How to patch AppleHDA
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Re: How to patch AppleHDA
Post by artur-pt »
that codec is not compatible with apple hda
use voodoohda
[External Link Removed for Guests] - join me at irc.freenode.net/##Olarila
born2bkilled
Post by born2bkilled »
Thanks artur -pt!
any ideas on the HDMI audio?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt »
man read about voodoohda.. have u read anything about ? i think no...
whityini
Post by whityini »
Hello everybody,
I have installed Mavericks into my Qosmio X500. Everything is working correctly :D except for the audio board that has this codec: Conexant CX20583 (Pebble HSF) :cry: .
I have tried using the same AppleHDA, that worked correctly under ML, without any good result.
Do I have to patch the AppleHDA? Is there here anyone that could help me?
Please attached find my DSDT and codec_dump.txt.
Many thanks
Mirone
Developer
Developer
CPU: Intel Core i7-8700k
GPU: Radeon RX 560 - 4GB
Post by Mirone »
Try this: [Local Link Removed for Guests]
whityini
Post by whityini »
Mirone wrote:Try this: [Local Link Removed for Guests]
Thank you Mirone for your prompt reply.
I have checked but it's not working. The AppleHDA.kext is not loaded. The only kexts loaded are IOHDAFamily and AppleHDAController.
Maybe I have to patch the DSDT as described into this guide to inject the HDA? Could you please check my attached DSDT?
Mirone
Developer
Developer
Post by Mirone »
you read the ReadMe file?
Your attached file with this error.
whityini
Post by whityini »
Mirone wrote:you read the ReadMe file?
yes I've read the ReadMe but I don't know how to check if the value is correct or not.
Re-attached my DSDT.aml. (Remove .zip in the name)
Mirone
Developer
Developer
Post by Mirone »
whityini wrote: yes I've read the ReadMe but I don't know how to check if the value is correct or not.
giving the same error, way.
how are you drawing it?
whityini
Post by whityini »
I don't know what's the problem.
Will retry to upload later on.
whityini
Post by whityini »
Mirone here is my DSDT. Hope it will be correct this time.
whityini
Post by whityini »
Mirone good news!!
I have removed the option NCPI=0x3000 from org.chameleon.Boot.plist and now the sound works correctly with your AppleHDA.kext.
It seem the DSDT is correct.
Thanks again for your help.
Mirone
Developer
Developer
Post by Mirone »
try this: [External Link Removed for Guests]
install kext+DSDT, repair permissions rebuild caches using kextwizard.
actrite
CPU: i3
Motherboard: acer
GPU: intel gma
Post by actrite »
Hey there,
I successfully installed Mavericks on my Acer 4820T but the audio is not working.
I believe it is an ALC269. Is there a kext out there already working for this sound card (VoodooHDA) or do I need to patch my AppleHDA?
Thanks for the help
Mirone
Developer
Developer
Post by Mirone »
try this: [Local Link Removed for Guests]
actrite
CPU: i3
Motherboard: acer
GPU: intel gma
Post by actrite »
I installed your kext with Kext Drop and still no sound. Do I need to edit my DSDT with the info from the README file? I currently don't have a DSDT for my laptop/motherboard. Can you assist me in creating one/downloading a pre-existing DSDT file?
PimentelX86
Veteran
Veteran
CPU: i7 2600
Motherboard: IPMH61R1
GPU: GT 610
Post by PimentelX86 »
Hello
You can try install VoodooHDA 2.8.4: [External Link Removed for Guests]
Remeber, remove AppleHDA or install AppleHDADisabler if you want install Voodoo...
Hint: Install with Chameleon Wizard and update cache.
If you don't want use voodoo... send your ioreg+DSDT to Mirone.
actrite
CPU: i3
Motherboard: acer
GPU: intel gma
Post by actrite »
Thanks, I'm going to try that method right now, but just in case I attached my ioreg and dsdt file. I'm willing to do anything to get this working!
actrite
CPU: i3
Motherboard: acer
GPU: intel gma
Post by actrite »
PimentelX86 wrote:Hello
VoodooHDA 2.8.4 works! Thanks a lot
Now If I could only get my video, webcam and wifi (AR9285) working
Doggynub
CPU: i7 sandy bridge
Motherboard: Dell xps l502x motherboard
GPU: NVidia 540M - Intel HD 3000 Mo
Post by Doggynub »
about the part in the applehdacontroller with the device and audio id which one should I put there?!
I have in System info app it shows : DevId = 1c20 - VendId = 8086
but in the codec_dump it shows vendor id = 0x10ec0665
Which one should I put there?
