Mojave / Catalina on Mobos Series 100/200/300 with OpenCore 0.5.3
madgario
CPU: i7 8700K
Motherboard: Z370N-Wifi
GPU: Radeon VII
Post by madgario » 05 Oct 2019, 15:04
05 Oct 2019, 14:32
madgario, u need boot from hdd/ssd with opencore and extract
Here it is :) Thank you @Mald0n
Post by MaLd0n » 05 Oct 2019, 16:02
madgario,
madgario
CPU: i7 8700K
GPU: Radeon VII
Post by madgario » 05 Oct 2019, 16:52
quick question, how do I dual boot my windows SSD from opencore?
Post by MaLd0n » 05 Oct 2019, 16:56
madgario, need read a manual for it and remember, is a newborn project :smoke:
Lorenzoo
CPU: i3-8300
Motherboard: Gigabyte b360m-ds3h
GPU: RX 480 nitro
Post by Lorenzoo » 09 Oct 2019, 09:21
Good morning MaLdOn. Lorenzo, from France ;). I hope you're doing fine my friend.
I am trying to install Mojave via open core, with your files, but at the boot the computer gets stuck after some seconds... I put you a pic of the moment when it blocks...
Post by MaLd0n » 09 Oct 2019, 13:50
Lorenzoo, try update all kexts
Lorenzoo
CPU: i3-8300
GPU: RX 480 nitro
Post by Lorenzoo » 09 Oct 2019, 14:07
ok I ll do that tonight and I tell you. Thanks
hbiieb95
CPU: Intel Pentium G4560
Motherboard: ASUS Z170-A
GPU: AMD Radeon RX460 2GB
Post by hbiieb95 » 09 Oct 2019, 18:41
Hey MaLd0, here is my send_me file, help me with the dsdt
thank you
Post by MaLd0n » 09 Oct 2019, 19:04
hbiieb95, ur config is very wrong, use olarila clover folder for chipset 100/200/300 with fakecpuid for ur processor if need, reboot and extract new send_me
Lorenzoo
CPU: i3-8300
GPU: RX 480 nitro
Post by Lorenzoo » 09 Oct 2019, 20:19
09 Oct 2019, 13:50
Good night MaLdOn. So I just tried with all kexts updated, and still the same, it get stuck, not at the same time but not far... I edited the config.plist, and it is totally empty, maybe it is a part of the problem, no ? I join you a pic and my efi folder.
Thanks in advance,
Post by MaLd0n » 09 Oct 2019, 20:35
Lorenzoo, i don't have any haswell here for tests
Lorenzoo
CPU: i3-8300
GPU: RX 480 nitro
Post by Lorenzoo » 09 Oct 2019, 21:24
09 Oct 2019, 20:35
Sorry, my mistake, I didn't precise my config: gigabyte B360M-ds3h/i3-8300/RX480 Nitro. The Haswell computer is relaxing..
Thanks again,
Post by MaLd0n » 09 Oct 2019, 22:02
Lorenzoo, send me original dsdt
Lorenzoo
CPU: i3-8300
GPU: RX 480 nitro
Post by Lorenzoo » 09 Oct 2019, 22:21
09 Oct 2019, 22:02
Here it is, original dsdt files from clover.
Post by MaLd0n » 09 Oct 2019, 23:47
Lorenzoo, check if work
haitrvn
CPU: I7 8750h
Motherboard: MS-16P6
GPU: GTX1050Ti
Post by haitrvn » 10 Oct 2019, 05:19
My RunMe files exported, i still use DSDT patched for Mojave - Clover version.
Everything works fine except for the trackpad gesture.
Should i re-export origin dsdt for OpenCore? :superman
Post by MaLd0n » 10 Oct 2019, 13:40
haitrvn, u can try
u don't need any ssdt, have all into dsdt
Lorenzoo
CPU: i3-8300
GPU: RX 480 nitro
Post by Lorenzoo » 10 Oct 2019, 20:00
09 Oct 2019, 23:47
Good night MaLdOn. Well sorry compadre but still not working. Gets stuck a bit farther this time..
septicshock
CPU: i7-6700K
Motherboard: GA Z170m-D3H
GPU: AMD Radeon 570
Post by septicshock » 10 Oct 2019, 20:22
Hi Maldon,
I have created a config.plist for OC using the manual. I'm pretty sure everything is as it should be per the guide. After OC launches and shows the picker, choosing any Mac partition (Mojave or Catalina) just freezes at the OC picker screen (does not show any attempt at launching the Mac OS).
Any help is greatly appreciated.
Post by MaLd0n » 11 Oct 2019, 04:09
Lorenzoo, the problem is oc, this bootloader need many improvements for run one real good hack
Added in 1 minute 19 seconds:
septicshock, i need read manual for update efi from first post, many work here, i'll try check it
