How to patch AppleHDA
fingerr
CPU: i5-560M
Motherboard: Asus U30JC
GPU: Intel HD 1st Gen.
Re: How to patch AppleHDA
Post by fingerr »
Mirone wrote:@fingerr
These ALC269 has many variations among its patchmaps.
I'll help you with it later.
Thanks a million Mirone!!
Waiting patiently :-)
best regards
fingerr
crusher
CPU: Intel i9 9900K
Motherboard: GA-Z390-M Gaming
GPU: RX 580 8GB
Post by crusher »
Mirone wrote:@crusher
try this: [External Link Removed for Guests]
Mirone one question.
Do you need to delete the existing VoodooHDA from S/L/E?
artur-pt
CPU: i5
Motherboard: Lenovo
GPU: Intel
Post by artur-pt »
if u gonna use applehda.. no sense use 2 audio kext...
make a copy of voodoohda u are using.. and then delete
[External Link Removed for Guests] - join me at irc.freenode.net/##Olarila
crusher
CPU: Intel i9 9900K
GPU: RX 580 8GB
Post by crusher »
artur-pt wrote:hello
Hello.But I delete my VoodooHDA and copy AppleHAD in my S/L/E.I work premission and repair disk,and copy DSDT on my Extra folder
,but after restart nothing no sound. :(
Give me some suggestion and thank you.
PimentelX86
Veteran
Veteran
CPU: i7 2600
Motherboard: IPMH61R1
GPU: GT 610
Post by PimentelX86 »
Hello
If AppleHDA doesn't work to you, so VoodooHDA is best choice.
Mirone
Developer
Developer
CPU: Intel Core i7-8700k
GPU: Radeon RX 560 - 4GB
Post by Mirone »
@crusher
crusher,
later sent another kext.
crusher
CPU: Intel i9 9900K
GPU: RX 580 8GB
Post by crusher »
crusher,
Thank you Mirone on your patience....
I'm Waiting.Means that I do not lose hope?
Mirone
Developer
Developer
Post by Mirone »
this using 10.8.5?
delete the flag NPCI = 0x2000/3000 the boot.plist
crusher
CPU: Intel i9 9900K
GPU: RX 580 8GB
Post by crusher »
Thi is my org.chameleon.boot.plist
<plist version="1.0">
<dict>
	<key>DSDT</key>
	<string>/Extra/DSDT.aml</string>
	<key>GenerateCStates</key>
	<string>Yes</string>
	<key>GeneratePStates</key>
	<key>Graphics Mode</key>
	<string>1920x1080x32</string>
	<key>Kernel</key>
	<string>mach_kernel</string>
	<key>Kernel Flags</key>
	<string>darkwake=0</string>
	<key>Legacy Logo</key>
	<key>SMBIOS</key>
	<string>/Extra/smbios.plist</string>
	<key>SystemType</key>
	<string>1</string>
	<key>IGPEnabler</key>
	<string>Yes</key>
	<key>IGPpltformID</key>
	<string>0166000A</string>
	<key>Timeout</key>
	<string>2</string>
	<key>USBBusFix</key>
	<key>UseKernelCache</key>
	<key>device-properties</key>
	<string>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</string>
</dict>
</plist>
Mirone
Developer
Developer
Post by Mirone »
@crusher
Try this: [External Link Removed for Guests]
repair permissions, rebuild caches use Kextwizard .App
Mirone
Developer
Developer
Post by Mirone »
@fingerr
Try This: [External Link Removed for Guests]
crusher
CPU: Intel i9 9900K
GPU: RX 580 8GB
Post by crusher »
Ok.I try leather.And I answer here.
Thanks...
fingerr
CPU: i5-560M
Post by fingerr »
Hi Mirone,
unfortunately no devices detected with new kext, I've tried with "layout-id" 0x0C and 0x01.
--EDIT--
I've tried once again first kext (AppleHDA-ALC269.zip) you've uploaded and output is OK, but Mic is strange thing, I can see under Audio Input settings that record level bar is showing activity but when I try record something (Audacity or Skype test call) nothing is recorded (at least voice, when I'm tapping with myfinger the chasis then I can hear it, but it's very quiet and with noise).
WIll you have some time to check or give me some advice what can I check myself (at least I'll try to play with it but need some advice where to search for)? I see it like that: kext is loaded, output is working so binary patching is OK, and output is ok, but what setting/files can I play to get input from microphone recorded.
Thanks in advance.
best regards
fimngerr
crusher
CPU: Intel i9 9900K
GPU: RX 580 8GB
Post by crusher »
Mirone after install AppleHDA and DSDT.aml sound work :D But my microphone don't work.
How ti activate my microphone.Look my pcture.
Mirone
Developer
Developer
Post by Mirone »
@ fingerr
@ crusher
This guide cover how to make modifications in PathMaps
and Pinconfigs, I already did trablho hard for you these
make changes for themselves. fingerr use the previous kext and make changes.
I'm sorry I'm busy dealing with other issues.
fingerr
CPU: i5-560M
Post by fingerr »
Mirone wrote:@ fingerr
@ crusher
Big thanks for your help and time! I'll try to find the way to get the mic working.
Thanks to you I have working output and devices are show so I have good base.
--EDIT--
during boot log says:
03.10.2013 23:04:21,000 kernel[0]: Sound assertion - Command/Response TIMED OUT and ( kRequestStateMatch == fCodecRequest->state = 2 ), fCodecRequest->command->codec: 0xffffff800ef64500, fCodecRequest->command->verb: 0x3017FF00, fPoweredDown: 0
can't tell if its important
best regards
fingerr
telanx
Post by telanx »
Hi, artur-pt:
I am trying my best to modify the Original AppleHDA.kext to drive the IDT 92HD90BXX(111d76e7) from Dell Latitude E6320, and below is some output from me, unfortunately, I still couldn't make it happen, so maybe I need your guys help~~~
Part 1. Codec ConfigData from Codec_Dump.txt, and modify info.plist file in AppleHDA.kext\Plugin (Codec_Dump.txt pls refer to attached file)
codec_dump.txt.zip
Codec: IDT 92HD90BXX
Address: 0
Vendor Id: 0x111d76e7
Normal Hex: 11 1d 76 e7
Decimal: 287143655
Hex Byte Flipped: e7 76 1d 11
a. Original Codec ConfigData
00A71C20 00A71D10 00A71EA1 00A71F03
00B71C1f 00B71D10 00B71E21 00B71F03
00C71CF0 00C71D00 00C71E00 00C71F40
00D71C10 00D71D01 00D71E17 00D71F90
00E71C50 00E71D10 00E71E01 00E71F23
00F71C2e 00F71D10 00F71EA1 00F71F23
01071CF3 01071D00 01071E00 01071F40
01171CF2 01171D00 01171E00 01171F40
01F71CF0 01F71D00 01F71E00 01F71F40
02071CF0 02071D00 02071E00 02071F40
b. Verb Data which Corrected by me
00B71C10 00B71D10 00B71E21 00B71F03
00F71C20 00F71D11 00F71EA0 00F71F20
02071CF0 02071D00 02071E00 02071F40 00D70C02
Comments: I modified the Verb Data according to http://www.insanelymac.com/forum/topic/283754-patched-applehdakext-for-codecs-idt-92hd81b1x5-92hd91bxx-and-92hd87b24/, thanks Micky1979 :-)
Then, I modified the AppleHDA.kext/Contents/PlugIns/AppleHDAHardwareConfigDriver.kext\info.plist as following steps:(Edit with Plist Editor Pro)
a. Change "CodecID" to 287143655 in decimal(111d76e7 in hex)
b. copy above Verb Data into "ConfigData" area.(164 bytes)
c. Change "Function Group" as "1"
d. Change "Layout ID" as "12"(Same with DSDT).
file info.plist, download link: [External Link Removed for Guests]
(sorry, i couldn't upload file to this thread. so I use a dropbox link)
Part2. Patch the AppleHDA Binary file in AppleHDA.kext/Contents/MacOS.
I used bcc9's Script to patch the AppleHDA Binary file.
I modified the script file "patch-hda-codecs.pl", added the 111d76e7, and to replace the 11d4198b.
{ name => 'IDT 76e7', #aka 92HD90BXX
target_id => 0x111d76e7,
patch_id => 0x11d4198b #ADI 1984B
Comments: thanks bcc9's great effort. :-)
file Patched AppleHDA Binary file, download link:
Part3. Modified Layout12.xml.
I use zlib.pl (thanks RevoGirl R.I.P) to decompress the zlib file to xml, after modified, compress back.
b. Inputs Outputs
0: LineIn 0:HeadPhone
1: Mic 1:IntSpeaker
c. Change "PathMapID" to "1".
file modified Layout12.xml file, download link:
Part4. Calculate the PathMaps, and modify the platforms.xml.
Below is my PathMaps for Inputs and Outputs.
a. For Outputs (Pin Complex --> Audio Output)
    IntSpeaker:
      Hex:   0x0d --> 0x13
      Decimal: 13 --> 19
    HeadPhone:
      Hex:   0x0b --> 0x14
      Decimal: 11 --> 20
b. For Inputs (Pin Complex --> Audio Selector/Mixer --> Audio Input)
    Int Mic:
      Hex:   0x0f --> 0x17 --> 0x15
      Decimal: 15 --> 23 --> 21
    Ext Mic(LineIn):
      Hex:   0x0a --> 0x18 --> 0x16
      Decimal: 10 --> 24 --> 22
then, I put those into platforms.xml file, and compress it, drop back.
file modified platforms.xml file, download link:
Part5. Modify DSDT to add the Method function in Device (HDEF).
I set the layout ID 0x0c, 0x00, 0x00, 0x00
file AppleHDA.kext file, download link:
After done above, I drop the modified AppleHDA.kext to S\L\E, and repair the permission, then rebuild the kernelkeche.....reboot, but unfortunately, it didn't work at all.
so, Could you help to solve it? thanks, appreciate for your effort. :-)
Mirone
Developer
Developer
Post by Mirone »
@telanx
Mirone
Developer
Developer
Post by Mirone »
@fingerr
if all audio function
disregard.
telanx
Post by telanx »
Mirone wrote:@telanx
Dear Mrone:
Thanks for your help, I downloaded your kext, and tried them one by one, after installed the kext use kext utility, and reboot, but unfortunately, no matter Ver 1 and Ver 2 didn't work.....
Is there anything wrong with the "Pin ConfigData" or something else?
Best Regards.
