Boost Volume", index=0, device=0
  Amp-In caps: ofs=0, nsteps=3, stepsize=47, mute=0
  Amp-In vals:  [0 0]
  Pincap 32: IN
  Pin Default 2426798384: [Fixed] Mic at Int N/A
    Conn = Digital, Color = Unknown
    DefAssociation = 3, Sequence = 0
    Misc = NO_PRESENCE
  Pin-ctls: 32: IN
Node 19 [Vendor Defined Widget] wcaps 15728640: Mono
Node 20 [Pin Complex] wcaps 4195725: Stereo Amp-Out
  Control: name="Speaker Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0, nsteps=0, stepsize=0, mute=1
  Amp-Out vals:  [0 0]
  Pincap 65556: OUT EAPD Detect
  EAPD 2: EAPD
  Pin Default 2417426704: [Fixed] Speaker at Int N/A
    Conn = Analog, Color = Unknown
    DefAssociation = 1, Sequence = 0
    Misc = NO_PRESENCE
  Pin-ctls: 64: OUT
  Unsolicited: tag=00, enabled=0
  Connection: 1
     12
Node 21 [Vendor Defined Widget] wcaps 15728640: Mono
Node 22 [Vendor Defined Widget] wcaps 15728640: Mono
Node 23 [Pin Complex] wcaps 4195596: Mono Amp-Out
  Amp-Out vals:  [128]
  Pincap 16: OUT
  Pin Default 1073872904: [N/A] Line Out at Ext N/A
    Conn = 1/4, Color = Unknown
    DefAssociation = 0, Sequence = 8
  Pin-ctls: 0:
  Connection: 1
     15
Node 24 [Pin Complex] wcaps 4195467: Stereo Amp-In
  Amp-In vals:  [0 0]
  Pincap 14116: IN Detect
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 1091637744: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 15, Sequence = 0
    Misc = NO_PRESENCE
  Pin-ctls: 32: IN VREF_HIZ
Node 25 [Pin Complex] wcaps 4195467: Stereo Amp-In
  Control: name="Headset Mic Boost Volume", index=0, device=0
  Amp-In vals:  [0 0]
    Misc = NO_PRESENCE
  Pin-ctls: 36: IN VREF_80
Node 26 [Pin Complex] wcaps 4195467: Stereo Amp-In
  Control: name="Headphone Mic Boost Volume", index=0, device=0
  Amp-In vals:  [0 0]
    Misc = NO_PRESENCE
Node 27 [Pin Complex] wcaps 4195727: Stereo Amp-In Amp-Out
  Amp-In vals:  [0 0]
  Amp-Out vals:  [128 128]
  Pincap 79676: IN OUT HP EAPD Detect
  EAPD 2: EAPD
    Misc = NO_PRESENCE
  Connection: 2
     12* 13
Node 28 [Vendor Defined Widget] wcaps 15728640: Mono
Node 29 [Pin Complex] wcaps 4195328: Mono
  Pincap 32: IN
  Pin Default 1088421889: [N/A] Reserved at Ext N/A
    Conn = Unknown, Color = Unknown
    DefAssociation = 0, Sequence = 1
  Pin-ctls: 32: IN
Node 30 [Pin Complex] wcaps 4196225: Stereo Digital
  Pincap 20: OUT Detect
    Misc = NO_PRESENCE
  Pin-ctls: 64: OUT
  Connection: 1
     6
Node 31 [Vendor Defined Widget] wcaps 15728640: Mono
Node 32 [Vendor Defined Widget] wcaps 15728704: Mono
  Processing caps: benign=0, ncoeff=73
Node 33 [Pin Complex] wcaps 4195725: Stereo Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pincap 65564: OUT HP EAPD Detect
  EAPD 2: EAPD
  Pin Default 52498463: [Jack] HP Out at Ext Left
    DefAssociation = 1, Sequence = 15
  Pin-ctls: 192: OUT HP
  Unsolicited: tag=01, enabled=1
  Connection: 2
     12 13*
Node 34 [Audio Mixer] wcaps 2097419: Stereo Amp-In
  Amp-In vals:  [128 128] [128 128] [128 128] [128 128] [128 128] [128 128]
  Connection: 6
     24 25 26 27 29 11
Node 35 [Audio Mixer] wcaps 2097419: Stereo Amp-In
  Connection: 6
     24 25 26 27 29 11
Added in 2 minutes 27 seconds:
03 Apr 2019, 18:02
still does not work. I downloaded the verb app.
Mirone
Developer
Developer
Post by Mirone »
paolot0rr3s, your codec is ALC283 you tried all versions for this codec?
paolot0rr3s
CPU: Intel i5
GPU: Intel
I tried the apple hda patch. It doesn't work. I followed the tutorial in the channel do you want me to do something to check if I repatch it again with the apple hda?
I did the dump but I think I got confused on the DSDT.
04 Apr 2019, 15:58
I
manhquang123123
CPU: i3 2328M
Motherboard: Lenovo G480 20156
GPU: GT 610M
Post by manhquang123123 »
I can't patch ALC269VC, and I'm not sure if it is v1 or v2, just voodoohda, please help me patch them, my laptop is lenovog480 20156 i3 2328m, 4gb, gt610m (doesn't work). run El Capitan My codecs dump from ubuntu and clover
khalidthami
CPU: i7-8565U
Motherboard: Asus UX433FA
GPU: HD620
Post by khalidthami »
Hello do you help In sound activation
ven though it seems like audio is working, there is no sound coming from speaker/headphones
alc294
Added in 9 minutes 2 seconds:
Capture d’écran
Mirone
Developer
Developer
Post by Mirone »
khalidthami,
try this:
AppleHDA-282.54-ALC294.zip
use layout id = 2 in your config.plist or DSDT, delete voodooHDA or similar kext before.
khalidthami
CPU: i7-8565U
GPU: HD620
Hello. Mr. Mirone, I was able to play the sound before, but I have to take off from his Ubuntu Linux system and then restart it on Catalina. Sound and microphone work very normal, but when you turn off the computer and reboot on Catalina there is no sound
Added in 28 minutes 47 seconds:
layout id = 2 does not work, but with layout id = 21 it works and the volume can be raised, but I hear nothing
Added in 4 minutes 15 seconds:
Capture d’écran 2019-11-04 à 23.17.49.zip
khalidthami
CPU: i7-8565U
GPU: HD620
Can you help me correct the sound please
alc294 asus ux433fa Intel WhiskeyLake
I need a personal Command to CodecCommander.kext for ALC294
Mirone
Developer
Developer
Post by Mirone »
khalidthami,
Unfortunately I don't have time to patch AppleHDA or AppleALC unless I get paid for it.
