🎉 NEW Discord server!
How to patch AppleHDA
Mirone
Developer
Developer
CPU: Intel Core i7-8700k
GPU: Radeon RX 560 - 4GB
Re: How to patch AppleHDA
Post by Mirone »
@telanx
if you use the flags npci=0x2000/3000
delete them and restart this flag disables the audio in 10.8.5.
telanx
Post by telanx »
Mirone wrote:@telanx
Dear Mirone:
You are right, I am using the flags npci=0x2000 in clover config.plist.
I have already to del this flag, and reboot, but it is still not working.
but I have a concern on my clover boot loader, there is some problem on config.plist, so, I am asking another guy who has the same audio codec, and use chameleon to boot OSX, after he tried this kext, I will let you know the result.
by the way, is there any other suggestions besides deleting the flags.? any other reason to prevent the kext working?
ps:I am using the OSX 10.8.5(12F45), with Clover Ver. 1958.(UEFI boot)
Mirone
Developer
Developer
Post by Mirone »
@telanx
I just think its weird codec
shows 111d76e in codec_dump
where did you get 111d76e7?
telanx
Post by telanx »
Codec: IDT 92HD90BXX
Address: 0
Vendor Id: 0x111d76e7
from codec_dump.txt, it said 111d76e7, and I checked the codec ID in Windows7, it also said the codec ID is 111d76e7.
I attached two file, one is from my codec(Dell E6320)
codec_dump-E6320.txt.zip
, and the other is from the other guy(Dell E6420)
Codec-E6420.txt.zip
, this two laptop used the same chipset intel QM67, and the same Audio codec IDT 92HD90BXX(111d76e7).
for your reference.
telanx
Post by telanx »
this codec is really wired, currently, I am using this kext for driving my audio card instead of using a VoodooHDA.
Sorry, the file is large than 1M, so i couldn't upload, you can download it from this link [url]https://dl.dropboxusercontent.com/u/6897343/Shared/111d76e7%20Driver.zip[/url]
and I checked the configdata, layout, pathmaps from attached kext, and I tried to add those values into AppleHDA.kext, because those values were proved to be work for my audio card in attached kexts. but unfortunately, it doesn't work at all either....
just for your reference.
telanx
Post by telanx »
I checked with the guy who use dell E6420(has the same Motherboard and Audio Codec), it doesn't work either, he use the chameleon without ncpi=2000 flag.
Mirone
Developer
Developer
Post by Mirone »
@telanx
tonight you upload a kext for you to test.
telanx
Post by telanx »
I tried your kext, and one kext which I modified with the parameters from the kext i currently used, ( this kext used a legacy fakeapplehda method, download link:[External Link Removed for Guests]).
but all failed.
any other kext you want me to check?
this is really a difficult codec, which I barely find a solution till now.(most of other IDT Codec have a solution now) -_-!
Mirone
Developer
Developer
Post by Mirone »
@telanx
try this: [External Link Removed for Guests]
zetarun
Post by zetarun »
Dear Mirone,
I have spend I have spend days and days now looking into the patching process and I am stuck ( as perhaps most people ) at the Platforms.xml patching. I have extracted everything that was required and I am frustrated with myself as I cannot see the three elements in order to calculate the path to my internal speakers and my mic. I am using ML 10.8.5 on a Toshiba L630-14C my codec is Conexant cx20585 (together with an IntelHD). As I have tried various kexts that didn't prove useful I have decided to patch the genuine AppleHDA 2.4.7 but I cannot figure out the last step, could you please have a look and advise me how to proceed, please?
Mirone
Developer
Developer
Post by Mirone »
@zetarun
use as a basis the pathmap
kext with this codec similar to yours,
correct the values ​​needed.
telanx
Post by telanx »
HI, Mirone:
It finally worked for me. Yeah! Thank you very much!
It seems that the Mic didn't work, but I think the pathmap between Mic and LineIn is opposite, maybe I could get it work by change them.
The Headphone didn't work either, maybe the pin config Data for Headphone still need to be modified?
I checked your kext, and find there are two different between Ver.2 and Ver.3. one is the Pin Config Data changed, the other is Patch Map for Internal Speaker changed.
1. For the Pin Config Data:(I summarized those Versions...)
a. You changed lots of numbers. I am wondering why you make this changes to enable the kext? Could you please make some explanation for it?
b. And the Data 0x0a is for IntSpeakers ? 0x0b is for Mic? 0x0d is for Line In? 0x0f is for headphone? right?
2. for the Patch map:
You changed the IntSpeaker's pathmap from 13-->19 to 13-->28-->27-->19. also changed the LineIn and Mic's pathmap ( I can understand it)
Is that all changes between Ver.2 and Ver.3?
Thanks again, you are the MAN!
Mirone
Developer
Developer
Post by Mirone »
@Telanx
You can try to fix the Mic based on your data
I tried different things and I have lost myself
but now it works you can make fine adjustments alone.
I taught you the way
but this is a guide to "Do it yourself".
all the bast!!
Headphone: 13-->28-->27-->19
Speaker: 11-->28-->27-->20
try this!
telanx
Post by telanx »
Mirone wrote:@Telanx
all the bast!!
try this!
Dear Mirone:
Sorry to reply to you so late, I am so busy these days. :-)
I am so sorry to make you misunderstanding, I didn't meant to push you, I just not very quite understand about the Verb Data. so I just want to know why :-)
With your help and suggestions, I have already updated the kext to Ver.4, and test by myself on my Dell E6320, and finally the IntMic, IntSpeakers, Headphone could all work.
Thank you very much! Really appreciate your great help!
The Ver.4 kext: [External Link Removed for Guests]
1. IntMic
2. IntSpeaker
3. Headphone(You must insert the headphone into jack, system will exchange them automatic)
telanx
Post by telanx »
Base on your Kext, I put the relevant information for this Codec(IDT 92HD90BXX 111d76e7) below, hope it could help the following people who has the same codec.
1. Pin Complex(Verb Data)
2. Layout & Pathmaps:
Mirone
Developer
Developer
Post by Mirone »
@telanx
Yes, the headphone is autodetect, as well as external microphone.
Enjoy the good sound!
zetarun
Post by zetarun »
Dear Mirone,
hi... after my last post I've tried virtually any configuration that seemed logical, however none of it worked. Basically at first I tried just changing the cx20583 codec based on my path map but as I don't have the cx20583 path map that you have used I only guessed whether or not my values are correct.
At first the only noticeable difference was that most of your connections were attached to Node 19, so I thought that it is the Mixer and maybe changing only the values of Node 19 -> Node 36 as it turns is my mixer might be sufficient, but no.
MIC internal 23 14 24 hex
35 20 36 dec
MiC Jack 1b 17 16 hex
27 23 22 dec
Audio Out fixed 1f 10 24 hex
31 16 36 dec
Audio Out Jack 19 10 24 hex
25 16 36 dec
but there are other possible paths as well, and the internal mic has only 1 physical connection.
Any suggestions, please?
born2bkilled
Post by born2bkilled »
could anyone post a mediafire link to verbit by signal64? his site is gone and i cant download it. thanks guys.
Edit: Nevermind, i found a copy, now i am picking my way through the platform xml
very complicated! :)
Mirone
Developer
Developer
Post by Mirone »
born2bkilled wrote:could anyone post a mediafire link to verbit by signal64? his site is gone and i cant download it. thanks guys.
the end of the Tab
has all necessary tools even a folder codegraph ready.
Look carefully the next time.
born2bkilled
Hmmmm, not a very successful couple of days :cry:
i cant get AppleHDA working with my setup, after carefully following all the instructions with no real errors or problems.
i cant get HDMI audio working through DSDT (although i am sure the dsdt is working, as i now have sleep working!)
i just cant get anything to show up in the sound setup tab in system profile, although IOReg has references to HDEF and HDAU.
(admittedly i have no idea what i am looking at in IOReg, so i dont know what these references mean!)
AppleHDA just refuses to load, saying the privileges are wrong when trying to force it with kextload.
I am not too bothered about AppleHDA as i have a copy of voodooHDA which i think works with this system, but the HD audio is something i really need due to my speaker setup.
(PC --> HDTV --> 16ch mixing desk --> studio monitor speakers)
My problem is that i am not up to date with my hardware...
OSX 10.8.5
- Asus P5KPL AM-EPU Motherboard (AMI BIOS)
- VIA VT1708S Codec
- Asus HD6670 2GB Gfx Card
- Core2Quad CPU
would anyone be willing to take a look at it for me? see if they can spot what i have done wrong?
i have zipped up everything i can think of that i have needed for this, all the codec dumps, verbs, untouched dsdt, modded dsdt, untouched AppleHDA and modded AppleHDA, copy of IOReg and all the tools i was using.
I understand everyone here has a real life and job, so im not expecting anyone to rush to help. but if someone has a spare minute, id be pretty damn thankful for your help!
