Mojave / Catalina on Mobos Series 100/200/300 with OpenCore Bootloader
rob88v
CPU: i7-8700K
Motherboard: Z370 Aorus Gaming 7
GPU: NVIDIA GTX 1080Ti
Post by rob88v »
@MaLd0n Here are my send me files for OpenCore for DSDT creation. I've been having trouble getting the iGPU to run connectorless for compute tasks, and I still get this error: [IGPU] Graphics driver failed to load: could not register with Framebuffer driver! I have tried putting in device properties for my iGPU but to no avail. I also have to use alcid=16 for my audio to work as it won't inject in OC normally. It's not a big issue, but I would like to keep the arguments as minimal as possible for my config. Thank you in advance for your outstanding work! PS: I am using 10.13.6 hopefully that won't pose an issue.
TwistedSystems
CPU: i7-7700K
Motherboard: GA-Z270MX-Gaming 5
GPU: Sapphire RX580 8GB
Post by TwistedSystems »
MaLd0n, :guitar :guitar Working with no issues. Thanks for the help again.
Post by MaLd0n »
TwistedSystems, i forgot one things, use it
Added in 5 minutes 5 seconds:
rob88v,
use only dsdt + ssdt tbh3
rob88v
CPU: i7-8700K
Post by rob88v »
14 Sep 2019, 16:19
rob88v, DSDT.aml.zip
Thanks @MaLd0n the DSDT works great! The only issue I have is that my iGPU still fails to load the driver, I must of done something incorrect on the framebuffer device properties as I keep getting the "failed to register to framebuffer driver" error, I have attached my config maybe there is an incorrect device id and platform id. I am using a GTX 1080Ti as the dGPU on 10.13.6 ( 17G8030) and my iGPU is the UHD 630 which I am trying to run as connectorless. With clover I used the Kaby Lake fake id, will I still need it with Opencore or should I be able to use the Coffee Lake id's?
Post by MaLd0n »
rob88v, u need a 59128086 and 59120003 for high sierra, shikigva=60 if need
rob88v
CPU: i7-8700K
Post by rob88v »
14 Sep 2019, 17:42
Thanks that worked for me! Does opencore need anything special in the folder to load windows 10 properly it sees the entry but when I click it the circle spins for a second and it reboots automatically. Any thoughts on what I could be doing wrong?
Post by MaLd0n »
rob88v, need check in manual for some instructions, i think work
telepati
CPU: i9 9900K
Motherboard: ASUS TUF Z390 Gaming Plus
GPU: Asus ROG RX 560
Post by telepati »
MaLd0n, I need a help OC DSDT. I used your EFI and its booted without any problem. Could you please help for creating OC DSDT? Thank you.
Post by MaLd0n »
telepati,
telepati
CPU: i9 9900K
Post by telepati »
MaLd0n, you are like a :superman . Thank you.
Added in 39 minutes 9 seconds:
16 Sep 2019, 17:04
telepati, DSDT.aml.zip
I test it now. No Bluetooth and USB hardware. Without DSDT is working but with DSDT no Bluetooth and USB hardware. I also checked DSDT and its available on config.plist.
I also get this on boot;
Post by MaLd0n »
telepati, use ssdts for usb and acpi warnings fix
Arquivo Comprimido.zip
u need drop OEM ssdts and put news, OC devs need add a easy way for it
telepati
CPU: i9 9900K
Post by telepati »
MaLd0n, I added these SSDTs to ACPI folder added as an item to config plist. But it didnt change anything. No USBs and bluetooth. I realise another problem. I cant see my windows partition on OC boot screen. I am just seeing two drive 1. Mojave 2. Recovery.
Edit: I used the old method for USB and Bluetooth.(SSDT-UIAC.aml and USBKextAll.kext) it's working now. But I cant see windows drive on OC boot screen.
Post by MaLd0n »
telepati, with OC u need block OEM table with "TableLength"
and add edited oem table
Clover made it on the fly with option in ACPI tab
telepati
CPU: i9 9900K
Post by telepati »
MaLd0n, Thank you.
hoangtuau
CPU: i5 9400
Motherboard: gigabyte b360m aorus pro
GPU: gtx 1050
Post by hoangtuau »
Please help me patched DSDT.
My hackintosh only iMac name
michaelanhvu
CPU: i7-6700k
Motherboard: Gigabyte Gaming G7-Z170
GPU: AMD R9380
Post by michaelanhvu »
I'm running RunMe.app and get an error.
Post by MaLd0n »
hoangtuau, extract files with opencore, not clover
Added in 20 seconds:
michaelanhvu,
--Run_Me
michaelanhvu
CPU: i7-6700k
GPU: AMD R9380
Oh, it's error for computer name, i renamed and it's ok.
Here is my dump files.
Post by MaLd0n »
michaelanhvu, u have a dsdt full patched
michaelanhvu
CPU: i7-6700k
GPU: AMD R9380
25 Sep 2019, 04:16
Why it's can't boot to opencore? So, i make a wrong way usb?
