Mojave / Catalina on Mobos Series 100/200/300 with OpenCore Bootloader
RandomTech7
Donator
Donator
CPU: i7-8700K
Motherboard: msi Z390i Gaming Edge
GPU: RX 5700 XT
Mojave / Catalina on Mobos Series 100/200/300 with OpenCore 0.5.3
Post by RandomTech7 »
12 Nov 2019, 16:33
RandomTech7, what about damage? corrupted system?
I did something wrong, as was in boot options of OC, I selected "install macOS Catalina" not "external" so it started to installing immediately to SSD and deleted OS from SSD.
Now "boot installer from external usb" is giving me glitch, screen is divided to two halfs.
This is how it looks like.
iHack Pro: msi Z390i Gaming Edge, i7-8700K, RX 5700 XT, M.2 SSD 256GB, 32GB RAM @3200Mhz (Catalina), iMacPro1,1
Hackbook Pro: (MSI GE62VR 6RF) i7-6700HQ, Intel HD 530, GTX1060 (disabled), 16GB RAM @2400Mhz (Mojave 10.14.6)
Post by MaLd0n »
RandomTech7, try with -x
RandomTech7
Donator
Donator
CPU: i7-8700K
GPU: RX 5700 XT
12 Nov 2019, 18:40
not helping :/
Post by MaLd0n »
RandomTech7, remove whatevergreen and try
RandomTech7
Donator
Donator
CPU: i7-8700K
GPU: RX 5700 XT
12 Nov 2019, 20:00
that also didn't work.. I had my working USB EFI folder backup but even that is not working, no OC no Clover is working now :cry:
I will wait for better WEG might have better support for Navi.
Post by MaLd0n »
RandomTech7, some people use without weg and work good, try a 10.15.2 beta
RandomTech7
Donator
Donator
CPU: i7-8700K
GPU: RX 5700 XT
12 Nov 2019, 21:33
ok will do :)
RandomTech7
Donator
Donator
CPU: i7-8700K
GPU: RX 5700 XT
hi Mald0n,
I installed Catalina 10.15.1 (19B88) on my system agin with Clover, is it easy to change to open core? if yes, how can I modify config.plist? is PlistEdit Pro app good for that?
Can I copy Clover plist and create new one for open core?
iMacPro1,1 smbios
i7 8700K
RX 5700 XT
32GB G-Skill 3200Mhz
Post by MaLd0n »
RandomTech7, me efi dont work?
if need add ssdt Olarila
SSDT-Olarila.aml.zip
after reboot extract send_me for dsdt patch
RandomTech7
Donator
Donator
CPU: i7-8700K
GPU: RX 5700 XT
13 Nov 2019, 18:06
First boot to blackscreen, added agdpmod=pikera in plist then boot ok :D
this is runme app:
Post by MaLd0n »
RandomTech7,
RandomTech7
Donator
Donator
CPU: i7-8700K
GPU: RX 5700 XT
13 Nov 2019, 20:46
RandomTech7, DSDT.aml.zip
I lost build in audio, only hdmi working
Post by MaLd0n »
RandomTech7, what layout-id u use? in dsdt have 1, just change
RandomTech7
Donator
Donator
CPU: i7-8700K
GPU: RX 5700 XT
13 Nov 2019, 21:12
ok I will change and report back, thank you
RandomTech7
Donator
Donator
CPU: i7-8700K
GPU: RX 5700 XT
13 Nov 2019, 21:12
nothing work for me :(
according to msi website my motherboard use alc892 audio codec.
and according to ALC Wikipedia, the alc892 use layout 1, 2, 3, 4, 5, 7, 12, 15, 16, 17, 18, 28, 31, 90, 92, 97, 99.. I tried all ( I changed numbers to Hexadecimal Value for dsdt ) but audio not working :cry:
do yo think ApplHDA patcher work? may I try it?
Post by MaLd0n »
RandomTech7, ur codec from ur mobo just use 1 or 7, work good
RandomTech7
Donator
Donator
CPU: i7-8700K
GPU: RX 5700 XT
14 Nov 2019, 00:37
for me both not working, its weird I know.. I had same problem with Mojave, maybe I change my msi with gigabyte or asus
Post by MaLd0n »
RandomTech7, gigabyte ever
contactwajeeh
Donator
Donator
CPU: Intel i3 6006U
Motherboard: Asus x541uak
GPU: Intel HD 520
Post by contactwajeeh »
@M
14 Nov 2019, 02:36
Will laptops be supported by opencore?
Post by MaLd0n »
contactwajeeh, yes, same folder work, just need add some kexts
