Mojave / Catalina on Mobos Series 100/200/300 with OpenCore Bootloader
GOVERNOR
CPU: i7
Motherboard: Asus
GPU: Asus
Mojave / Catalina on Mobos Series 100/200/300 with OpenCore 0.5.3
Post by GOVERNOR »
Master I can't install the Mojave and the Catalina. I'm using sabertooth z87 with i7 & hhd.
can you help me?
Post by MaLd0n »
GOVERNOR, only skylake+ here, i don't have any skylake- for test
Eonx
CPU: 8700k
Motherboard: Asus maximus x hero
GPU: Rx 590
Post by Eonx »
Thank you for your generosity, please help me for Catalina.
Post by MaLd0n »
Eonx,
Eonx
CPU: 8700k
GPU: Rx 590
Post by Eonx »
16 Nov 2019, 16:24
Eonx, DSDT.aml.zip
Thank you so much, it worked without any issues.
ccoaston
CPU: i7 9700k
Motherboard: MAXIMUS XI (WIFI)
GPU: Radeon Vega 64
Post by ccoaston »
@MaLd0n,
My PCI section in system information is completely blank. Everything seems to be working so far except not being able to turn my main volume down for my Monitor speakers.
Mobo: Asus Hero XI (Wifi/Bluetooth disabled - Using Fenvi card)
Really grateful for the help!
Attached is my Send me File
Post by MaLd0n »
ccoaston,
remove ssdt Olarila
holyfield
Post by holyfield »
29 Jun 2019, 00:22
First, stay with one USB Stick bootable for rescue if need or use EFI folder in USB Stick bootable with MacOs
*If u have a DSDT patched for Clover, don't use, need patch again for OC
I'm a bit confused. What exactly is needed to do?
Added in 34 seconds:
29 Jun 2019, 00:22
Post by MaLd0n »
holyfield, first test with one bootable usb stick
antrace
Donator
Donator
CPU: i5 8600
Motherboard: asus prime p z370
GPU: gigabyte rx 580
Post by antrace »
hey mald0n, can you please make a DSDT for me that works with OC and catalina? iam running OC already and got everything to work except for sleep. i tried the old DSDT you made for me, but it wont work with your new OC 0.5.3 :(
i think its my dsdt which is wrong so i kindly request a new one :)
regards
Post by MaLd0n »
antrace, use folder from first post, if dont work u need remove dsdt boot from system and extract new send_me
antrace
Donator
Donator
CPU: i5 8600
Post by antrace »
it did crash on boot with some weird errors. i extracted new dsdt now. i had loaded a dsdt the first time when i did it.
Post by MaLd0n »
antrace, u don't stay with my folder, use it with my dsdt
antrace
Donator
Donator
CPU: i5 8600
Post by antrace »
i tried now and it will only boot with your EFI folder (when i put DSDT in acpi folder) if i remove "Rename GFX0 to IGPU (Graphics)" patch. if i dont remove it it will give me acpi read errors and wont boot. is it because my internal gpu was deactivated when i made the dsdt?
i have made a screenshot to show. :)
whatever, once i removed it the system boots just fine, but sleep still doesnt work. it will go to sleep and wake up directly again. ive disable wake from lan ofcourse, but it didnt help.
any clue what we can do?
thx btw for your help... again :)
Post by MaLd0n »
antrace,
use power button for wake
antrace
Donator
Donator
CPU: i5 8600
Post by antrace »
thank you soooooo much! it works!! :)
i also made audio to work and put in my smbios. really everything is working now. you a real wizard man.
thx again!!!!
Post by MaLd0n »
antrace, ;)
holyfield
Post by holyfield »
18 Nov 2019, 14:53
Thank you. I find your post insanelymac. I have also GA Z390 DESIGNARE with Intel Core i9-9900K processor. I used Clover to install Catalina, but seems that it's smart to have OpenCore as bootloader to get native video encoding to work with Radeon VII. So I want to convert Clover to OpenCore. I used your Clover pack for my beast.
Post by MaLd0n »
holyfield, use efi folder oc from first post, reboot and extract one send_me
contactwajeeh
Donator
Donator
CPU: Intel i3 6006U
Motherboard: Asus x541uak
GPU: Intel HD 520
Post by contactwajeeh »
15 Nov 2019, 11:08
contactwajeeh, yes, same folder work, just need add some kexts
Can you please make one for laptops too, I am ready to test Also does OC supports dual booting, I have current setup Catalina / Win 10 just making sure that it will work after migration.
