Mojave / Catalina on Mobos Series 100/200/300 with OpenCore Bootloader
moshaqeb84
CPU: i5 6200u
Motherboard: HP 80D1
GPU: intel hd 520
Mojave / Catalina on Mobos Series 100/200/300 with OpenCore 0.5.3
Post by moshaqeb84 »
hi maldon
could you please give me correct opencore efi and OC
thank you alot
sssteve
CPU: skylake i7
Motherboard: z170x
GPU: Vega 64
Post by sssteve »
Ok just for the record.
this is how I was able to fix thunderbolt:
I've added the force power .efi package to OpenCore ([External Link Removed for Guests])
And removed the TBH_C cable from the Alpine ridge as recommended on this post: [External Link Removed for Guests]
Problems I still have so far:
- Sleep never worked (not even in clover)
- USBs won't work the second time on the same port
Post by MaLd0n »
moshaqeb84, u have a full dsdt patch
Added in 36 seconds:
sssteve, what happens with sleep
extract one new send_me with ur last changes
moshaqeb84
CPU: i5 6200u
GPU: intel hd 520
when i put opencore efi he is restart
Post by MaLd0n »
moshaqeb84, OPENCORE is not our friend :lol:
berserk
CPU: core i3 m330
Motherboard: toshiba l500
GPU: mobility ati 4650
Post by berserk »
hhhhh ok thank you
sssteve
CPU: skylake i7
Motherboard: z170x
GPU: Vega 64
Post by sssteve »
Here's the updated send_me version:
Please note that I don't use all of the .AMLs in the ACPI folder (just the ones enabled on the Config.plist of OpenCore
Sleep:
It just reboots and I get a Kernel panic
When it boots back up, thunderbolt (usb devices on the Ultrafine monitor) are gone.
panic(cpu 4 caller 0xffffff7f8e54e970): "UPSB(iMac17,1): thunderbolt power on failed 0xffffffff\n"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/IOPCIFamily/IOPCIFamily-370.0.2/IOPCIBridge.cpp:1396
Backtrace (CPU 4), Frame : Return Address
0xffffff83c6fcba60 : 0xffffff800db39a3b
0xffffff83c6fcbab0 : 0xffffff800dc70fe5
0xffffff83c6fcbaf0 : 0xffffff800dc62a5e
0xffffff83c6fcbb40 : 0xffffff800dae0a40
0xffffff83c6fcbb60 : 0xffffff800db39127
0xffffff83c6fcbc60 : 0xffffff800db3950b
0xffffff83c6fcbcb0 : 0xffffff800e2d17f9
0xffffff83c6fcbd20 : 0xffffff7f8e54e970
0xffffff83c6fcbd40 : 0xffffff7f8e537bdb
0xffffff83c6fcbda0 : 0xffffff7f8e538116
0xffffff83c6fcbdc0 : 0xffffff7f8e536320
0xffffff83c6fcbe10 : 0xffffff7f8e540b33
0xffffff83c6fcbe30 : 0xffffff800e226654
0xffffff83c6fcbea0 : 0xffffff800e22645a
0xffffff83c6fcbec0 : 0xffffff800db7b625
0xffffff83c6fcbf40 : 0xffffff800db7b151
0xffffff83c6fcbfa0 : 0xffffff800dae013e
Kernel Extensions in backtrace:
com.apple.iokit.IOPCIFamily(2.9)[AA7C7A4F-9F5D-3533-9E78-177C3B6A72BF]@0xffffff7f8e52f000->0xffffff7f8e565fff
BSD process name corresponding to current thread: kernel_task
Boot args: dart=0 shikigva=60 agdpmod=pikera
Mac OS version:
19B88
Kernel version:
Darwin Kernel Version 19.0.0: Thu Oct 17 16:17:15 PDT 2019; root:xnu-6153.41.3~29/RELEASE_X86_64
Kernel UUID: 7503CD47-851F-321E-8747-50DB4299165F
Kernel slide: 0x000000000d800000
Kernel text base: 0xffffff800da00000
__HIB text base: 0xffffff800d900000
System model name: iMac17,1 (Mac-DB15BD556843C820)
System shutdown begun: NO
Panic diags file available: YES (0x0)
System uptime in nanoseconds: 465474601678
Post by MaLd0n »
sssteve, the problem is thunderbolt
u have many unnecessary files
use only it
Arquivo Comprimido.zip
thunder72fr
CPU: 8700K
Motherboard: ASUS ROG STRIXX Z370-E Gaming
GPU: Sapphire Radeon VII
Post by thunder72fr »
Hello MaldOn,
I change Clover for Opencore.
I need a new ddst, please:
Help me.
I extract without RTX2080ti and futur card AMD. Only iGPU
In my config.plist, i can disable RTX2080ti
i7 8700K / Z370-E Gaming / 32 Go DDR4 / Radeon VII / Triple Boot Windows 10 Pro - Macos 10.14.5 Mojave - Ubuntu 19.04
Post by MaLd0n »
thunder72fr, try with same
thunder72fr
CPU: 8700K
Crash with DSDT.aml special clover
Spookd
CPU: i9-9900KS
Motherboard: Gigabyte Z390 Designare
GPU: Radeon 7 (AMD direct)
Post by Spookd »
I am a brand new registered Olarila "member" (10m ago). I have a fresh newly built hackintosh and I would like to install Catalina 10.15.1 using OpenCore (Clover if better for my hardware) and with all ports working including native Thunderbolt 3 onboard. I have never used OpenCore but have used Clover. I have struggled to get this working and the quickest, best solution with better future compatibility (OpenCore) is what I am looking for. Please point me exactly where I can get up and running the quickest. If I am posting this in the wrong forum please let me know where I should be posting as I am new and thought it was best to describe everything up front in hopes I can get to a solution quickest. I have the following hardware:
I initially will be using HDMI cable to connect to monitor to get started then migrate to Display port or TB3 in near future.
Gigabyte Z390 (F8 BIOS)
i9-9900KS
HyperX Predator Black 64GB 3600MHz DDR4 CL17
Samsung 970Pro NVME M.2 (installed in 1st M.2 slot)
Fenvi T919 PC PCI WiFI Card (BCM94360CD)
Asus USB-BT400 Bluetooth dongle
Radeon 7 (direct from AMD) (installed in top PCIE 3.0 x16 slot)
EVGA SuperNova 1000 G3 80 Plus Gold
Fractal Design R6 case
Mac Keyboard (full with numbers)
Magic Mouse 2
Thank you to anyone that can jumpstart me in making this a quick and least time consuming success. I apologize if I am posting in wrong forum I didn't know where to go.
Post by MaLd0n »
Spookd, post one full dump
--Run_Me
Spookd
CPU: i9-9900KS
Post by Spookd »
MaLd0n thanks for your reply.
Before I found your site I tried a Clover install and frankly I think I am very close to getting it to work. I don't know how I am to use the RunMe app since I cant get the hackintosh working. I do have some real Macs so is that where I am to use it?
I will share with you my Clover EFI and a report that I think shows what the problems are with the hackintosh trying to boot. I used this Vanilla guide r/Hackintosh to build the EFI. Also, in case you are wondering why I am using OcQuirks (2.09), that is supposed to be a better replacement for AptioMemfix (or whatever that driver is named).
I have been at this for a few weeks and at the end of my patience trying to get this to work. I would really appreciate any help you can offer to get me up and running fast with Catalina 10.15.1 and with all ports, iMessage and everything else a Mac does and have it working. PayPal $ ready to go if this can get done.
Post by MaLd0n »
Spookd, check if work
EFI.zip
Spookd
CPU: i9-9900KS
Post by Spookd »
i am working on Bootcamp windows side right now, let me go to my MacBookPro and download your EFI and pop it in the hack and see if it can work.
By the way, I love your quick response and help. I will report back in a few minutes.
Added in 16 minutes 17 seconds:
MaLd0n okay, I popped it in, pressed reset button on hack, a small text menu opened in top left corner of screen. I could barely read it before it auto booted. It streamed a bunch of code on the screen for a bit then flashed a pic of the Gigabyte BIOS icon/pic and like 8 or so text errors flashed so quick I couldn't read and it went back to the text boot screen and did the same thing over and over. I never had the chance to choose how to boot it just did it on its own.
Anything I should try now? I did happen to notice the first menu item said this "Install Catalina (external)". I am using an internal Samsung 970 Pro NVME M.2. I don't have any external drives connected. Does that matter?
By the way, my BIOS settings are on F8 (newest BIOS that supports 9900KS) and I changed the settings to what most everybody has changed for this build and setup.
This may appear to be a very dumb question but is there a specific USB port I am supposed to be using to boot? 2.0, 3.0? Not sure if it makes a difference.
Post by MaLd0n »
Spookd, remove dsdt and try
Spookd
CPU: i9-9900KS
Post by Spookd »
Just the DSDT.aml file and nothing else?
Added in 6 minutes 41 seconds:
MaLd0n, okay, I only removed that DSDT.aml file and tried again. Same result, doing same thing and not working
Should I remove the Radeon 7, Enable iGPU in BIOS and try again? Then, if it works re-install, disable iGPU in BIOS and fix anything from there that might not be working?
I did try removing Radeon 7, Enable iGPU in BIOS and make Auto and it didn't work, did the same as before but even quicker fail. I re-installed Radeon 7, Disabled iGPU and set to PCIE 1 in BIOS. I am back to square one with no progress.
Post by MaLd0n »
Spookd, use clover for one perfect hack, oc is a new project and need many many many improvements
Nexxusone
CPU: i5 9400f
Motherboard: Asus B360 G Gaming
GPU: sapphire rx480 4GB Nitro+
Post by Nexxusone »
Send me Garys-iMac-Pro.zip
this is the zip from runme.app - trying to test opencore 0.5.3 on my B360 Asus Motherboard - the version in post 1 doesn't work - so included my zip file for a opencore sdst creation.
my mac os is 10.15.2 beta3 - the clover bootloader on ssd has been removed (was fully working - but gone clean for open core) and i boot my samsung 2.5inch 850 ssd (sata port 1) via usb clover stick.
I understand opencore is flaky with NVMe drives (this is my m.2_2 drive in PCI-e X4 mode this has windows on) can be removed is opencore will not play nicely
my m.2_1 drive is pci-e X2 mode as AHCI /sata mode is a WDC120GB green drive - this is blank - also understand opencore seeing nvme drives as sata is flaky too... (i have been reading both old and new open core guides... till head hurts!)
my OSX drive that boot fine is a samsung 850 ssd in sata port one has 10.15.2. beta3 on running a RX5700 (yes i know about agpdmod+pikera)
i can easily remove all m.2 drives and just use 850ssd if required due to conflicts, the rx5700 can be swapped for a rx480 if required,
I am using ethernet intel1219v7 - can remove my asus wi-fi card if required but this was plug and play.
some help with any or all of above - even if advice on required kexts etc.
