[Guide] Mobile Intel HD Graphics Skylake+
Post by MaLd0n » 30 Aug 2019, 12:40
novemberman, try with Intel HD/UHD 615, 620, 630, 640 and 650 7th properties
-Donated? Send me one PM-
novemberman
Donator
Donator
CPU: i5 kabylake
Motherboard: idk -laptop-
GPU: hd620
Post by novemberman » 30 Aug 2019, 17:36
30 Aug 2019, 12:40
I tried but doesn't seem to work.
Maybe I did it wrong.
Gonna try again maybe with plist editor.
thank you for your answer anyway.
Added in 36 minutes 1 second:
Tried again I copy/ paste but maybe I have other things that are messing with this ..; ?
Can you check ? thank you.
Post by MaLd0n » 30 Aug 2019, 18:52
novemberman,
config3.plist.zip
novemberman
Donator
Donator
CPU: i5 kabylake
GPU: hd620
Post by novemberman » 30 Aug 2019, 21:18
thanks I booted with your file but unfortunately same graphic problems..; I don't understand why it doesn't work.
Post by MaLd0n » 30 Aug 2019, 21:20
novemberman, try other platformid and devid
novemberman
Donator
Donator
CPU: i5 kabylake
GPU: hd620
Post by novemberman » 30 Aug 2019, 21:31
ok thanks, will let you know !
novemberman
Donator
Donator
CPU: i5 kabylake
GPU: hd620
Post by novemberman » 31 Aug 2019, 07:31
tried lots of platformid and devid provided in CloverConfigurator but none solve this problem.
and I noticed you didn't checked "inject intel" in the config file you gave me is it ok or should I inject ?
Because when I leave it uncheck I get 4 mb memory for graphics, (but not scaled blurs/gradients)
And when I check box I get 1536 mb vram but scaled blurs/gradients are back
thank you
Post by MaLd0n » 31 Aug 2019, 19:03
novemberman, if have 1536 mb u have a full load, need check what cause bug video, u can try other smbios
novemberman
Donator
Donator
CPU: i5 kabylake
GPU: hd620
Post by novemberman » 01 Sep 2019, 09:20
Ok thank you, I tried all possible smbios with KabyLake but still this bug. I think I'm going to stay with this fix for now :
Boot > Arguments -----> lilucpu=8
Devices > Properties > Devices > PciRoot(0)/Pci(0x02,0)
Devices > Properties > Properties Key > AAPL,ig-platform-id with in Properties Value > 00001619
Devices > Properties > Properties Key > device-id with in Properties Value > 16190000
Graphics > set ig-platform-id to 0x19160000
Graphics > enable Inject intel
kuarahy@icloud.com
CPU: i78th
Motherboard: ideapad S145
GPU: Intel
Post by kuarahy@icloud.com » 29 Sep 2019, 04:19
I have the intel UHD 620 8th generation, when I applied the changes to the file , my hackintosh loads everything but in the end shows a black screen ,do I have to check anything else in the plist file ?
Os. My machine : Lenovo ideapad S-145 i7 8th
Added in 53 minutes 15 seconds:
Hi
Besides the changes in the config.plist , is there anything else I need to check ?
Afternsplying the changes the system seems to load fully but the screens goes gray
Thanks in advance
Post by MaLd0n » 29 Sep 2019, 05:46
kuarahy@icloud.com, check a dev id and ig-platform-id native from ur igpu
kuarahy@icloud.com
CPU: i78th
GPU: Intel
Post by kuarahy@icloud.com » 29 Sep 2019, 05:50
Mardldon
Where can I check that , and what do I do next ?
Added in 3 minutes 57 seconds:
Before I applied this code I was getting a message like this
Whatevergreen ( Id is 0x3EA0 you should change it to 0x3EA5)
The system would load fully but I would get only 7mb of vram
Post by MaLd0n » 29 Sep 2019, 05:57
kuarahy@icloud.com, try a 620 or 630 8th
kuarahy@icloud.com
CPU: i78th
GPU: Intel
Post by kuarahy@icloud.com » 29 Sep 2019, 06:19
I’ve tried both 620 and 630 8th generation , 630 gives me back the message from whatevergreen (same message ) but the system loads with 7mb vram.
620 8th does not give any message from whatevergreen , the system loads completely ( I think) but gives me a gray screen ( though the hd seems to be working , light is blinking )
Added in 2 minutes 35 seconds:
I`ll try again tomorrow, its 3am here , got to sleep
Thanks for your help
Added in 5 minutes 59 seconds:
When I place the code for 620 8th generation I got this in the config.plist in clover configurator , is it correct ? I attached the SS in zip format
Added in 11 minutes 5 seconds:
Well apparently applying the code for 620 8th the system loads completely but it shows a gray display and I can’t see anything , but the keyboard is working , the volume keys works coz I can hear the volume going up and down when I press them , and also the cap locks light goes off and off when I press it.
What else do you suggest ? Should I send my files here to get further help ?
Thanks again
kuarahy@icloud.com
CPU: i78th
GPU: Intel
Post by kuarahy@icloud.com » 08 Oct 2019, 20:05
Did the fix work for anybody ?
Regards
Post by MaLd0n » 08 Oct 2019, 20:08
kuarahy@icloud.com, check ur native dev id and ig-platform-id
Zarach
Geek
Geek
CPU: QuadCore Intel Core i7 8559U
Motherboard: Lenovo Ideapad 330 15|KB
GPU: Intel UHD Graphics 620
Post by Zarach » 12 Oct 2019, 12:18
Alguma coisa deu errada...
Tentei os config plist mas só um abre o sistema, e quando abre é sem aceleração gráfica
Ps.: Meu notebook só tem uma placa de vídeo, ela é a Intel UHD 620
:help
HahAhAH
Post by MaLd0n » 12 Oct 2019, 15:11
Zarach, veja qual o dev id e ig-platform-id nativo na sua gpu
Zarach
Geek
Geek
Post by Zarach » 12 Oct 2019, 19:38
12 Oct 2019, 15:11
A informacao que tenho:
Vendor: 8086
Device: 5917
Sub: 17AA
Sub D: 3965
Vendor name: Intel Corporation
Device Name: UHD Graphics 620
HahAhAH
Post by MaLd0n » 13 Oct 2019, 02:58
Zarach,
<key>PciRoot(0)/Pci(0x02,0)</key>
<dict>
<data>
AAAbWQ==
</data>
<key>device-id</key>
<data>
FlkAAA==
</data>
<key>disable-external-gpu</key>
<data>
AQAAAA==
</data>
<key>enable-hdmi20</key>
<data>
AQAAAA==
</data>
<key>framebuffer-fbmem</key>
<data>
AACQAA==
</data>
<integer>1</integer>
<data>
AAAwAQ==
</data>
</dict>
