Mojave / Catalina on Mobos Series 100/200/300 with OpenCore Bootloader
Mojave / Catalina on Mobos Series 100/200/300 with OpenCore 0.5.3
Post by MaLd0n »
contactwajeeh, with oc and dual boot u need apply some extra patches or kill windows installer
contactwajeeh
Donator
Donator
CPU: Intel i3 6006U
Motherboard: Asus x541uak
GPU: Intel HD 520
Post by contactwajeeh »
19 Nov 2019, 19:55
I tried booting with the folder in the first post, but unfortunately its just rebooting within seconds of apple logo screen. also windows 10 also shows up in the boot up options but unable to boot it as well. :(
Post by MaLd0n »
contactwajeeh, clover is much better, years of hard work from many people
contactwajeeh
Donator
Donator
CPU: Intel i3 6006U
GPU: Intel HD 520
19 Nov 2019, 20:17
very true. Appreciate your time @MaLd0n. Count me in, whenever you have that OC test ready.
Post by MaLd0n »
contactwajeeh, work fine here, but have several bugs and problems ;)
holyfield
Post by holyfield »
19 Nov 2019, 18:02
holyfield, use efi folder oc from first post, reboot and extract one send_me
Thank you, but I'm not sure what are you trying to tell. Where and how I should use that EFI folder? What do you meaning by reboot and extract one send_me. Sry I'm unfamiliar with OpenCore.
I used EFI folder on USB flash drive and I get several options (EFI, macOS etc), but when I choose macOS I will get an error
ERROR allocating 0x11c7d pages at 0x0... alloc type 2
Couldn't allocate runtime area
OC: Boot failed - Aborted
OCB: StartImage failed - Aborte
Halting on critical error
Post by MaLd0n »
holyfield, :shock:
sssteve
CPU: skylake i7
Motherboard: z170x
GPU: Vega 64
Post by sssteve »
Hey Maldon, here's my file.
I appreciate the help.
Cheers!
I finally donated! so the beer is on me ;)
Post by MaLd0n »
sssteve, hey, thx for support
before restart with dsdt, generate one injector USB with hackintool
sssteve
CPU: skylake i7
Motherboard: z170x
GPU: Vega 64
Post by sssteve »
Hey MLd0n,
A couple of things aren't working: my thunderbolt (alpine ridge) and any of the USBs on the Thunderbolt Display.
is that something you could help me with?
Post by MaLd0n »
sssteve, extract new send_me
sssteve
CPU: skylake i7
Motherboard: z170x
GPU: Vega 64
Post by sssteve »
Hey MaLd0n
Here's my latest files:
23 Nov 2019, 17:42
Hey MLd0n,
Post by MaLd0n »
sssteve, Ur thunderbolt is working, but hotplug don't work native, u can try with kgp ssdt
OC.zip
sssteve
CPU: skylake i7
Motherboard: z170x
GPU: Vega 64
Post by sssteve »
I've tried it, no luck.
Any ideas ? It used to work on clover in the past.
Post by MaLd0n »
sssteve, use same ssdt tbh3 from clover
sssteve
CPU: skylake i7
Motherboard: z170x
GPU: Vega 64
Post by sssteve »
Also tried that, no luck.
It's the same file, I ran a diff.
What could be the problem?
Post by MaLd0n »
sssteve, nop idea, if work on clover need work on oc, just need add a name of ssdt into config.plist
Eonx
CPU: 8700k
Motherboard: Asus maximus x hero
GPU: Rx 590
Post by Eonx »
16 Nov 2019, 16:24
Eonx, DSDT.aml.zip
Hello @MaLd0n
I can't properly shut my pc down, it keeps restarting when I select shutdown and then bios says there is failure, I have to hard shutdown from case button. What can I do ?
Post by MaLd0n »
Eonx, my dsdt have this fix, if don't work u need check what cause it
Eonx
CPU: 8700k
GPU: Rx 590
Post by Eonx »
How can I check what is causing it?
